I don't have more than 6 months of experience and I am a little lazy . I work on Android platform . I have very good skills in understanding what is happening in general . The problem is that I don't have the experience to read and understand someone elses code (btw I just got a new project which I will develop a new feature in Android) . I would ask for some advice on how to be a good debugger and understand what is happening in detail . I am facing lots of problems reading it. I don't know how to write unit tests also.
    One question at a time please. Assuming it is your code now, rework it to a format that suits you and document it as you go (create headers for all members). Try to get used to some popular style though, that will make life easier. Make sure you understand each member, if you need to rename stuff. – Martin Maat Apr 14 '18 at 14:56
    Unfortunately this site closes question if it is not written well the first time. You haven't even described what kind of problems you are facing when reading it. Have you set up the [Android development environment](https://developer.android.com/topic/instant-apps/getting-started/setup.html) (such as Android Studio, but there are other non-Google options), *according to the language chosen by the project*? Does it compile? Does it run? Does it print log statements to the debug console? Can you interrupt it while it is running, and where does that land at? etc. – rwong Apr 14 '18 at 16:22
  • Regarding unit tests, CandiedOrange's advice about [Model-View-Presenter](https://en.wikipedia.org/wiki/Model%E2%80%93view%E2%80%93presenter) (and similar ones, some of which are registered trademarks of some vendors), is an architectural approach that separates a mobile application into several layers. These layers can be combined as one or separated as multiple projects. Unit tests usually belong to a separate project, but it needs to call into objects and functions which are in the Model and the Presenter layer of the application project. So, CandiedOrange answered the unit testing part. – rwong Apr 14 '18 at 18:18
    @rwong As for similar ones you can substitute UI for view and apply this to the buzz word architectures: [Hexagonal](http://alistair.cockburn.us/Hexagonal+architecture), [Onion](http://blog.thedigitalgroup.com/chetanv/2015/07/06/understanding-onion-architecture/), and [Clean](https://8thlight.com/blog/uncle-bob/2012/08/13/the-clean-architecture.html) – candied_orange Apr 26 '18 at 12:27
    `how to be a good debugger and understand what is happening in detail` -- By gaining experience. You do that by writing and debugging programs. – Robert Harvey Apr 26 '18 at 15:52
  • Well, if the code is not properly formatted, that's the first step. Run a code formatter. It's amazing what comes to light when you just format code. After that, you can look for the entry points and set breakpoints there. Following the execution path is a good way to understand exactly what is going on. – Berin Loritsch Apr 26 '18 at 16:44
  • @BerinLoritsch Personally I hate automatic code formatters. If reformatting needs to be done I'm more then happy to take the time to do it by hand. I know what the code base looks like and what it expects and allows. When I'm done I'm left with code that, at least in one way, I've already touched. Although, it's safer to do that when you have tests. – candied_orange Apr 26 '18 at 18:43
I have more than 20 years of experience and I am profoundly lazy. I work in many platforms.
The way I read and understand someone else's code is primarily with my fingers.
Why yes I am the kid who was always getting told you don't look with your fingers. I am forever touching the signs that say do not touch.
I am fortunate enough to work in a shop where we do tests. When it comes time for me to understand someone else's code I don't just read it. I run it. I test it. I run the old tests for it. The smallest ones I can find. I write new tests for it. I ask questions about it. I challenge the code in every way I can think of. Somewhere in there I find time to read it and laugh at the lies we call comments. Only once I've done all that do I start to think I might understand it. That's when I start to refactor it. I change it to be something other than what it was, while not yet changing what it does. I do this to make adding a new feature easier or to prepare to make an old bug go away. After adding tests that show my intent, I make my changes. I also look for other little changes to make so I can leave it a little nicer than I found it. Then I go do something else, and for a time, forget this code exists.
The ability to do this is WHY I care about tests. Tests help me read code. Tests don't prove your program does what it's supposed to do. They show what it actually does. You have to figure out if that is what it's supposed to do.
When you're new it is so tempting to reach for lazy ways of thinking. One of the most damaging is to focus on mechanics and structure. It is far better to focus on ideas. To help you with this let me teach you a really good pattern to know about when learning your testing. It's called the humble object.
