I was really glad that ES6 introduced the let keyword for defining variables. var scoping rules can lead to all kinds of issues, especially when working with loops and event handlers. Even when programmers used var in the past, they still almost always expected let scoping rules.
Variables declared with var are available in the entire function. Variables defined with let are only available inside the block where they are declared.
However, var's scoping rules are also useful sometimes, though very rarely. Here is an example: (imagine all of these examples are inside a function, I don't intend to define globals here)
try {
    var result = mightThrowAnException();
    //do various things
finally {
    if (result) cleanup(result);
//do other things
callSomeFunction(result); //reference result
return result;
In the above example, replacing var with let would cause an error. In order to use let, one would have to write a function like this:
let result; //declare the variable outside the braces
try {
    //do various things
finally {
//do other things
return result;
I honestly think writing it this way isn't any better. It feels worse when you have to predefine more variables like these, just because they're declared in a try block.
In TypeScript, there is the additional annoyance that you have to explicitly declare the type of result if you want to predefine it in this way. If you initialize it, the type will be deduced automatically.
Is it a good idea to use var instead of let to take advantage of these scoping rules, when in almost every other part of your code you use let?
Grant Miller
  • 143
GregRos
  • 1,723
    Possible duplicate of [Is there any reason to use the "var" keyword in ES6?](https://softwareengineering.stackexchange.com/questions/274342/is-there-any-reason-to-use-the-var-keyword-in-es6) – Robert Harvey Feb 08 '18 at 18:02
    In any case, I think your second example is the preferred way to do it. Most other languages will not allow the `var` variation to work, so it violates the principle of least surprise. – Robert Harvey Feb 08 '18 at 18:04
Usually in these types of questions, I refer the ESLint for guidance as they explain very plainly why the rules are as they are, take a look at no-var rule.
The main reason is for readability. the behaviour you are referring to is hard to read and track and here is an example .
Also, the second snippet of code is by far easier to track and debug, and defining the variable in the correct scope (first example the var is used outside the scope of definition, which is misleading and can cause problems like shadowing ).
Daniel Dror
  • 151
