I have a system that is generating internal events for objects. I am extending their debugger to display a human-readable version of the events sent to the debugger.
For instance, the system will generate "OnClick" for the "Blue Button" control, on a "a-guid-value-for-the-view" view. If the readable version of "a-guid-value-for-the-view" is "Customer Edit View" I want to output
On the Customer Edit View, Blue Button was clicked.
To set this up, I will Map every event to a template literal which I evaluate dynamically. My code works but the setup of the Map in PopulateEvents looks too heavy. Is there a way to make this more readable?
//Setup the list of events
function populateEvents() {
        events = new Map([
            ["OnClick", function _renderEvent(viewId, controlName, properEvent) {
                return `On the ${_viewName(viewId)}, ${controlName} was ${properEvent}.`}],
    //Function to translate system event
    var eventName = function (eventParams) {
        return events.get(systemEventName)(viewId, controlName, properEvent);
    var viewName = function (viewId) {
        if (!views.has(viewId)) {
            views.set(viewId, fnToConvertViewIdToName(viewId))
        return views(viewId);
Rohit Gupta
  • 203
strattonn
  • 131
No. Use inheritance instead -- it is unnecessary to create a Map as there is no advantage to re-defining a handler for each event and to have to suffer the added processing time. It will be much much easier to add an event handler to the base object. I sugfgest you use inheritance & composition instead of a static implementation on each instance of your DOM-Objects -- You might need a quick re-read on event-handling in JS (or any favorite language).
Realize that an event is an event is an event and you only need a generic log handler that is a part of the event handling chain -- just install your callback function into the event chain so it gets handled for any and all events and then build a case-statement that switches on eventType to do the proper logging:
function anyEvent(event) {
    switch (event.eventType) {
        case "onclick":
               var view = dosomethingToGetTheView(event);
               var parent = getParentObject(event);
               var type = ...
               logEvent(view, event, parent, type...);
               break;
Greg Patnude
  • 96
  • That's a great idea and I'll check into that but I'm not sure if I have access to this. I'm extending their debugging routine. That routine is giving me all the information I need in one place, so it's a case of translating the data in this function, which is why I'm using a Map. As for hooking into the events I'd have to work out what they're doing first which is a bunch of work, whereas I have all this right on hand. – strattonn Oct 17 '18 at 23:40
