I have a function that creates a new object by passing to it's constructor integer ids primarily with values of 0. This function is called when saving a newly created record (not an edit).
public class RecordController
private int _recordId;
private int _subRecordId;
private string _xmlData;
private SubRecordA CreateSubRecordA()
_xmlData = LoadXmlData();
ParseXmlData();
return new SubRecordA(
SubRecordTypeId.A // leaky DAL abstraction
0,
0,
_xmlData);
However, the two 0
parameters coincide with private fields that are already initialized to 0
in an Init()
method
private void Init()
_recordId = 0;
_subRecordId = 0;
I'm not sure if it is better to explicitly pass these zero-valued fields to SubRecordA's
constructor instead?
_recordId,
_subRecordId,
_xmlData);
Passing the literal 0
seems more clear as to what the intention is, but also seems to weaken the logic by excluding these fields from it's flow (say for example _recordId
gets initialized with a -1
at some point in the future).
Update
Using Robert Harvey's suggestion to let the default constructor zero out the properties/fields, I created an explicit constructor that takes only the required parameters and calls : this()
public class SubRecordA : SubRecord
public override int SubRecordTypeId { get {return (int)SubRecordTypeId.A; } }
public int ParentRecordId { get; set; }
public int RecordId { get; set; }
public string XmlData { get; set; }
public SubRecordA(string xmlData) : this()
//SubRecordTypeId = SubRecordTypeId.A;
XmlData = xmlData;
