I will have a database of products where each record will have a number associated with it, let's say, the number of "sales".
I will periodically update the database so each "sales" field for each record will be updated.
I need to sort these records based on the "sales" columns, descending. I need to track the "ranking" of each of those record at each database update. So if a record is number 1 when database is sorted by "sales" descending, I need to store this information. When I update this database and that records now is the 5th still when database is sorted by sales descending, I need to record this information. So then I can reconstruct the ranking evolution of each record.
Is this clear ?
I see 2 ways of doing so: For each record and on each database update, create a foreign key record with position and date. The database will grow a lot with each update since each record will be associated with a new foreign key.
Another way of doing so: do not create a foreign record but somehow store this information on the record itself, not sure exactly how.
How would you do this? What's the proper way of doing ? This system intends to use a postgres DB.
Robert Brax
  • 231
On each update or insert create a database trigger. Inside that trigger search for the top sales item and store its ID in a separate table or whereever you want to store it with date and position. Read about triggers here.
Farrukh Subhani
  • 208
Some suggestions:
  • You do not need to create new records for all products every time, you only need to create for those that change their ranking position
  • I did a quick search and found out Postgres has array and json type. I am not sure if you can have array of json in a table. If yes, you can have an array of json having ranking position and timestamp within your record. Push new json to this array every time ranking position is changed
  • You also need to check the size limit of the array field. If it does not match your system expectations you will need to create new records of primitive types
  • Or still using array of json, but inside new records. Check the array size every time you update, if the size is at limit create a new one with same foreign key, push the json to its array, use an index/timestamp field to know the order of records with same foreign key
kkkkkkk
  • 134
    Thanks for sharing your suggestions. There are 7K records and they change everyday which would lead to millions of records/year. I went for the postgres array solution: I create a single record per product (1/1 relation) in another table and use the pg array there to push new ranking positions and their timestamp. There is no particular limitation on array size: it is subject to the global pg column size which is more than enough. I will see how practical this is on a day to day basis, I can always revert to the traditional one to many relation shall my current solution doesn't prove good. – Robert Brax Nov 04 '17 at 09:26
