105
I employ a lot of meta-programming to avoid repetitive tasks and build safer-to-use abstractions.
I recently moved to a new job where I am working in a larger team and this worries some of my colleagues, because they do not comprehend it.
I always try to leverage the full potential of the language, but some (not all) of my colleagues perceive that as a risk (some welcome the approach).
I agree it is a problem to write code that nobody else on the team can comprehend. On the other hand we are all professional C++ developers and I think we should aspire to a higher standard than writing C with classes.
My question is, who is right, what should I do?
Clarification: Trying to leverage the full potential of the language, does not mean I throw TMP at every problem. C++ is a toolbox and to me C++ proficiency is about being able to use all the tools from the box and about picking the right one for a particular job.
kamikaze
  • 1,060
  • 40
    This is ultimately opinion-based. Personally, I make it a rule not to use features so complex that they are accidentally Turing-complete - such as C++ template metaprogramming. – Kilian Foth Mar 03 '18 at 11:25
  • 26
    @KilianFoth templates are not "accidentally" Turing-complete. They were always intended to be powerful tools of abstraction – Caleth Mar 03 '18 at 16:05
  • 80
    Code that nobody can understand isn't a higher standard. – speciesUnknown Mar 03 '18 at 16:59
  • 38
    @Caleth Herb Sutter does [call them _accidentally_ Turing-complete](https://www.youtube.com/watch?v=4AfRAVcThyA). Sure, they were meant to be powerful abstraction features, but I don't think they were intended to allow for as arcane, undecidable constructions as Turing-completeness allows. And certainly, their syntax wasn't designed to make such metaprogramming less intransparent then necessary. – leftaroundabout Mar 03 '18 at 17:08
  • Define "higher standard". Does the output of your meta-programming meet criteria of correctness, efficiency, & maintainability? If so, great. If not, then not. – jamesqf Mar 03 '18 at 18:50
  • Related: *[C++ for the Embedded Programmer](https://www.youtube.com/watch?v=A_saS93Clgk)* and *[Kvasir - CppCast. Episode 78](http://cppcast.com/2016/11/odin-holmes/)*. – Peter Mortensen Mar 04 '18 at 13:58
  • SFINAE = *[Substitution failure is not an error](https://en.wikipedia.org/wiki/Substitution_failure_is_not_an_error)*. – Peter Mortensen Mar 04 '18 at 14:16
    False dichotomy. You can program at a "higher standard" and leave behind C with classes, embrace modern C++, use templates (eg the STL) as well as const, no () casting, no pointer arithmetic, value semantics, lots of goodness, without heading ibnto TMP. If you see no daylight between C-with-classes and TMP then you're doing it wrong. – Kate Gregory Mar 04 '18 at 17:12
    "Code that nobody can understand isn't a higher standard.": The OP did not state this, unless I misunderstood the question. He / she said that some colleagues do not understand the code. I think this should be OK in general, as long as at least one or two other members of the team are able to understand the code. – Giorgio Mar 04 '18 at 18:17
  • @KilianFoth: That which makes them turing complete is not very complex; it's one of the basis things one learns in many functional programming languages: pattern matching and specializations. The turing completeness is, IMHO, not what makes them arguable. The property "Turing Completeness" does _not_ imply things like "point of instantiation", "ambiguity resolution", "ADL", "readability" ... I think you are really targetting the wrong language trait here. At last, C++ programmers __use__ _metaprograms_ quite often. Some `` implementations use expression templates, for example. – phresnel Mar 05 '18 at 07:09
    after the edit this question looks like a duplicate of [Does usage of advanced language features decrease maintainability?](https://softwareengineering.stackexchange.com/q/214528/31260) – gnat Mar 05 '18 at 10:14
  • Can you show some code examples? It's hard to know what you mean by metaprogramming – ACV Mar 05 '18 at 15:17
  • One of the most important qualities of good code is readability – ACV Mar 05 '18 at 15:18
  • @gnat They are similar but I find still different. The other one is about code readability and this one is about whether advanced features should be prohibited because of team members who don't (want to) understand them. – t3chb0t Mar 06 '18 at 08:12
  • "I think we should aspire to a higher standard than writing C with classes" - I think that is not a decision for you to make on your own! The whole team should agree on this. – Thorbjørn Ravn Andersen Mar 06 '18 at 08:53
  • @leftaroundabout What do you mean by "undecidable constructions as Turing-completeness allows"? Problems (or sets) can be undecidable, but not programs, so decidability has nothing to do with Turing completeness. – Cedric Reichenbach Mar 06 '18 at 14:04
  • @CedricReichenbach Turing completeness allows you to define a template that can only be instantiated with some particular types (short of sending the compiler in an infinite loop or something), with the set of these types being undecidable. – leftaroundabout Mar 06 '18 at 14:15
  • Username checks out. – Eternal21 Mar 06 '18 at 18:21
  • This might be an opinion to consider: https://hackernoon.com/why-senior-devs-write-dumb-code-and-how-to-spot-a-junior-from-a-mile-away-27fa263b101a – Dan Jones Jun 19 '18 at 20:14
10 Answers10
189
Metaprogramming is OK. What you are trying to do is not OK.
