I have a class that handles the state of a response, called StockResponse. The code has multiple ifs to handle each state of the stock. Most of the cases has a default behaviour, but some conditions need additional if-else inside to handle correctly the response. The conditions are becoming hard to maintain, and looks bad to have a huge method with many if-else conditions.
I am guessing which will be the best way to handle them. Code now looks like this:
public Result ProcessStockState(StockResponse response)
   if(response.state==StockStateEnum.Ok)
       if(response.Sender==Sender1){ /* code....*/ }
       else if ( response.Sender==Sender2){/*code ...*/ }
       else {/**default handling code...*/}
   else if(response.state==StockStateEnum.Unkown)
       if(response.Sender==Sender5){ /* code....*/ }
       else if ( response.Sender==Sender7){/*code ...*/ }
       else if ( response.Sender==Sender10){/*code ...*/ }
       else {/*default handling code ...*/}
   else if(response.state==X)
       /*Multiple conditions that ussually differ from the other ifs*/
       /*It always have a default behaviour*/
Which design/pattern you would recommend me to avoid that cascading if-else ?
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
X.Otano
  • 612
    Possible duplicate of [Approaches to checking multiple conditions?](https://softwareengineering.stackexchange.com/questions/191208/approaches-to-checking-multiple-conditions) – gnat Mar 01 '18 at 08:20
    Possible duplicate of [How to tackle a 'branched' arrow head anti-pattern?](https://softwareengineering.stackexchange.com/questions/205803/how-to-tackle-a-branched-arrow-head-anti-pattern) – Doc Brown Mar 01 '18 at 08:39
    see also: [Elegant ways to handle if(if else) else](https://softwareengineering.stackexchange.com/questions/122485/elegant-ways-to-handle-ifif-else-else) – gnat Mar 01 '18 at 10:48
  • I don't like the State pattern (GoF) because it's fragile when you add new transitions, but you could use it. There are also many ways to hande state transition code that are not OO (table-based, etc.) which have been around a long time and are very maintainable. – Fuhrmanator Mar 01 '18 at 16:22
  • https://stackoverflow.com/questions/5923767/simple-state-machine-example-in-c is related, since you're dealing with a design for state machine logic. – Fuhrmanator Mar 01 '18 at 16:24
    If you only have three else ifs, I don't think it's worth it to try and change it to something else. – Robert Harvey Mar 02 '18 at 04:36
6 Answers6
The problem with if/else chains is that they are inflexible and tightly couple that class with any implementations used if any.
For a dynamic approach, I would recommend the same solution that I mentioned in this answer.
Basically, you create a set of response handlers and a response manager. The last is in charge of dispatching the response to the proper handler.
The solution relys on polymorphism. All the handlers should implement an interface (IStockResponseHandler) with two methods:
  • bool CanHandle(StockResponse response)
  • Result Handle(StockResponse response)
Then, you initialize the StockResponseManager with a list of IStockResponseHandler instances.
Finally, once you get a response, you need only call the StockResponseManager.getResult(response) in order to get the proper result.
As I also mentioned in my linked answer, the benefits are future-proofing. You allow yourself to handle new types of responses with little to no additional work in your project and without adding yet another static if condition to your if/else chain. If you loaded rules from a database, you could in theory dynamically handle responses without making any changes in your program whatsoever.
As a general rule, I would create one IStockResponseHandler class per Result type. In other words, two conditions may result in the same returned Result value, and in this case it should be handled by the same class, not two separate classes. In your example I'm thinking that would be a class for each possible response.state value.
Laiv
  • 14,283
  • 69
Neil
  • 22,670
  • 45
  • 76
  • Good idea if you have many different types of response states (the implementation of a single handler is straightforward, and adding new ones easy), but don't you think it could be an overkill for simpler situations? Do you have any guidelines *when* if would begin to pay off? – Mael Mar 01 '18 at 08:13
    @Mael OP asked for a more handy design. If we're assuming OP is happy with his current design, there would be no need for an answer. Though admittedly if you have no reason to think the if else chain would grow beyond 3 in the future, this solution would be a bit overkill, yes. OP clearly thinks this is a code smell, and I prefer not to discourage that thinking. If/else chains should at least be considered for change. – Neil Mar 01 '18 at 08:56
  • I'm not personally a fan of the idea of things called managers but I still give this my vote because I am too lazy to type up a separate answer and I think this covers the idea enough. I personally would go with a chain of responsibility. That's the first thing I thought of. Each outer if is a link in the chain, and even the inner if-else blocks can be chains if you want to go crazy, the outer chain links are then a link composed of a chain. Polymorphism and OOP to the max! – Hangman4358 Mar 02 '18 at 14:32
  • @Neil The solution you suggested very much reminds me of the Chain of Responsability design pattern. – MMalke Oct 18 '20 at 21:49
    @MMalke It is similar, though you have more control on how to handle multiple handlers, whereas chain of responsibility design pattern will halt execution of remaining handlers. I suppose in the case of OP's question, that chain of responsibility would do just fine as well. – Neil Oct 21 '20 at 07:02
There is no particularly complicated pattern I would use. Just break up the top-level alternatives into individual methods like ProcessOKResponse(), ProcessUnknownResponse() etc. and leave only the dispatch logic in the entry point method.
