After doing a bit more research, I stumbled upon this article from which I've pulled some quotes out that I think is helpful for what I want to accomplish (and for any future readers). This offers a way to adopt a reactive programming model over an imperative programming model.
Event-sourcing
The idea here is to represent every application’s state transition in
a form of an immutable event. Events are then stored in a log or
journal form as they occur (also referred to as ‘event store’). They
can also be queried and stored indefinitely, aiming to represent how
the application’s state, as a whole, evolved over time.
What this helps accomplish is that if a microservice goes down yet other events pertinent to it are being published and events are consumed by, say, other instances of that microservice, when that microservice comes back up, it can refer to this event store
to retrieve all the events that it missed during the period it went down.
Apache Kafka as Event Broker
Consider the use of Apache Kafka which can store and dispatch thousands of events per second and has built-in replication and fault-tolerance mechanisms. It has a persistent store of events which can be stored on disk indefinitely and consumed at any time (but not removed) from the Topic (Kafka's fancy queue) were delivered to.
The events are then assigned offsets that univocally identify them
within the Topic — Kafka can manage the offsets itself, easily
providing “at most once” or “at least once” delivery semantics, but
they can also be negotiated when an event consumer joins a Topic,
allowing microservices to start consuming events from any arbitrary
place in time — usually from where the consumer left off. If the last
consumed event offset is transactionally persisted in the services’s
local storage when the usecases ‘successfully complete’, that offset
can easily be used to achieve an “exactly once” event delivery
semantics.
In fact, when consumers identify themselves to Kafka, Kafka will record which messages were delivered to which consumer so that it doesn't serve it up again.
Sagas
For more complex usecases where the communication among different
services is indeed necessary, the responsibility of finishing the
usecase must be well recognized — the usecase is decentralized and
only finishes when all the services involved acknowledge their task as
successfully completed, otherwise the whole usecase must fail and
corrective measures must be triggered to rollback any invalid local
state.
This is when saga comes into play. A saga is a sequence of local transactions. Each local transaction updates the database and publishes a message or event to trigger the next local transaction in the saga. If a local transaction fails because it violates a business rule then the saga executes a series of compensating transactions that undo the changes that were made by the preceding local transactions. Read this for more info.
