TL;DR I would suggest implementing a combination of the second(PUT /invoices/{id}
) and third(PATCH /invoices/{id}/
) suggestion.
Let us look at the first part which is the URI. Many standards can exist as to how the uri's can be formed depending upon the guidelines followed by a project or team. However, for simplicity one of the thumb rules that I would prefer to keep is that a given resource end-point should ideally have a matching get end-point' (except if the endpoint ends with an operation name).
To make my point clear, PUT /invoices/{id}/status
- this suggestion should only make sense (or make things intuitive for the api consumer) when you also have an equivalent GET /invoices/{id}/status
for it, which I believe would not be the case as it will only make your development effort far more cumbersome. If by any chance you do want to selectively expose attributes in 'GET', I would still suggest implementing GraphQL
for 'GET' rather than implementing your own standard and going with 'PATCH' for updates. (Also, just a small recommendation, you ideally would want to keep attributes such as status
in an invoice
as read-only as they represent the state of the invoice and should ideally be changed via some operation-specific endpoints such as POST /invoices/{id}/send
rather than through a PUT
operation.
Coming towards the other suggestions mentioned, PUT /invoices/{id}
and PATCH /invoices/{id}/
, the decision is based upon whether the API is exposed internally or externally because otherwise, both are valid HTTP standards.
- If exposed externally, I would suggest implementing both PUT and PATCH because many of the API consumers might not have relevant support for implementing PATCH or might consider it as a bit too tricky to implement
it flawlessly, depending upon the developers they have and in such a scenario you would prefer to give them both the options.
- If the API is strictly for internal usage, you can in such cases choose to go solely with PATCH to get the benefit of reducing unnecessary payload in your update request.