You can later transform the big switch, e.g. into a lookup table, or into dynamic dispatch via inheritance, or something else, but the important thing is to reduce the amount of decisions taken in one block of code. Refactoring to smaller methods is the key to that.
(Example pseudo code for a method lookup table:
handlers = [
   OK: handle_ok,
   unknown: handle_unknown,
   backorder: handle_backorder
def handle_ok():
def handle_unknown():
def handle_response(response):
  handlers[response.state]()
Example code for dynamic dispatch:
class OKResponse:
    def dispatch():
        if condition1:
            action1()
        elif condition2:
            action2()
        else:
            action0()
class UnknownResponse:
    def dispatch():
def handle_response(response_object):
    response_object.dispatch()
Kilian Foth
  • 107,706
  • 45
  • 295
  • 310
  • Thanks for your answer. What do you mean by lookup table or dynamic dispatch? Can you explain it a little bit ? – X.Otano Mar 01 '18 at 07:56
Think about factoring the second-level ifs to separate functions. For example handleResponseOK() and handleResponseUnknown(). Then, your code will look like this:
        handleResponseOK(response);
        handleResponseUnknown(response);
        handleResponseX(response);
When you have to make a decision, you still have to put the logic to make it somewhere and if you need more than one if... well, there's no escaping that.
Sure you can dress your code in fancy design pattern-branded clothes, but do you really need to? Maybe just good old refactoring will suffice if you just need to reduce the indentation, and don't want to code elaborate constructions to hide your ifs.
Mael
  • 2,305
  • 26
Considering that the main method is returning Result, you can simplify else if statements with just if + return.
And as many other guys suggested obviously it makes sense extracting if statement bodies into a method.
I guess it could look something like this:
public Result ProcessStockState(StockResponse response) {
   if(response.state==StockStateEnum.Ok) {
       return handleResponseOk();
   if(response.state==StockStateEnum.Unkown) {
       return handleResponseUnknown();
   if(response.state==X) {
       return handleResponseX();
   return defaultResult;
the same approach you can take in handleResponse methods.
xagaffar
  • 131
Polymorphism is technique that can help you achieve what you need. It helps you decouple the code as well and make your code more scalable for future. Here is my implementation of the technique that breaks the if-else condition.
Create a dictionary with all the StockResponseHandlers i.e Ok,unknown,etc..
        StockEnum stockEnum = response.state;
        Dictionary<StockEnum, IStockResponseHandler> dictionary = new Dictionary<StockEnum, IStockResponseHandler>();
        dictionary.Add(StockEnum.Ok,new StockResponseOkHandler());
        dictionary.Add(StockEnum.Unknown, new StockResponseUnknownHandler());
        dictionary.Add(StockEnum.X, new StockResponderXHandler());
        if(dictionary.ContainsKey(stockEnum))
            IStockResponseHandler stockResponseHandler = null;
            dictionary.TryGetValue(stockEnum,out stockResponseHandler);
            stockResponseHandler.Validate(response.Sender);
Note: the last statement sends the ISender to the respective Handler
Ok Handler and other handlers would look something like this :
public class StockResponseOkHandler : IStockResponseHandler
    public StockResponseOkHandler()
    public void Validate(ISender sender)
        sender.WriteSenderSpecificCode();
You can write seperate code for each sender in their, below it is for sender 1
using System;
namespace ChainReactionWithInterface
    public class Sender1Handler : ISender
        public Sender1Handler()
        public void WriteSenderSpecificCode()
            Console.WriteLine("Called 1");
So we have decoupled all elements and at any point of time, we can add new conditions and it will be scalable. The only drawback i see in this technique is initialization of classes.But maybe there are other of optimizing it for good by lazy loading or some sorta thing.
vin
  • 267
Using Java enum pseudocode:
public enum StockStateEnum {
    OK(
        public void process(Response response) {
    UNKOWN(
    public abstract process(Response response);
    public static StockStateEnum findByState(Response response) {
      // Loop through enum values trying to find a match
      for (StockStateEnum stockState : StockStateEnum.values() {
        if (stockState == response.state) {
          return stockState;
      return StockStateEnum.DEFAULT;  // Or null, depending on requirement
Usage:
  StockStateEnum stockState = StockStateEnum.findByState(response);
  stockState.process(response);
My guess is you could do something similar with response.Sender reducing even more the number of if statements and cyclomatic complexity.
ootero
  • 111
