The java.util.Predicate
interface contains the test(...)
method, whose JavaDoc description states that it [evaluates] this predicate on the given argument and that it [returns] true if the input argument matches the predicate, otherwise false.
Should I take this to mean that test(..)
always returns a true
or a false
and is never allowed to throw an exception? I ask, because the classes from the Collections framework have the concept of "optional operations", where it is explicitly mentioned in the JavaDoc that certain methods might throw UnsupportedOperationException
First of all, I'm not a Java programmer, I don't work in software development per se, but I use a language that is similar to Java in some respects and I try to follow Java conventions where possible. I've tried searching for resources on the topic, but most of them mention how to throw checked exceptions from stream code.
I'll try to make a contrived example here. Let's say I have a Person
class and a Predicate
defined like class IsAdult implements Predicate<Object>
. Notice that I've used Predicate<Object>
and not of Person
. Would it be OK to throw an exception if the object being tested is not a Person
, for which it's possible to determine whether they are an adult, or should the predicate return false
, seeing as how the object that it tested couldn't under any circumstances have been an adult.
