Suppose I have UI like it:
<script>
  var someFunction(){
    //some code to validate and then send message
</script>
Message:<br>
<textarea></textarea><br>
<input type="button" id="submit" value="Submit" onclick="someFunction()"/>
Which a submit button calls someFunction() to validate and then send messages to server. I know someFunction is not a good name for name, but I don't know which naming principle is better: Should the name be:
1.Relate to which button to use:
var onSubmitPressed(){
2.Relate to the task of the function:
var validateAndSendMessage(){
which one is better?
ocomfd
  • 5,652
It will be good if you give the name same as the action you will be doing. Like if you want to validate and send message to server then the name should be
So whenever if new developer sees your code he will get to know for which purpose this function is written.
  • Yes! Intent should be communicated. But I would go for `validate`, since the function should validate and in case of successful validation, the browser should "submit" aka "send the message" – Thomas Junk May 07 '18 at 10:35
    The main question was stating **to validate and then send messages to server** so I kept such name.. If it was only for validate then we can give the name as `validate()` or `formValidation()` – Sambhaji Katrajkar May 07 '18 at 11:20
