I am using C# on a pretty huge solution that user a Static Class to manage the Session on the database.
The performance are not so good because of the number of call to the database.
The company decide to introduce Redis as a very fast alternative. Of course it is so fast! But now I have to design a service that will replace gradually the original Static Class.
In the solution there is no DI system.
I am asking some guidance to design the new "Session Manager" that abstract the usage of the Static Class rather than the Redis Client. Based on the operation, It will internally call one method rather the other.
Is there any pattern to get advice from?
Angelo Badellino
  • 704
  • You can still use static methods in the new session manager which refer to a static instance of Redis. Just make sure Redis is thread-safe. If it isn't, then you must make it so. – Neil Nov 21 '17 at 15:28
    I posted an answer to a very similar question 4 years ago. My answer isn't spectacular, but I would probably follow a very similar approach today. Take a look: https://softwareengineering.stackexchange.com/questions/195079/how-to-convert-a-static-access-style-project-to-ioc-di-style/195084#195084 – MetaFight Nov 21 '17 at 15:46
    This question is really broad. Have you made an attempt at creating something yet? It sounds like you already understand the need to get away from the static class and build something a bit more testable and loosely-coupled. What's the problem? – Robert Harvey Nov 21 '17 at 16:28
  • You say there isn't a DI system. What is stopping you from adding one? – Becuzz Nov 21 '17 at 20:31
    I've found [Working Effectively with Legacy Code](https://www.amazon.com/Working-Effectively-Legacy-Michael-Feathers/dp/0131177052) tremendously helpful for situations like this. – Caterpillar Nov 22 '17 at 09:14
  • I know that this question is broad. But with the internal search engine I did not find a similar solution. I am aware that this can make me some vote down. I appreciate the comments, I am still here to read other mindset. – Angelo Badellino Nov 22 '17 at 09:23
Let's say you have a static library like this:
class SessionHelper
    static public void Foo()
        //Implementation
    static public void Bar()
        //Implementation
And a program that uses it, that you'd rather not monkey with too much:
class MassiveSpaghettiCode
    void DoSomethingNobodyUnderstands()
        SessionHelper.Foo();
        SessionHelper.Bar();
I would extract the static methods to an interface and copy the implementation code from the static class, only exposing each method as an interface member.
interface ISessionHelper
    void Foo();
    void Bar();
class SessionHelper : ISessionHelper
    public void Foo()
        //Implementation
    public void Bar()
        //Implementation
Then, expose an instance of the implementation via a member property with the same name as the original static class. This allows the legacy spaghetti code to continue to function without any modification. For bonus points, we can inject the instance if we want.
    protected readonly ISessionHelper _sessionHelper;
    protected ISessionHelper SessionHelper
        get
            return _sessionHelper;
    public MassiveSpaghettiCode() : this( new SessionHelper() ) //Default constructor requires no injection
    public MassiveSpaghettiCode(ISessionHelper sessionHelper)
        _sessionHelper = sessionHelper; //Injected, or injectable at least
        SessionHelper.Foo();  //Notice this code hasn't changed at all
Once you have the existing code extracted to an interface/implementation, write a series of integration tests and get it nice and stable. You want to make sure you understand what it means to fulfill the contract implied by that interface,not just syntactically but semantically.
Once you have a thorough understanding of the interface as implemented by the legacy code, create a new class, implementing the same interface, but with brand new code using your newer back end technology (Redis, or whatever). Run this class through exactly the same unit tests. Be sure you can explain any difference in test outcomes; ideally there shouldn't be any.
Once all of the tests pass identically, you're ready to switch it out, which is as easy as changing the one dependency.
P.S. I believe this is pretty much the approach Microsoft took when migrating everyone from classic ASP to ASP.NET, e.g. the Session and Response syntax looked the same but worked rather differently.
John Wu
  • 26,032
  • 63
  • 84
The solution provided in Mike Feather's Legacy Code book is very similar to the solutions given above, but without any need to change the consumers of your static class.
Let's start with the simple example given by John Wu, with small modification (I assume that the class is also marked static):
public static class SessionHelper
    public static void Foo()
        //Implementation
    public static void Bar()
        //Implementation
Extract the interface, create a new (non-static) class implementing it by moving all the implementation details from the static class into the new class, and remove its static modifiers. Also generate such a class using Redis instead of the database:
public interface ISessionHelper
    void Foo();
    void Bar();
class DatabaseSessionHelper : ISessionHelper
    public void Foo()
        //Implementation taken from the static class
    public void Bar()
class RedisSessionHelper : ISessionHelper
    public void Foo()
        //new Implementation based on Redis
    public void Bar()
Now go back to your original static class, add a new static member of the interface type, instantiate the DatabaseSessionHelper by default, but allow for a different instance to be injected, and forward all calls to the instance:
    private static ISessionHelper _Instance = new DatabaseSessionHelper();
    public static void SetInstance(ISessionHelper instance)
        _Instance = instance;
        _Instance.Foo();
        _Instance.Bar();
Now you can set the instance to Redis somewhere during the start-up of your application: SessionHelper.SetInstance(new RedisSessionHelper()). That's the only change required in the rest of the program, nothing else needs to be changed, the rest of the program will not need to know anything about the changes in the static class. That's the difference to the other solutions provided here, which require changes elsewhere.
Bernhard Hiller
  • 1,953
Create an interface for the functionality. I will use an example based on a static file system call, but the concepts are the same for your Redis problem.
public interface IFileSystem
   string ReadAllText(string path);
Now the real one:
public class RealFileSystem : IFileSystem
   public ReadAllText(string path)
     System.IO.File.ReadAllText(path);
An alternative (Fake):
public class FakeFileSystem: IFileSystem
    return "Fake response from: " + path;
Now, one will need to extract that dependency, either in the constructor or the method that is calling it.
As an example callout, let's use method level injection:
public string MethodLevelInjection(IFileSystem fileSystem, string path)
  fileSystem.ReadAllText(path);
Now, whoever is calling this method will have to create the proper instance and pass it in. The tests can use a fake implementation.
So, one will either have to use method level or constructor level dependency injection to pass the dependency in. One could introduce a dependency injection framework to handle the wire up, or do it manually. If this is the only case, maybe manually is the best until there are multiple instances of DI needed.
But now one has the ability to switch out the dependency.
Jon Raynor
  • 10,905
  • 47
