I recently stumbled upon some code which looked wrong. I edited it only to see that my changes broke the code. I tried to structure the code in different other ways to make the code both look and be right, but I wasn't satisfied with any alternative I could come up with.
The logic of the code is as follows:
  • A Path is made of zero or more Segments.
  • A Segment contains:
    • one or more properties (here only one for brevity), and
    • a reference to the Path it is on.
  • Invariants that must be upheld:
    • The Path reference on a Segment is always initialized.
    • A Segment is an item of some Path's Segments.
    • The Part reference on a Segment references the Part, which Segments contain the Segment.
Here's the code I looked at, when I thought I had found a bug:
public class Path
    public List<Segment> Segments { get; } = new List<Segment>();
public class Segment
    public int Property { get; }
    public Path Path { get; }
public static class Test
    public static Path CreatePath()
        var path = new Path();
        var segment = new Segment(path, 42);
        return path;
By just glimpsing at CreatePath and without inspecting further I concluded that there clearly was a bug, since segment wasn't added to path.Segments and thereby violating an invariant.
Apparently I was wrong as the constructor of Segment did more work than I expected. The actual constructor looked like this:
public Segment(Path path, int property)
    Property = property;
    Path = path;
    path.Segments.Add(this); // <--
While I acknowledge the intent of the constructor to ensure the invariants, I didn't like the way it was done mainly of two reasons:
  • The constructor does more work than validating arguments and initializing fields.
  • CreatePath only looks correct when you know the internals of the constructor.
This to me breaks the Principle of Least Astonishment -- at least I was astonished.
I tried to come up with alternative ways to accomplish this, but I'm not entirely satisfied with any of them.
The original code where the consistency is ensured inside the constructor of Segment. It's problem is, that segment looks unused in CreatePath if you don't know about the internals of the constructor.
namespace PathExample0
    public class Path
            Path = path;
            return path;
This first alternative takes out the consistency part of the constructor and into the CreatePath. The constructor is now free of surprises and segment is clearly used in CreatePath. The minor problem is now, that were are not guaranteed that segment is added to Segments of the right Path.
namespace PathExample1
    public class Path
            Path = path;
            path.Segments.Add(segment);
            return path;
My second attempt Adds an AddSegment to Path which ensures the consistency. This still don't hinders you to call new Segment(somePath, 42) and break the consistency.
namespace PathExample2
    public class Path
        private readonly List<Segment> segments = new List<Segment>();
        public IReadOnlyList<Segment> Segments => segments;
        public void AddSegment(int property)
            var segment = new Segment(this, property);
            segments.Add(segment);
            Path = path;
            path.AddSegment(42);
            return path;
The third and last example I could come up with interfaces out Segment into ISegment and makes Segment a private class to Path. This should now ensure full consistency between a Path and its Segments. To me it feel like a cumbersome approach and almost as a misuse of interfaces to hide the constructor of Segment.
namespace PathExample3
    public interface ISegment
        Path Path { get; }
    public class Path
        public IReadOnlyList<ISegment> Segments => segments;
        private class Segment : ISegment
                Path = path;
            return path;
So my question is how to structure the code in a way, to ensure the invariants while retaining idiomatic C# code. Maybe I'm missing out on a well-known design pattern to accomplish this?
Giorgio
  • 19,486
  • 84
  • 135
Jonas Nyrup
  • 191
    (In my eyes, your question would benefit from an introductory summary where all of it is going to, and a (list of) explicit question(s) at the end.) –  Nov 16 '17 at 14:02
  • My gut feeling is that the further you separate creating the Segment from adding it to the Path, the more chance for bugs, especially **concurrency** bugs. But needs more analysis. – user949300 Nov 16 '17 at 23:35
    A relevant counterexample to the "constructors must have no side effects" is [SWT graphic widgets,](http://www.vogella.com/tutorials/SWT/article.html#swt-widgets) which always take a `parent` widget and always add themselves. – user949300 Nov 17 '17 at 21:00
A way to avoid usage of a misleading constructor is to make it private and instead provide a static factory method stating what it does. It also allows you to keep the constructor clean. (I would not say that is has no side-effect. A function changing some state besides returning a value is said to have a side-effect. Since constructors are not functions and cannot return any value, producing side-effects is all they can do. They change the state of the object from uninitialized to initialized.)
    private Segment(Path path, int property)
        Path = path;
    public static Segment AddToPath(Path path, int property)
        var segment = new Segment(path, property);
        return segment;
You can use this static factory method in the Path class
public class Path
    public Segment AddSegment(int property)
        return Segment.AddToPath(this, property);
Now it is not possible anymore to create a segment without adding it to a path and without setting the reference to its path.