I use metaprogramming all the time in my job. It's a powerful tool which can be used to do a lot of things in a more readable and maintainable way. It's also one of the harder to comprehend styles of programming out there, so it really needs to earn its keep. I like it when I can reduce 1000 lines of code to 50, but I try to limit it as such.
The issue is not metaprogramming, but this:
This is where you get in trouble. You have an opinion. It's fine to have an opinion that metaprogramming is good. It's fine to have an opinion that we should all aspire to be better C++ developers.
It is not fine to compel both your collegues and future hires who will have to maintain the code you wrote to agree with your opinion. That is your boss's job. Your boss is the one who should be concerned with making sure that your code is maintainable in the long run. They (hopefully) have much more buisness experience, because believe me when I say it's a business decision, not an ideological decision.
It is fine to want to metaprogram. It is fine to want to teach others to metaprogram. But understand that it's also fine for others to choose not to learn to metaprogram, and that will be true until you are in a position of power. (and, as an industry secret: when you finally are a lead developer, in a position of power, you're not in a position of power at all. There's someone controlling the pursestrings who is in power).
If you want to encourage them to be okay with metaprogramming, start small. Start with a single enable_if that makes the API easier to read. Then comment the daylights out of it. Then maybe find one case where a template metafunction turns 10 large repetitive classes into 1 class with 10 little helpers. Comment the heck out of it. Get feedback. Find what people think about it. Be fine if they tell you not to do it. Find a niche where metaprogramming earns its keep so thoroughly that your collegues all (begrudgingly) agree that it was the right tool for the job.
As a short story, I wrote a beautiful library once, using extensive metaprogramming. It did exactly what we needed at the time, when no other approach could get remotely close. It actually changed the direction of the application I was writing in. But it was metaprogramming. Only one or two other people in my entire company could read it.
Later, my colleague took another stab at the problem. Instead of leveraging metaprogramming to precisely do what was needed, he worked with leadership to relax the constraints that had been put on the problem such that metaprogramming was not needed. Perhaps more accurately, metaprogramming was less needed. He was able to confine it to what metaprogramming does best.
The resulting library is now in a position to be used in a remarkably wide market, and that's certainly in no small part due to the fact that the new code can be maintained by a far wider range of developers. I'm proud of paving the way with metaprogramming, but it's my colleague's code which is going to reach the wider audience, and there's good reasons for that.
