In Germany we use the expression "Clean Code" (loanword) to describe source code that is well written. Lately I came to translate "Clean Code" literally to german and had an idea that in english there could be several meanings:
  1. Clean Code: well written source code
  2. Clean Code: a set of rules (code) to keep everything clean
Yet I am not certain whether the second meaning could be a valid interpretation in english. So maybe a native speaker could give me an answer. If I am wrong with the second interpretation it would be kind to explain why my interpretation is differnt from that of native speakers.
Edit:
I know the contents of the "Clean Code" book and I know the primary meaning of clean code. So please do not explain to me how to code cleanly - it is off topic. I want to know whether the term "clean code" used in a context beyond software engineering code be understood as rules how to keep everything clean.
CoronA
  • 135
    Here, “Code” refers to source code, not rules or laws. Therefore, I'd translate “clean” as „sauber“ in the sense of „ordentlich“ → „sauberer Code“ oder „ordentlicher Quelltext“. If “clean code” referred to rules about keeping clean, it would be a “cleanliness code” (German: *Sauberkeits-Ethos*, nicht: *sauberes Gesetzbuch*). – amon Oct 29 '17 at 11:40
  • I am quite aware of the intended meaning. My question was whether there is a hidden meaning in "clean code". So a complete answer to my question would be an explanation (!) why nobody would expect "Clean Code" to be a code of rules about writing "clean" source code. From your comment I cannot see whether "cleanliness code" makes the expression unambiguous or whether "clean code" is bad english. – CoronA Oct 30 '17 at 05:18
  • Then maybe you'd get a better answer from the English Language SE (or similar)? –  Oct 30 '17 at 16:15
  • I do not need an academic justification. @Amon: Your profile points to the fact that you are located in Germany. Are you truely a native speaker? Or did you speak with native speakers about this subject? – CoronA Oct 30 '17 at 16:33
  • Better developers consider code produced using the "clean code" book guidelines, "ugly code" i.e. the opposite of what was intended. Just to add to your confusion. :) – Frank Hileman Oct 30 '17 at 18:50
  • Keep in mind that anyone can write a book called "Clean code". If that book sells, now people will have trouble to distinguish between truly clean code, and the code written using that book's guidelines. This is the most annoying thing about such a book. – Frank Hileman Oct 30 '17 at 22:11
  • @Frank: So you do agree that there are two meanings and the second one is misleading? JohnWu seems to have another opinion. – CoronA Oct 30 '17 at 22:26
  • There is only one meaning, but the meaning is subjective. However, in the context of the tag used on this site, the meaning is specifically that book, from what I can tell. If you review posts using that tag, you will see how horrible the code can be, when following the guidelines in that book. Truly clean code is generally the most simple code, and the least amount of code. That is not what the book recommends, as it would make a short book. – Frank Hileman Oct 30 '17 at 23:45
  • Seems like "clean code" is well written source code where as "Clean Code" is known as a set of rules. – JeffO Nov 01 '17 at 12:41
  • @JeffO Exactly. Titling such a book "Clean Code" muddies the waters. – Frank Hileman Nov 01 '17 at 23:08
  • Can someone come back to the question. I can read a lot of comments that are completely off topic, and some others that say "no", but no answer tries to justify the fact that clean code cannot be understood as cleanliness code. And why is the answer of CandiedOrange contrary to the majority of comments? Maybe it is too trivial, but remember: I am not native speaker. – CoronA Nov 03 '17 at 07:10
Clean Code is a buzzword given to us by Uncle Bob (Robert Martin) in his book of the same name: Clean Code.
As Amon points out code refers to source code. However Uncle Bob published a second book called Clean Coder with the sub title of "A code of conduct for profesional programers". In this case "code" in the subtitle does not refer to source code. However, "coder", refers to someone who writes source code. So it's easy to say it can be either 1 and 2. However, as I read the book Clean Code I translated it as meaning source code most of the time.
Personally I don't think of them as a code of rules the same way I think of building codes. Someday they might be, but right now they are ideals we reach for when a solution could take more than one form.
If what you're looking for is a way to review someone's work to determine if it conforms, we typically use other words for that: standards, conventions, and style guideline.
The books get into stuff far more subjective and difficult to impose on others. They are very good ideals to reach for, ask for, but there's never going to be a tool that will confirm if you chose a good name. For that you need to talk to your team.
In general the term refers to code that meets ideals that have nothing to do with whether the code works. Humans like clean code. Computers don't care.
candied_orange
  • 102,279
  • 197
  • 315
  • Maximum respect to Mr. Martin, but I'm pretty sure usage of the term "clean code" predates the first printing *Clean Coder*. – John Wu Oct 29 '17 at 17:39
    @John: I think we all agree on that. But that was not my point. I wanted to know whether the second meaning is thinkable - or just bad english (i.e. nobody, even children would not expect the second interpretation). – CoronA Oct 30 '17 at 05:24
"Clean code" refers to source code that is "clean." It does not refer to any sort of code as in code of behavior (e.g. code of conduct or legal code). It's source code. So your answer is #1.
In this context, "clean" is not particularly well-defined, but generally means that the code is free from unnecessary complexity, free of code smells, and otherwise free of clutter that would make it difficult to read or maintain. It is understandably subjective. Books have been written about it, such as Martin's Clean Code.
Some engineers use "clean" interchangeably with "good." Also, it comes up in other contexts, e.g. "clean design," which could mean a number of things. Personally I discourage both terms in technical discussions since they lack any agreed or actionable definition.
If you are looking for a term that indicates "a set of rules to keep everything clean," some terms that might apply are coding standards and coding conventions.
For comparison, see also elegant code and SOLID code.
John Wu
  • 26,032
  • 63
  • 84
  • The question was not "either 1 or 2". I know what clean code is. I just do not know whether a native speaker (without background in software engineering) could misinterpret this term. In Germany this is unthinkable, because code (which is used in german language) has no second meaning in german. – CoronA Oct 30 '17 at 16:37
  • No, a typical native speaker would never take "clean code" to mean #2. – John Wu Oct 30 '17 at 17:09
  • SOLID has the same problem. "SOLID" has nothing to do with producing solid code, in the English sense of the term. – Frank Hileman Oct 30 '17 at 22:13
  • But SOLID is a good example for a term that has two meanings - one as acronym and one as word "solid". And I am quite sure that this is intended. – CoronA Oct 30 '17 at 22:31
  • @CoronA Intended, yes, and the source of many problems as the various techniques within are misapplied... – Frank Hileman Oct 31 '17 at 00:16
