It's very common see a generic's DAO implementation like this:
public List<E> getResultList(String namedQuery, Map<String, Object> parameters) {
    Query query = entityManager.createNamedQuery(namedQuery);
    parameters.entrySet().forEach(e -> query.setParameter(e.getKey(), e.getValue()));
    return query.getResultList();
I have some problems with this approach:
  1. Using a complex structure to just pass a list of key & value data.
  2. Map creation is very verbose.
Example:
public List<TransacaoTEF> getActiveTransactions1(TipoMensagem tipoMensagem, LocalDate date) {
    Map<String, Object> parameters = new HashMap<>();
    parameters.put("type", tipoMensagem);
    parameters.put("date", date);
    return getResultList("namedQueryXTPO", parameters);
To avoid this I thought in create a simple Parameter class:
public List<E> getResultList(String namedQuery, Parameter... parameters) {
    Arrays.stream(parameters).forEach(p -> query.setParameter(p.getName(), p.getValue()));
public List<E> getResultList(String namedQuery, List<Parameter> parameters) {
    parameters.forEach(p -> query.setParameter(p.getName(), p.getValue()));
Using:
public List<TransacaoTEF> getActiveTransactions2(TipoMensagem tipoMensagem, LocalDate date) {
            new Parameter("type", tipoMensagem), new Parameter("date", date));
public List<TransacaoTEF> getActiveTransactions3(TipoMensagem tipoMensagem, LocalDate date) {
    List<Parameter> parameters = Arrays.asList(
It's over engineering or just paranoia ;p ?
Rodrigo Menezes
  • 340
I don't think it's either. Yes, a map is a generic data structure but it's also the first thing you reach out for when you need key-value or param-value pairs. So most people do it like that and then the rest of the code is just them being responsible and not do things like this:
parameters.put(null, someValue);
parameters.put("%$@*^%", someOtherValue);
If you use a Parameter class you can do something extra than what a map gives you. You can assert or validate some of the things that you place inside it like not specifying a null parameter name like above, or maybe not send null values but a JDBC NULL instead, or whatever...
A map is just a bucket. What you put in is what you get out. Nothing fancy. If your application is simple, few disciplined developers, etc, then a map might be enough.
If you are building a library or if you want to make sure there are some safeties in place, then a Parameter class is better.
Bogdan
  • 3,600
To ease the tedium of creating the map I'll often write a little utility:. (skeleton code)
Map addKeyValuePairs(Map m, Object...pairs) {
   // TODO test that pairs has an even number
  for (int i=0; i<pairs.length; i+=2) {
     // TODO Add null checks as desired
     m.put(pairs[i].toString(), pairs[I+1].toString());
  return m;
user949300
  • 8,679
  • 26
  • 35
