From the memory-allocation point-of-view, you're right. A pointer variable on a 64-bit architecture occupies 8 bytes, no matter what type of pointer it is.
But the C compiler needs to know more about a variable than its size. An analogy: long
and float
typically both need 4 bytes (so why have different types???), but you surely tell the compiler which one you want because their operations behave differently.
Back to pointers: there is the *
operator for dereferencing a pointer, and the []
indexing operator for relative addressing, and both need to know the pointer type.
For a pointer declared int *pi;
, a statement like double x = *pi / 2
will truncate the division, while with a float *pf;
, float x = *pf / 2
will give you a fractional result. So you surely need to tell the compiler about the pointer type, for some quite important behaviour depends on that info.
And there is pointer arithmetic, e.g. the relative addressing done with the []
operator. If we have
char *pc = 0x12340; // Compiler will complain, as types don't match!
int *pi = 0x12340;
double *pd = 0x12340;
Then, pc[4]
will be the character (byte) you find four characters after the 0x12340
address, being at 0x12344
. But you'll find pd[4]
not at 0x12344
, but at 0x12360
, 32 bytes after the base address, as indexing a double pointer will count in 8-byte steps instead of single bytes. And of course this also applies to all of the pointer arithmetic including the +
and -
operators. So, once again, you need to tell the compiler about the pointer type to allow for correct pointer arithmetic.
One important feature of the C language is that the type information is kept only in the compiler. At runtime, the pi
pointer's 8 bytes in memory don't contain the information that pi
is an int
pointer. It's the compiler that produces different machine code for operations on pointers of different types.
So, if you get a pointer with value 0x123456789ABCDEF0
and no other information, you can't tell if it's a double
, an int
or a function pointer (or whatever else). Only if your compiled code contains a "debug" attachment, you might find the info there that the pi
variable is an int
pointer, and if your 0x123456789ABCDEF0
pointer value comes from that variable, then you know that you have to look for a (4-byte?) int
starting at the address of 0x123456789ABCDEF0
if you want to see the value that pi
points to.
But such a debug attachment is by no means necessary for the program to run, it's just a courtesy for people who want to look inside.
