Should one create shareable private class member or keep variable in method scope to pass it as a second method argument?
There is a third option, which is to formally address logically separate abstractions by introducing another class.
Class is responsible of sending multiple, not connected messages to WebService, so when I was creating it, I didn't plan to put variables connected to given order as a class state.
It looks to me like you are dealing with several abstractions here.
Sometimes we use multiple parameters instead of creating a formal abstraction. For example, we have an x
coordinate and a y
coordinate, and use those as parameters in several places. They are meant to be taken as a pair — they are thus an informal abstraction. To make the a formal abstraction we can create a Point
class that binds the x
and y
together. Now where ever we had passed the two variables, we pass the single abstraction. A single abstraction is better than the variable pairs in that the client using these has fewer things to worry about, and the Point
is more type safe and less error prone that the individual coordinate values (which might have been int
s, for example). For example, one could accidentally swap x
and y
; one could use x
with the wrong y
when dealing with multiple points.
Generally speaking, it would be a mistake to include the fields of a logically different abstraction as members of some other abstraction. While it is hard to see from the code in your example, what the class in question is doing, it doesn't look like a good home just for passing parameters to these other functions (methods?).
When you're deciding whether to add fields to an existing class vs. create create another class, here is one way to think about it. If they are logically separate abstractions then the should have separate classes. If they are one and the same abstraction, then add the fields to the class. Check the lifetime of the individual fields. If they all have the same lifetime (and all the same lifetime as object (the class's instances)), that is consistent with being a single logical abstraction. However, if some of the fields are uninitialized after the others are properly initialized (e.g. in the constructor or an init method), and the other fields are only initialized and valid during certain operation sequences, then they belong to a logically separate abstraction, which indicates separate classes.
In your example, order
and xmlorder
possibly form a logically separate abstraction for you to receive as parameter in the first method.
Further, outputData
could be upgraded (either by adding fields to it or by creating a wrapper — use the above lifetime analysis to determine) to capture (order
and xmlorder
) and outputData
and customerCode
Thus, your code could look like this:
public void SendOrder(OrderBundle orderBundle, Insider insider)
string customerCode = CustomerServices
.Get(insider.CustomerId)
.Code;
OutputDataBundle outputBundle = CreateOutputData(orderBundle, customerCode);
outputBundle.CreateReservations();
outputBunlde.PlaceOrder();
(Quality type & variable names notwithstanding.)
