-1
I understand in a single core system, multiple threads operate in sequence, scheduled by the OS. Hence it can't be possible to have a race condition since by definition they are taking turns locking a variable.
However if I have a multicore processor, is it possible for multiple threads of the same process to be run concurrently and hence both attempt to lock a variable at the same time?
For example I have a global semaphore s = 1
If 2 threads on different cores ran simultaneously, they both would try to decrement the semaphore and be successful in race conditions.
In a single core, 2 threads operate in sequence (scheduled by OS), so this is not possible, as the second thread will see s = 0 by the time it is scheduled.
Therefore I'm wondering if I have a process that spawns multiple threads, and I have multiple cores, what is stopping the race condition where 2 threads running simultaneously see the global semaphore as s=1 at the same time and attempt to operate on it?
Chowza
  • 101
  • I think you'll find your answer here: https://softwareengineering.stackexchange.com/questions/245189/what-prevents-a-race-condition-on-a-lock?rq=1 – Simon Groenewolt Sep 02 '18 at 20:29
    Possible duplicate of [What prevents a race condition on a lock?](https://softwareengineering.stackexchange.com/questions/245189/what-prevents-a-race-condition-on-a-lock) – Martin Maat Sep 02 '18 at 21:24
  • ah did not see that. Wasn't aware it was implemented in hardware. Thanks! – Chowza Sep 03 '18 at 09:11
They do, though there are two potential kinds of threading models, which go do the nature of the "turn" or slice of the CPU offered to a thread by the operating system: cooperative and interrupted — the former requires the programmer to periodically yield, and the latter uses the CPU clock and other I/O device interrupts to determine what code to run next.
Most modern operating systems offer interrupted threads rather than cooperative threads — they work better for very independent workloads, and work better on multi-cpu architectures as well, and so I'll not discuss cooperative threads further.
This is generally not the case since with modern threads, the granularity of potential interruption is very small: between any two machine code instructions.  Because of this, these threads are still subject to race conditions, since many operations we might consider in a high level language expand to multiple machine instructions.
Then, for interdependent threads — i.e. working on the same in-memory data structures, single cpu or multi-cpu — the threads should announce when they are starting to work on shared data that could lead to a race.  To accomplish this, the hardware guarantees that some minimum primitive operations are atomic (performed atomically — or aborted) across all CPUs and the software uses these hardware features to compose larger critical sections, locks, and/or transactions.
See for example, the MESI protocol, which is a mechanism by which CPU's use their caches to communicate the status of these primitive operations.
Erik Eidt
  • 33,282
  • 57
  • 91
  • To add, those atomic options are provided by the OS's APIs, so use them rather than attempting to roll your own. – whatsisname Sep 13 '18 at 04:50