  • By the GoF design-pattern definition, a `factory method` is polymorphic (implemented in a subclass for different types). I see your solution as a `simple factory`? c.f. https://dzone.com/articles/factory-method-vs-simple-factory-1 – Fuhrmanator Nov 17 '17 at 16:55
    I think the correct term for my method is *static factory method*. – Olivier Jacot-Descombes Nov 17 '17 at 17:43
  • It would be great if you could cite a source for that term. I teach design patterns and factory is perhaps the most overloaded word in that discipline... – Fuhrmanator Nov 17 '17 at 17:46
  • [What are static factory methods?](https://stackoverflow.com/questions/929021/what-are-static-factory-methods) – Olivier Jacot-Descombes Nov 17 '17 at 18:16
  • I'd use the [Joshua Bloch reference](https://books.google.ca/books?id=ka2VUBqHiWkC&pg=PA5&redir_esc=y#v=onepage&q&f=false) (see the most-voted answer's comment about why it's not a factory method -- it's essentially the same comment as mine). – Fuhrmanator Nov 17 '17 at 19:03
  • Best answer. One question / suggestion: why did you name it "AddToPath" instead of "CreateAndAddToPath"? IMO the later is clearer, but wondering if you have a different take. – user949300 Nov 17 '17 at 20:55
    I am not referring to a GoF design-pattern when I say *static factory method*. I just mean a static method that creates, initializes and returns an object. – Olivier Jacot-Descombes Nov 18 '17 at 16:07
  • `CreateAndAddToPath` is a good name. The name `AddToPath` tells what it does on a higher (geometric) level and ignores the fact that an object must be created (implementation detail). When I review older code that I ‘ve written, I often rename things, because it helps me to understand what a had written. Often when coding I am focused on details, what makes me narrow-minded. Later I often see things clearly. See [The Boy Scout Rule](http://programmer.97things.oreilly.com/wiki/index.php/The_Boy_Scout_Rule) – Olivier Jacot-Descombes Nov 18 '17 at 16:24
  • "Static Factory Method" is a term used by Joshua Bloch in his book "Effective Java", which essentially means `public static MyObj newInstance(){ return MyObj();}`. It has nothing to do with GoF patterns. – Andrejs Sep 05 '19 at 11:45
It is unclear why segment has to reference a path. It does not strike me as particularly good idea. If it can be avoided - that is what I would refactor to begin with. The problem you are having is a direct result of having a circular dependency, which (in my experience) is never a good thing. I'm afraid there is no pretty way to solve this problem, unless you eliminate the cause.
That being said, if you have to keep the Path reference for w/e reason, I think your last option is the best one. I don't quite see why would you need an interface though. As long as AddSegment(int property) is the only way to add a segment to path, it does not matter whether or not Segment class is public. Path class will stay consistent. However I would probably add an overload that takes a segment:
public class Path
        AddSegment(new Segment(property));
    public void AddSegment(Segment segment)
        if (segment.Path != null) throw ...;
        segment.Path = segment;
    public Path Path { get; internal set; }
    public Segment(int property)
Nikita B
  • 299
  • The bi-directional reference is just like in a graph, where nodes and edges could have references to each other. I wasn't explicit enough about it, but a `Segment` must *always* be a part of a `Path` and therefore I wanted to avoid a public constructor of `Segment`. – Jonas Nyrup Nov 17 '17 at 15:18
You can enforce consistency to a certain degree by making the Segment constructor internal, and putting the Path and Segment classes in a different DLL than your main application code:
// In one DLL
public class Path
    private List<Segment> segments;
    public IEnumerable<Segment> Segments => segments;
        return segment;
    public int Property { get; private set; }
    public Path Path { get; private set; }
    internal Segment(Path path, int property)
        Path = path ?? throw new ArgumentNullException(nameof(path));
Then use the Path class in another DLL file:
// In another DLL
var segment1 = path.AddSegment(42);   // Compiles
var segment2 = new Segment(path, 56); // Does not compile. Constructor is internal
Because the Segment constructor is marked internal you must go through the Path.AddSegment method to create new Segment objects.
The Segment constructor is free of side effects, because the Path.AddSegment method adds the new segment to the Path's collection.
Greg Burghardt
  • 34,276
  • 63
  • 114
  • Not a bad idea, but forcing people to move classes between DLLs is quite invasive advice. Usually we don't have a lot of choice in these matters. – Frank Hileman Nov 17 '17 at 01:48
If created Segment absolutely must be referenced be a Path, it reflects some business requirements, and it seems that this requirement constitutes a Segment's invariant. And objects should be created always valid, with all invariants ensured. Since the code executed while object creation resides in constructor, it's very logical place for enforcing his invariants.
And I agree with Nikita, I'm sure you could avoid that circular dependency. It's considered a bad practice, at least in Domain-driven design.
Vadim Samokhin
  • 2,158
