Since you don't specify what would the purpose of the "write" database would be, I will assume here that what you mean is this: when registering a new update to an aggregate, instead of rebuilding the aggregate from the event store, you lift it from the "write" database, validate the change, and issue an event.
If this is what you mean, then this strategy will create a condition for inconsistency: if a new update happens before the last one had a chance to make it into the "write" database, the new update will end up validated against outdated data, thus potentially issuing an "impossible" (i.e. "disallowed") event and corrupting the system state.
For example, consider a standing example of booking seats in a theater. To prevent double booking, you need to make sure that the seat that is being booked is not already taken - this is what you call "validation". To do that, you store a list of already booked seats in the "write" database. Then, when a booking request comes in, you check if the requested seat is in the list, and if not, issue a "booked" event, otherwise respond with an error message. Then you run a projection process, where you listen to the "booked" events and add the booked seats to the list in the "write" database.
Normally, the system would function like this:
1. Request to book seat #1
2. Check in the "already booked" list: the list is empty.
3. Issue a "booked seat #1" event.
4. Projection process catches the event, adds seat #1 to the "already booked" list.
5. Another request to book seat #1.
6. Check in the list: the list contains seat #1
7. Respond with an error message.
However, what if requests come in too quickly, and step 5 happens before step 4?
4. Another request to book seat #1.
5. Check in the list: the list is still empty.
6. Issue another "booked seat #1" event.
Now you have two events for booking the same seat. The system state is corrupted.
To prevent this from happening, you should never validate updates against a projection. To validate an update, you rebuild the aggregate from the event store, then validate the update against it. After that, you issue an event, but use timestamp guard to ensure that no new events have been issued since you last read from the store. If this fails, you just retry.
Rebuilding aggregates from the event store might carry a performance penalty. To mitigate this, you can store aggregate snapshots right in the event stream, tagged with ID of the event from which the snapshot was created. This way, you can rebuild the aggregate by loading the most recent snapshot and replaying only events that came after it, as opposed to always replaying the whole event stream from the beginning of time.
