Please refer the following two forms of the same code
First:
<?php if(some_condition){
<li><a target="_blank" href="example.com/channel1/" class="xyz">If content</a></li>
<?php
}else{
<li><a target="_blank" href="example.com/channel2/" class="xyz">Else Content</a></li>
<?php?>
Second :
<?php
if(some_condition){
echo '<li><a target="_blank" href="example.com/channel1/" class="xyz">If content</a></li>';
else{
echo '<li><a target="_blank" href="example.com/channel2/" class="xyz">Else Content</a></li>';
My question is which one of the following is a better option.I know the second one is more readable. But if there are so many conditions on the same page, then which is better performance-wise(i believe, there will be only a negligible performance difference between the two).
I would like to know your views/points, regarding standards performance and whatever you think I should know, about the two different forms.
(And which should be preferred over the other,when there is only single if-else block, and multiple if-else blocks)
Thanks
