I got a headscratcher: someone submitted code to test whether all of some checkboxes were unchecked, and it indicated True when an even number were checked. The code looked something like:
if (box1.checked == box2.checked == box3.checked == box4.checked == box5.checked == false) ...
and I read it naively as: if each one is false... But this was incorrect. I figured out why (C# evaluates from left to right, and the result of a boolean compare is a boolean: false == false evaluates to true), but I wondered if this shows up often, and has a name? I guess I would name it Chained Falsehood or maybe False Decay as it would be fine if all operands were True.
The same idea works fine with assignment, so I can see why the coder tried it this way.
Ok, based on comments, this should not be called an anti-pattern because it is a bug. I think it should be called an idiom from another language. But vanity of vanities, thy name is Python, and its name should be called Haddock's Ayes.
