It really depends on how you're doing MVC. MVC does not dictate how M, V, and C communicate. Your code makes sense if you're doing this:
But not if you're doing this:
Which you should do largely depends on how you feel about Command Query Responsibility Segregation.
Telling me you're using MVC doesn't tell me much. It's an old design pattern that has been reinvented in many different ways. The only consistent thing about it at this point is the idea of separating 3 areas of responsibility.
The billion dollar mistake was to allow null
into the typing system. Unless you use a language that fixes that you're living with nullable types.
Carefully not returning null
is a different thing. You avoid returning null
because the meaning of null
isn't clear from context to context and the behavior it causes is usually unintended. Returning a null object lets you control the behavior and makes the meaning clear. This can be as simple as setting String to "" rather than null
Using Optional
lets you get a similar effect without defining a null
object class because Optional
is effectively a container. Rather than subjecting you to a null
that blows up when you dot off of it, Optional
acts like an ArrayList that contains nothing.
Optional
doesn't stop null
from existing. It just abstracts dealing with it away. It effectively stuffs your if (foo != null)
checks down into Optional
so you don't have to look at them. It also only works as long as you keep using Optional
. The moment you break out of Optional
, and directly touch what's in there, you're right back where you started, dealing with null
Faithfully avoiding null
in your returns may sound attractive but understand that just because something says it returns Optional
doesn't mean they can't still screw you and sometimes return a naked null
. The typing system can't make you that promise. That's the billion dollar mistake.
