Are there any use-cases where a nested object as state is either more optimal/easier to work with than individual properties?
For instance if I wanted to express some user controls for interacting with a photo in state I could write something like so (nested object):
this.state = {
   photoControls: {
      open: false,
      thumbnailUrl: null
Or I could also write it this way (individual properties):
this.state = {
   photoControlsOpen: false,
   photoControlsId: null,
   photoControlsThumbnailUrl: null
Although I can logically group properties together using a nested-object style of state, it seems to only prove more verbose when trying to update just one, or a couple, of those properties.
This being said, what are the benefits (if any) to using nested objects in state as opposed to using individual properties. I understand that nested-objects might feel more proper, but I can't think of any benefits to them, anyone have any insight?
connected_user
  • 477
  • see [Why do 'some examples' and 'list of things' questions get closed?](https://softwareengineering.meta.stackexchange.com/a/7538/31260) – gnat Dec 11 '17 at 15:58
  • @gnat I am not looking for a right answer, I want to see if anyone can give any use-cases where a nested-object state structure can prove beneficial? – connected_user Dec 11 '17 at 15:59
  • Should I post this on stack-overflow or where? Reddit? lol – connected_user Dec 11 '17 at 16:02
    It might actually fit Reddit's format better than SE's. – MetaFight Dec 11 '17 at 16:38
  • You can read Redux's thoughts on it here on State Shape... https://redux.js.org/docs/basics/Reducers.html – Jon Raynor Dec 11 '17 at 19:46
  • since this was never closed or anything... have you found a proper answer yet? – Manticore Jun 16 '18 at 07:17
  • Yes, the answer I found is that the difference is really negligible for the most part. The shape of your state, whether a series of flat properties or on object, really doesn't hold that many differences. The only differences you may come across is how certain libraries or frameworks enforce one of these shapes and/or how they choose to set these states. – connected_user Jun 17 '18 at 23:10
It depends on likely future development. Creating a separate object for PhotoControls is a waste of time and code if the object is never reused. However, if PhotoControls is likely to be used in another object, then defining it separately is good, but only if the abstraction is really useful. If the Photocontrols object in another object must have attributes that are not relevant in the old context, you may have built a bug trap.
I have often regretted creating sub-objects when they were unnecessary and been very happy to have created them when they were useful. Think about what you might want to do in the future. You won't always be right, but thinking about it ahead of time improves your odds.
MarvW
  • 89
Abstracting state for audio/video would be a good example:
video: {
            readyState,
            networkState,
            error: error || networkState === 3,
            // TODO: This is not pretty. Doing device detection to remove
            // spinner on iOS devices for a quick and dirty win. We should see if
            // we can use the same readyState check safely across all browsers.
            loading: readyState < (/iPad|iPhone|iPod/.test(navigator.userAgent) ? 1 : 4),
            percentagePlayed: getPercentagePlayed(restState),
            percentageBuffered: getPercentageBuffered(restState),
            ...restState
References
Paul Sweatte
  • 382