Cort Ammon
  • 10,840
  • 32
  • 79
    Replace "metaprogramming" with some other style, technique, technology, library, and the answer is still great! – Andrejs Mar 03 '18 at 21:55
    _Your boss is the one who should be concerned with making sure that your code is maintainable in the long run._ Most bosses don't even know what code maintainability is. They have virtually no technical knowledge so I wouldn't trust their decisions which have rather a political character. – t3chb0t Mar 04 '18 at 11:27
    @t3chb0t: An _experienced_ boss knows how much money should be spent on customer service (i.e., bug fixing and new features) and how to minimize that cost. Maintainability is the most powerful tool for that purpose. That boss may not know technical details but should be able to build up a team that can be trusted on that point. – mouviciel Mar 04 '18 at 12:22
    While there is good advice in your answer, I feel the overall tone is too much "dumb down the code so the least skilled teammember can maintain it", which is bad advice IMO. – D Drmmr Mar 04 '18 at 13:32
    @DDrmmr I did set the tone for someone who believes programmers should be using metaprogramming in order to raise the standard. I don't think it should be dumbed down to where the least skilled teammember can maintain it. It should be dumbed down to where the *team* can maintain it, and perhaps even stronger, it should be dumbed down to where the team can maintain it *without you*. Otherwise one is writing onesself a job. – Cort Ammon Mar 04 '18 at 15:00
  • @DDrmmr, +1 to Cort. It's also worth noting that if the *team* can't maintain it... who can? For example, my team is about to go into maintenance mode for a sprint due to my upcoming vacation. That's not a position we want to be in long term - not in least because it puts unnecessary stress on peoples vacation time. – NPSF3000 Mar 04 '18 at 15:03
  • I feel there is something fundamentally wrong with this answer. I have faced too many cases of write code that I alone understood or fail hard. Suffice it to say it was either write code that nobody else understood that didn't need maintenance and provided behaviors support could understand or write code that needed constant support because it was too brittle. – Joshua Mar 04 '18 at 23:08
    @Joshua What I have found is that there does not exist such a thing as "code that doens't need maintenance." – Cort Ammon Mar 05 '18 at 00:18
    But I have modules in production that haven't changed in years because encapsulation was done correctly. – Joshua Mar 05 '18 at 01:01
    @Joshua Then consider yourself lucky, or that you did a good job. Just shy of two decades after I wrote code, the environment my software operates in has shifted enough that what was once the correct encapsulation is no longer the correct encapsulation, and we now have new-hires who have to pick the code up and work on it. – Cort Ammon Mar 05 '18 at 02:22
    Who, as a developer, actually has a boss whose opinion on a technical matter ought to override their own? I don't accept the premise that it's at all common that one's boss ought to have the technical aptitude to make an informed decision in/out on template metaprogramming. – Tom W Mar 05 '18 at 13:13
  • @TomW You're making a wrong assumption. The boss doesn't need the technical aptitude to make an informed decision. What the boss needs is the ability to ask the experts for all the consequences of deciding one way or the other and then they should make a decision based on all the information they have available to them. If decision makers always had to understand the technical details behind everything, nobody could ever be a CEO. – Cronax Mar 05 '18 at 14:20
  • @TomW And the reality is, that nothing we do is *completely* technical. Everything is shades of grey in business, once we strip away illusions. That's why it's a really good idea for your boss to come to you for estimates, even though he's making what, on the surface, is simply a business decision. Likewise, there's a little shred of business in every decision we make as developers. – Cort Ammon Mar 05 '18 at 15:53
  • If you code doesn't require maintanence, it likely isn't being used. :-) – Nick Keighley Mar 07 '18 at 09:18
  • Basically you wrote about all the implied issues that make me ask the question in the first place. Good job! – kamikaze Mar 13 '18 at 10:21
  • @CortAmmon: wonderful answer. I hope you have a job that pays buckets of [insert local currency]. – Rethunk Mar 24 '18 at 12:48
40
First and foremost, this is the team's issue, and you have to solve it with the team. If you have backup from the team for programming using certain elements and constructs, do it; if not, discuss it with them and if you cannot convince them and make a strong case why "your approach" is clearly better, you will be better off not to use it.
Note that using template meta-programming in C++ is always a trade-off: sure, it can sometimes help to design certain parts of an application more DRY, and it is definitely helpful for creating highly efficient and highly reusable libraries.
On the other hand, these benefits come at a certain cost: the code gets more abstract, often much harder to read, much harder to debug and much harder to maintain. This makes the usefulness of meta-programming in application programming often questionable. So, assuming you are not going to create the next STL, every time you are tempted to use meta-programming, ask yourself if those drawbacks are really worth it. And if you are unsure, discuss this with your peer reviewer during code review.
