I am currently designing a software in which I have to use a rest client. I have decided to use a particular library, but am stuck whether I should use it directly or add a custom encapsulation layer. To make myself more clear, suppose i have to make a request from a function named getAuthInfo
Doing it directly
function getAuthInfo() {
return someLibrary.get(path, headers);
Adding Encapsulation layer
/* Adding an abstraction layer on top of the library */
import myEncapsulation;
return myEncapsulation.get(path, headers);
/* myEncapsulation module */
function get(path, headers) {
The reason why I am asking is because the pace at which things change in javascript world, the library i am using today might do a complete rewrite causing breaking changes or a new library might come out which better supports my use case.
In any such case, if I implement using the first method, I will have to make changes all across the app, but in the second case I will have to make changes in a single module.
But the downside I feel to the second method can be that, there is a little overhead to implement the module and that I will have to maintain very cautiously and document properly for the EncapsulationModule.
What do you guys suggest ??
