Background
I am trying to develop with Webpack and JavaScript. Webpack would bundle all source code into one single file. When application becomes large, the file would be very large and cause negative impact to the performance.
Webpack
Webpack provided feature named code splitting which would split the bundle output into different according the predefined entry point. It would help increase the performance if the application become too large. However, It required to restructure the application and deeply understand the application, then the application spitted into different modules which would be the entry points for build. Also, it would requires code change when another required to call the function by Lazy Loading.
SystemJs
SystemJs is a dynamic Es Module Loader which would lazy load the required module in Runtime.
Question
Should I use webpack for large-sale application?
Possible Solution
JavaScript Source Code Bundling is necessary for large application but the application may be spitted into sub-modules and may be lazy load into application if the sub module is loaded.
Update
stage 3 proposal specific the dynamic import syntax which would used to solve my problem (lazy load for specific part).
import('./test.js').then(function(Test){
var test = new Test.default();
test.doSomething()
Which is similar to
import Test from './test';
var test = new Test();
test.doSomething();
Webpack support
It required to config the public path, chunkFilename and add syntax-dynamic-import for enable new syntax (import()).
const path = require('path');
module.exports = {
entry: {
app: './src/app.js'
output: {
publicPath: 'bin/',
path: path.resolve(__dirname, 'bin'),
filename: '[name].bundle.js',
chunkFilename: '[name].bundle.js'
devtool: 'source-map',
module: {
loaders: [
test: /\.js$/,
loaders: [
loader: 'babel-loader',
options: {
presets: ['es2015'],
plugins: ["syntax-dynamic-import"]