Someone of the mechanical/structural mind set will insist every class, every method, be under test or they'll insist that testing doesn't work and is a waste of time. They'll say that the only good code coverage number is 100% or that code coverage is a pointless unobtainable fantasy. All of which are true, to someone that thinks this way.
The humble object pattern just flat out admits that there is such as thing as hard to test code. This is very healthy to understand. Sometimes the problem isn't you. It's the code the problem demands.
Nothing's completely untestable but rather than throw every magical mocking and reflection trick at the code to test it as-is the humble object pattern expects us to do a little re-architecting. We change the code to separate testable behavior from uninteresting structural glue code that frankly doesn't need testing. Why? Because testing is about understanding code.
This is exactly why views and presenters aren't the same thing. View's, backed by presenters, have had their interesting behavior removed. They are nothing but boring structural code. The interesting decisions are all happening in the presenters. We test the presenters. We don't test the views.
Views and presenters aren't the only places we do this. Anything that has a boring mechanical need to be wired up can benefit from the humble object pattern. Talking to the DB, a service, a chip, a driver, all can end up with this same dynamic. Give them the wiring they need and scrape away any interesting behavior the app needs to exhibit into a nice testable module that proves the behavior is what we need.
In this way you can enshrine any needed behavior in testable code regardless of any mechanical or structural need to create hard to test code. That way you can focus on your real idea.
There are many many things to study to help you develop your testing skills but understanding why not every lump of code is going to welcome your testing efforts, or even needs to, is right at the top of my list.
candied_orange
  • 102,279
  • 197
  • 315
  • One year after I made the question, I'm confirming it. I quit that job. I fixed tones of code, they didn't want to change. They just kept working on spagheti code without fixing a thing. – coroutineDispatcher Jul 12 '19 at 14:50
  • The testing possibility was not an option, there were no separation of conserns and hell lot of static methods, classes, and singletons. Database instance instantiations more than 5 times per class, a total disaster – coroutineDispatcher Jul 12 '19 at 14:51
    @coroutineDispatcher I learn every paradigm I can so I can be effective in anything. But yeah. I feel your pain. Before fixing the code you have to fix the team. Sometimes the team doesn't want to be fixed. – candied_orange Jul 12 '19 at 17:18
This is something that I have to say I don't entirely understand. I have encountered a number of occasions when someone has asked me a question about why something has happened without having actually fired up a debugger and stepped into the code to look.
This is all you need to do for a starting point - open the application, fire up your favoured debugging tool and step into the code. See where it goes, see if you can see the patterns being used.
Once you've got the hang of how your colleague has structured their code (however it is that they have done it), try to write your new feature in a similar pattern, as this will make life considerably easier for the next new developer to come along.
The point here is that you don't have to just read the code - we have the tools that allow you to follow the flow through. Use them.
Paddy
  • 2,623
Reading code
The way I've learned to get better at reading code is often by reading other things. I read blogs, books, and questions and answers here on the various Stack Exchange sites about programming and architecture. It can be difficult to separate the useful bits from the dogma surrounding it, but doing so is extremely useful.
For example, there are rules people mention frequently when discussing software architecture. SOLID, the law of Demeter, design patterns, etc. Each of these ideas are useful to some degree. So learn them and try them out. You will likely find that there are limits where these ideas break down. For example, short functions are generally a good idea. It's easier to understand the flow of control and the logic in a shorter function. But it can be taken to an extreme. I've seen people recommend that no function should be longer than about 3 lines. I have, unfortunately, had to work with code like that and it is actually harder to follow because there's not enough context in a given function. So try these things out and learn where their limits are.
Debugging
For debugging, learning how to use the debugger is a great first step. Be aware that debugger designers are sadists and the user interface for most debuggers are atrocious. If you can use an IDE with a debugger that has a GUI, I highly recommend it. They're not perfect, but they're a step up from using the awful command-line interfaces for most debuggers.
But you need other tools besides the debugger. You need memory watching tools; you need static analyzers; you need profilers, etc. Each one targets a specific set of problems. For example, there are tools for finding memory leaks while running. A profiler will time your code to find which parts are using the most CPU time, etc.
Tools help make the work of debugging easier.
user1118321
  • 4,969
