Take the following algorithm with two separate sections, and the sections do not influence each other whatsoever (the function is not recursive, as well).
void algorithm(int x)
// This section of the algorithm has linear growth... O(x)
// This section of the algorithm has x * logarithmic growth... O(xlogx)
To determine the algorithm's Big O notation, I did the following:
Algorithm run time approximately = xlogx + x
The greatest term is xlogx, so the algorithm's Big O = O(xlogx).
Is this correct? Or do I need to factor in more information from the two sections of the algorithm. For example, the first section actually performs 10x operations, but in my calculations I only use its O(x) notation.
