Trying to imagine how you would go about implementing summation (or reduction?) on a parallel architecture and am having a difficult time.
Specifically thinking in terms of WebGL arrays of vectors such as this:
[integer1, integer2, integer3, ...]
Wondering if there is a way to do this in parallel
var array = [ 1, 2, 3, 4, 5, ... ]
var sum = 0
array.forEach(function(number){
  sum += number
return sum
The problem I am encountering is I think mentioned here in this NVidia document on GPU reduction (not quite following):
how do we communicate partial results between thread blocks?
Wondering if one can describe an algorithm that computes the sum of something in parallel, since there is a shared variable that needs to be used somehow (the sum variable). Or perhaps this isn't possible.
Lance
  • 2,537
The short answer is that you don't share the accumulator. You have a separate accumulator for each adder, and start each at 0. The final step is to sum the results.
This generalises beyond arithmetic addition, as a parallel reducer will assume that it's arguments form a Monoid.
Suppose that S is a set and is some binary operation S × S → S, then S with is a monoid if it satisfies the following two axioms:
  • Associativity
    • For all a, b and c in S, the equation (a • b) • c = a • (b • c) holds.
  • Identity element
    • There exists an element e in S such that for every element a in S, the equations e • a = a • e = a hold.
Where S is the set of all values of a particular type, is the operation, and the identity e is the initial value (or alternatively that a default instance of S is e)
Caleth
  • 10,519
  • 35
  • Thank you. I understand what a Monoid is. Wondering what you mean by "You have a separate accumulator for each adder, and start each at 0. The final step is to sum the results." Wondering if that final step must be done sequentially/in parallel, and how that would look (and not sure what the adder/accumulator are). Would love an example such as in WebGL/GLSL. – Lance Apr 25 '18 at 19:08
