I've been programming professionally for years now at several different companies and I consider myself to be a fairly competent programmer. However, of everywhere I've worked there are usually dozens of different software engineers and programmers with dozens of different coding styles, and patterns. I've read tons of literature on the subject of well designed applications, but I honestly don't think I've ever seen or fully implemented one myself. I'm curious if there are any real hands on examples of different design principles, especially applications implementing a proper service architecture to really get a feel for everything.
For example, our current application began with many different conflicting design ideas, but most of the original engineers have been let go. Now, I pretty much have free reign with a whole swath of very novice developers in which to help train and educate as they begin their careers. I'm trying to set a positive example by implementing easy to follow, but still robust designs.
As our application stands today we have somewhat of a legacy area and the new area. The legacy area consists of:
- A repository layer (built with ADO.Net), but it's pretty tightly coupled and near impossible to test or write tests for.
- A domain layer - Relies on the repositories, but intermingles logic between many different classes and areas
- A model project - loosely reflects the database models
- A viewmodel project
- A web logic layer - one developer went through a detangled all web/business logic (somewhat) and placed it into its own project.
- The web layer - contains controllers, views, and web apis.
The new stuff is built similar, but taking a different approach
- Entity layer - This project solely contains our entity framework entities and contexts. It also has a factory method that returns the proper context and gets the connection string information from our configuration files for each edmx.
- EF Repositories - Each repository handles a minor subset of functionality, pretty much only 1 entity type is interacted with in this layer unless certain joins are necessary.
- Domain layer - This layer builds out units of work for each and every piece of functionality going forward. It doesn't have much/any crossover functionality and is very specialized.
- Unit test project - The unit test project creates mock repositories and checks all the logic implemented in the domain layer.
- Web layer - responsible for wiring up dependency injection and serving up views, controllers, and API methods.
In the new stuff, every single repository implements an interface (almost to a fault), and everything works via dependency injection. I find it rather straight forward, but I'm afraid I'm either doing too much or too little.
For example, lets say I have a context called MainContext
. In my repository layer, I have a repository called GenericRepository
. GenericRepository
implements an interface called IGenericRepository
that lays out methods such as Get, Save, etc. These methods are the same for most repositories, but can be overridden if necessary. It might look something like:
public class GenericRepository<TEntity> : GenericRepository<TEntity> where TEntity : class
internal SchoolContext context;
internal DbSet<TEntity> dbSet;
public GenericRepository(SchoolContext context)
this.context = context;
this.dbSet = context.Set<TEntity>();
public virtual void Insert(TEntity entity)
dbSet.Add(entity);
public virtual void Update(TEntity entityToUpdate)
dbSet.Attach(entityToUpdate);
context.Entry(entityToUpdate).State = EntityState.Modified;
// -- more methods
All other repositories inherit from the GenericRepository
, but they all also implement their own interface that also implements IGenericRepository
At this point we are 2 or 3 interfaces deep, and I'm beginning to feel like it's a bit overkill.
Am I going overboard with the design? Are there any good, complete examples that illustrate the best path forward with a similar design?