Toby Speight
  • 550
Doc Brown
  • 199,015
  • 367
  • 565
  • I agree but discuss it with QA before you put it in code. No sense in creating something that will be rejected. – shawnhcorey Mar 03 '18 at 12:12
    How about: "I agree. But..." Changing it to "to" completely changes the meaning. One should always discuss something unusual with QA before time is spent on it. You stated that this discussion should take place at the code review, after the time is spent. – shawnhcorey Mar 03 '18 at 16:08
  • @shawnhcorey: sure, if "QA" in your organization is responsible for coding standards. However, this is IMHO not the typical "QA" role - in most organizations I know, the term "QA" refers a group of people who do quality assurance in a black-box manner, not responsible for which elements of a programming language should be used and which not. Those people are seldom qualified enough in programming to discuss such details. – Doc Brown Mar 05 '18 at 12:06
  • QA is a generic term like HR. And the quality of the personnel in QA vary as much as those in coding. – shawnhcorey Mar 05 '18 at 12:27
  • @shawnhcorey: so you would discuss this topic about template meta programming with QA people even if they don't know anything about C++? – Doc Brown Mar 05 '18 at 12:37
  • The point is they _should_ know about C++ and template meta-programming. How can QA judge the quality of the code if they know nothing about coding? – shawnhcorey Mar 05 '18 at 13:03
    @shawnhcorey: that is exactly my point, the QA role varies heavily in different organizations. In lots of organizations, QA people have no idea of programming, so they are probably not the right ones to discuss such a topic. – Doc Brown Mar 05 '18 at 13:11
  • They are the right ones because without their approval, your code won't see production. – shawnhcorey Mar 05 '18 at 13:32
    @shawnhcorey: well, on one hand you wrote "QA is a generic term" - on the other hand, you have a very specific QA role and responsibility in mind - sounds a little bit contradictory to me. – Doc Brown Mar 05 '18 at 13:44
    I have never encountered a QA person who knew anything about programming. – Nick Keighley Mar 07 '18 at 09:21
19
My general opinion: if you have a choice, as is often the case, between the following three options:
  • Type out many nontrivial code structures repetitively by hand;
  • Use C++ template metaprogramming to automate code generation;
  • Use some other code generation mechanism, such as macros or some other programming language to generate C++ source files
then template metaprogramming, done properly, will likely be the most readable and maintainable of the three options. This is the argument that I would make to the team, if I were in your position. Examples with actual code would help convince them.
When you use Template Meta-Programming(TMP) to avoid repetition, you should use it to construct well-documented, carefully tested abstractions that localize the complexity within the TMP code, making it easy to write correct client code. This is the design of the C++ standard library.
I do not think that we can judge who is right or wrong without seeing an example of the type of code you're trying to write.
user1118321
  • 4,969
Brian
  • 617
Software developers should aspire to write code that works, that works obviously, that can be tested, that can be reviewed, that can be debugged, and that can be adapted when changes are needed. If writing "C with classes" achieves this, then it is just fine.
And these are the standards that you should measure your code against. Especially: Does it work obviously, can it be tested, can it be reviewed, can it be debugged, and can it be adapted when needed?
gnasher729
  • 42,090
  • 59
  • 119
An argument from compassion:
Does your job give free time for learning, or in alternative, can you convince your bosses to allocate some hours for learning these language features?
If not, using those is essentially giving them extra unpaid work. You may think that a C++ programmer should know the whole language, or something like that, but an academic point doesn't relieve the burden you'll be imposing on them. Your colleagues have kids, ailing parents, sick spouses - or hell, just a reasonable social life that doesn't involve learning C++. The more vocal opponent of your proposal may be lazy - or they may be going thorough a rough time and doesn't need extra shit in their life right now.
André Paramés
  • 343
Code should be written firstly for humans to read, and only incidentally for the compiler to parse.
Now the thing to remember about non trivial TMP is that you are restricting the number of people who can read that code, it can be a valid tradeoff, but I would argue is far more of a reasonable tradeoff in libraries and such where you have a small specialist team of experts then it is in a bigger application.
When you pull out all the tricks in the book you impose costs on everyone else in that they now need to understand the language including all the lawyerly corner cases that you have exploited, you also impose a cost on hiring in that you have raised the bar to work on the application in a useful way, now maybe that is worth it, but do watch the costs....
For me, a bit more typing, maybe even some code duplication, but that I can put in front of Mr "C with classes plus STL" when it needs modification is a lot more useful then some incredibly elegant TMP thing that only I can maintain (And will therefore be forever maintaining). Remember also that the C with classes guy might happen to be the subject matter expert, and that expertise is usually a lot more valuable then being a language lawyer.
