No, there is no nor
operator in any high level mainstream programming language.
Why ?
Mainly because it is difficult to read:
- it requires the mental combination of several operators ( "and not", or in a more literary style : "further negative", "each untrue")
- it implies an implicit
not
on the first operand, but the reader only understand this afterwards
- it is different from human languages, which use an explicit negation on the first operand, such as "neither x nor y", "nor x nor y". So a reader might confuse
(x nor y)
with (x and not y)
instead of ((not x) and (not y))
- some readers are confused with the apparent
or
semantic which doesn't apply
But it's so common in hardware...
nor
is an elementary hardware gate that can be used to make all the other logical gates. So one could argue that all the other logical operators are combinations and nor
is the simplest elementary logical operator.
However, what's true for the hardware is not necessarily true to the humans. And despite it's popularity at hardware level, some mainstream CPUs do not even offer a NOR
in their assembler instruction set (e.g. x86).
Alternatives
Readability matters. And sometimes it can be improved by other means.
Use of existing operators
For example:
if x not in [1,2] // use of 'in' or 'not in' operator instead of x!=1 and x!=2
Ordering of conditions
if x==1 or x==2
action A
else
action B
instead of
if x!=1 and x!=2
action B
else
action A
Use of until loop
Some languages also offer loop instructions that allow to express conditions either with while
or with until
, letting you choose the more "positive" way. These instructions are for example until c do ...
in ruby, do until c ...
in vb, or repeat ... until c
in pascal and its descendants.
For example:
Until (x==1 or x==2) do
is equivalent to:
While (x!=1 and x!=2)
Make a function
Now if you still prefer the nor
syntax, you could define a function, but only if you don't expect a shortcut to happen:
If ( nor(x,y) ) // attention, x and y will always be evaluated
There is a readability advantage of the function over the operator, because the reader immediately understands that the negation applies to all arguments. In some languages you can define a function with a variable number of arguments.
