It's a sort of simple compression where you use one numeric variable to store many boolean / binary states, using doubling and the fact that every doubling number is 1 + the sum of all the previous ones.
I'm sure it must be an old, well-known technique, I'd like to know what it's called to refer to it properly. I've done several searches on every way I can think of to describe it, but found nothing beyond some blog articles where the article authors seem to have figured this out themselves and don't know what to call it, either (example 1, example 2).
For example, here's a very simple implementation intended to illustrate the concept:
packStatesIntoNumber () {
let num = 0
if (this.stateA) num += 1
if (this.stateB) num += 2
if (this.stateC) num += 4
if (this.stateD) num += 8
if (this.stateE) num += 16
if (this.stateF) num += 32
return num
unpackStatesFromNumber (num) {
assert(num < 64)
this.stateF = num >= 32; if (this.stateF) num -= 32
this.stateE = num >= 16; if (this.stateE) num -= 16
this.stateD = num >= 8; if (this.stateD) num -= 8
this.stateC = num >= 4; if (this.stateC) num -= 4
this.stateB = num >= 2; if (this.stateB) num -= 2
this.stateA = num >= 1; if (this.stateA) num -= 1
You could also use bitwise operators, base 2 number parsing, enums... There are many more efficient ways to implement it, I'm interested in the name of the approach more generally.