I forget who said it but "Everyone knows that debugging is harder then writing it in the first place, so if you program it as cleverly as you can, how will you ever debug it?".
Even if I can write really out there modern C++ I usually prefer not to, it means I have to do less of the maintenance programming.
Dan Mills
  • 642
No you should not. You are employed to produce code that satisfies a specification. This code has to be maintainable not an ego trip. You could be run over by a bus tomorrow, so someone has to be able to pick up your code and progress the task in hand. However, it is positive to try to convince your employers to incorporate new techniques into their programming standards.
    _You are employed to produce code that satisfies a specification._ yes, but you are forgetting that also _to the best of knowledge_. – t3chb0t Mar 04 '18 at 17:10
The only way to answer this question in context is to look at the specific problems and the specific way you solved them with meta programming. Unless you post code here we cannot know whether you indulged in an unnecessary complication which is fun for you alone "solving" a non-existing problem; or whether you employed the full power of the language to write a simple, elegant solution not available by other means.
If it is the latter, I would encourage you to continue doing so together with your team. Every good team must do meaningful code reviews which discuss not only style issues but also whether the programer's solution uses the best approach, uses the appropriate language features, is maintainable and testable etc. Your meta programming solution should fill one such review session, likely a whole afternoon. The programmers who reject your approach should lay out alternatives (like code generation with perl, code duplication etc.) and show how it performs against the criteria mentioned, compared to your solution. Your job, as their friendly "opponent" in the argument, is to show that it is a way to get the job done fast, that maintenance is easy, testing is easy, and the code is actually readable once you get past the hurdle of parsing the funny grammar. (If you are strategic you may show it to a friend in the office beforehand and convince him or her that it's really cool; that will help you in the discussion because you won't be alone.)
Most programmers are lazy and enjoy elegant, small solutions. If yours is one, chances are you can convince them, especially if the alternatives demonstrated fall short.
There is not a single correct answer to this question.
Because the first thing you should ask yourself is: in what situation are you placed by your employment? Some people are indeed employed as code monkeys to code up specifications, others are employed as team players, others are employed as knowledge workers or experts.
The only constant bottom line is that you need to look at it from the perspective of your employer, since essentially this means to be an employee. Sometimes it is in the best interest of your employer indeed to nudge your colleagues to become better and master advanced techniques. Yet in a different situation, you might just create lots of problems and liabilities and endanger the success of the projects you're involved in.
Ichthyo
  • 301
The question isn't really about whether meta-programming is OK or not, but rather about whether it's OK to be better than the others on the team so here are a few controversial points about how I see it...
I recently moved to a new job where I am working in a larger team and this [meta-programming] worries some of my colleagues, because they do not comprehend it.
They are worried that you're better then them. That's good. You're going to be the new expert. You just destroyed their status-quo world.
Sure, nobody likes to be less skilled than anyone else, so they are trying to stop you from using techniques that are too complex for them. They either cannot comprehend it or are not going to, because they feel secure now.
I don't. I think it's showing your expertise.
You should use all your skills to write the best code you can write and don't look behind at those who don't understand it. Otherwise you'll get stuck on their level and be just an ordinary coder. It's a good thing to be better than others, and it's a good thing to strive to be better than them. You'll never gain any new experience if you don't try to use anything new or do things differently.
I know I'm going to be downvoted, but this is how it looks like. It's not a crime to be better than others on the team, and it's not a crime to use your skills. It's just that everyone is afraid to admit it... because they are on the non-skilled side and hate it that the new guy suddenly can do something they can't. If they were clever, they'd ask you for help and for advice and not criticize your code for being incomprehensible.
EDIT
There seems to be a lot of confusion about this question. As the comments show many people think it's about general code readability. No, it's not. It's about whether certain language features/constructs should be forbidden or avoided because some team members don't understand them.
My answer is no. They should not be forbidden. If you want to forbid something how would you do that? You'd have to prepare some kind of a questionnaire to find out what your team members can and cannot - or rather don't want to learn as I think all languague features are useful somewhere so knowing them and being able to use them is always good and the more you know the better code you can write. You'd also need a scale to define which features are beginner, intermediate or advanced ones.
