When creating a Set in Java, what's the difference between the following? Which one should I use, and why?
Set< T > set = new HashSet<>();
HashSet< T > set = new HashSet<>();
jason
  • 121
    This question is off-topic for this site, but this question on stack overflow answers your question: https://stackoverflow.com/questions/2279030/type-list-vs-type-arraylist-in-java – Samuel Oct 13 '17 at 02:06
    I can understand how it might appear off-topic, but I am not sure it really is. –  Oct 13 '17 at 02:54
    @Snowman it is not really off topic but already answered at stackoverflow. – Timothy Truckle Oct 13 '17 at 06:43
  • ...it was asked soooo many times – dagnelies Oct 13 '17 at 09:41
  • @TimothyTruckle that makes it neither off-topic nor a duplicate. Unless _our_ help center says it is off-topic, or there is a duplicate on _this_ site, it should be fine. –  Oct 13 '17 at 12:54
    If anything this question should be closed as a duplicate of [Understanding “programming to an interface”](https://softwareengineering.stackexchange.com/q/232359/) –  Oct 13 '17 at 13:10
In object-oriented programming, there is a concept of "programming to an interface." The idea is you do not really care which type of set you use, only that it fulfills the contract of the Set interface (or List, or Map).
Your examples do not really show the benefits of the first example, but consider this code:
public class Example {
  public HashSet<String> doSomething() {
    final HashSet<String> set = new HashSet<>();
    // do stuff with the set
    return set;
You use this class all over the place. There are tons of references, and code in multiple locations has to store the result of that method in a HashSet<String> reference.
Oops, now you have a requirements change, and order matters. HashSet does not guarantee iteration order, now you need a TreeSet. So you update the method to use TreeSet. Except now you have tons of references that need to be updated. Perhaps your IDE can update this for you: perhaps you have external users of the class and it will create headaches for them.
A better alternative is to code to an interface. Instead of defining the implementation in the method signature and body, use plain old Set. If the method's contract is that it returns an ordered set, return a SortedSet. If users of the set need not only order but there is also a guarantee that an iterator can navigate the set, return a NavigableSet.
  public SortedSet<String> doSomething() {
    final SortedSet<String> set = new TreeSet<>();
    return set;
The Java collections framework includes interfaces for most of the common implementations. The Map interface has subinterfaces mirroring the set interfaces I already mentioned (makes sense, because the sets delegate internally to maps). Lists are an exception (ArrayList implements RandomAccess, a marker interface), but queues (including LinkedList) have several interfaces.
Anyway, code to the highest level interface you can. If a consumer of your interface only wants to iterate, then store a reference to that set in a Collection or even Iterable, insulating it from interface changes later on.
The answer from @Snowman is right for the general case. It is most of the time correct to code to an interface, for the reasons he stated.
There are cases however, where you don't want that, as the underlying implementation can make a big difference to performance.
Consider the case of a List<E> which you process by using List.get(int) and List.set(int, E). While these operations are available for all List implementations, it will make a huge difference in performance whether you are working on an ArrayList or on a LinkedList.
In such a case you could define that your method accepts only ArrayList as a parameter. Or you could accept List and then create an ArrayList from it for processing.
So the answer is, it depends. In most cases code to an interface, but when you need to, don't be afraid to specify the exact type you are expecting.
