This article states that:
Consistency in CAP actually means linearizability, which is a very specific (and very strong) notion of consistency. In particular it has got nothing to do with the C in ACID
The article goes on to define linearizability with:
If operation B started after operation A successfully completed, then operation B must see the the system in the same state as it was on completion of operation A, or a newer state.
To me, this is very similar to the definition of isolation:
The isolation property ensures that the concurrent execution of transactions results in a system state that would be obtained if transactions were executed sequentially, i.e., one after the other.
Is there any difference between the I (isolation) in ACID and the C (consistency) in CAP?
antonro
  • 249
  • You make the claim that the C for Consistency in CAP has nothing to do with the C in ACID yet don't define the C in ACID to support that claim. Instead you only make claim that the C in CAP means linearizability. So when you say "between the two" It's not clear what you mean because you just talked about 3 different things. Please edit to support your claims. Do this with quotes, not simply links. And make clear which two things you want to know the difference between. – candied_orange May 20 '18 at 13:32
    @CandiedOrange "Do this with quotes, not simply links". I posted **3** quotes. – antonro May 20 '18 at 21:19
  • @CandiedOrange Would you please explain why those don't count, and then, given that those that I base my question on don't count, what type of quotes would "support my claims" (I didn't claim anything, I stated what the article and Wikipedia say). – antonro May 20 '18 at 21:38
0 Answers0