In order to demonstrate how silly such restrictions are, let's take a really simple example: you are going to be hired as a software engineer but your future boss tells you that you will not be allowed to use do/while loops because there are a couple of people on the team that have never used them before and also are not going to because they have always been using for loops for everything so they find do/while loops confusing.
Now you think this is stupid and crazy, don't you? But so is forbidding other features. Some poeple can use them and others don't want to learn them.
Why should you produce worse code if you know there is something that allows you to do the same with much less effort and yet result in a much more readable are robust code?
And it doesn't matter wheter you use only basic language features or advanced ones, you can use either one to produce an equally incomprihensible and unmaintainable code so this is an entirely differen topic.
t3chb0t
  • 2,515
    This answer is horrible. Meta-programming does not imply supremacy _and_ vice versa – polfosol Mar 04 '18 at 14:04
  • @polfosol well, this question isn't about meta-programming at all. – t3chb0t Mar 04 '18 at 16:30
    The question is not so much about whether it is okay to be better than others, but whether to produce code no one else can understand. Showing off is okay in your private hobby project, but not so much in a corporate setting. (Depending on your corporate culture it still might pay off, but it is not good for the company.) – Paŭlo Ebermann Mar 04 '18 at 19:23
    In my experience, anyone who feels strongly that they have a significantly higher level of expertise than the rest of their team has actually fallen victim to the Dunning-Kruger effect. That's not to say that some people aren't *much* more skilled than others, or that *in this case*, the rest of the team isn't in fact incompetent... but a true expert will always focus on simple code and big-picture engineering (including accounting for team effects over time) rather than just programming for style points. – Daniel Pryden Mar 04 '18 at 21:20
    @PaŭloEbermann this isn’t about showing off. It’s about leveraging the tools at hand to the best of your ability and *raising the bar* for the rest of the team. – RubberDuck Mar 04 '18 at 21:40
    @RubberDuck: "*It’s about leveraging the tools at hand to the best of your ability and raising the bar for the rest of the team.*" This presupposes that not using metaprogramming represents a lower bar. I'm neither a proponent of nor a critic of metaprogramming. But I have serious doubts that employing metaprogramming a priori raises any bars with regard to the quality of the resulting code and/or programmers who know it. – Nicol Bolas Mar 05 '18 at 05:05
    Writing code that others can't read doesn't prove that you are better than them. It proves you can't write readable code. – Stig Hemmer Mar 05 '18 at 09:03
    @StigHemmer apparently you did not understand the question and you are changing the topic. It's not about non-readable code but about code incomprehensible for others due to their lack of knowledge. – t3chb0t Mar 05 '18 at 09:07
    @t3chb0t My point was that these two are the same thing. – Stig Hemmer Mar 05 '18 at 10:55
    @StigHemmer you are so wrong... complex and advanced code can still be hundred times more readable than a console application written by a beginner who only knows a couple of basics. – t3chb0t Mar 05 '18 at 10:59
    @t3chb0t - while that is true, you seem to have missed the point, which is that if code isn't readable *by the people who need to be able to read*, then it is badly written. Knowing your audience is critical. And "raising the bar" isn't a problem... as long as you do it gradually and carefully. Simply dropping a whole load of code that they won't understand on them isn't a good way to do that. – Jules Mar 05 '18 at 15:11
    @StigHemmer I have seen all of these called "too clever" at one time or another: pointers with more than two levels of indirection, pointers to pointers, *any* pointers, bitwise arithmetic, *arrays*, and constructs of the form "if (a && (b || c))". Those are ordered roughly by how long ago I first saw the claim. Assuming that when someone doesn't understand your code, the fix isn't for them to learn to program better, but rather for you to write simpler code, has *consequences* in the long run. If the OP's colleagues don't understand metaprogramming, this is an opportunity for them to learn. – Ray Mar 05 '18 at 16:37
  • It actually depends on my colleagues motivations and I think their concern is shipping a good product, so your answer is not the right one in this case. I'm writing firmware for machine parts, and these people who do not care about correctness and safety exist and ultimately risk human lives with their negligence and they must be purged. So I gave you an upvote against the general trend. – kamikaze Mar 13 '18 at 11:03
