It depends on what your goal is. If you just want a simple ordering, then you can just an integer column for order
, or priority
, etc. But if you want columns for priority, like a kanban board, you might encode that differently by having for example an M to N mapping of issues
and columns
. In that case, you can also have an order
or priority
for your issue
, so that in can be ordered correctly in the column.
Reordering by the user is a trivial problem. You would simply keep track of the original order of the issue (i.e. the integer value order
); once you know the updated/new order, it’s some basic math to get all issues for that column and update their orders as well. For example, you have these 3 issues in the column named “TODO”:
- “Fix database bug” -
order = 1
- “Fix UI bug” -
order = 2
- “Implement feature” -
order = 3
you could move “Implement feature” to the top and adjust the order values for the other issues in that column to:
order = 1
order = 2
- “Fix UI bug” -
order = 3
So, to answer the root question, it depends on your use case!
But all in all I think most people just use a simple integer column and some basic order-update logic when things get moved around. Note that this requires 1 database record update for every item that needs to have its order adjusted (in the above example, 3 records are updated). However, this shouldn’t be an issue for most relational databases as you could (and should) wrap those updates in a transaction.
