Inheritance vs coding to an interface is something I have wondered with respect to proper architecture design but actually have not run into an problems when using abstract inheritance over coding to an interface in my own projects.
According to SOLID principles of OOP Design (and general OOP advice), you should code to an interface and never use inheritance (abstract or otherwise) (and yes, I realize I am speaking in the context of absolutes because I find very few arguments otherwise). While this makes complete sense for situations such as having classes such as:
class A {}
class B : A {}
class C : B {}
class D : C {}
class E : D {}
In this context, there is a strong coupling between classes that can easily break at any level. I 100% agree that inheritance is the key problem. However, I often wonder if the following would be an acceptable use of inheritance
public abstract class Vehicle
public enum Gear
Drive,
Reverse,
Park,
Low,
High,
Neutral
public string Color { get; set; }
// Other common properties here …
public virtual void Drive()
if (KeyInIgnition() && HasFuel() && SeatBeltsOn() && GearMode == Gear.Drive)
// Some logic to move car forward
// other logic ...
public virtual void Reverse()
// Logic here ...
public class Sedan : Vehicle
// Set base class properties here ...
public int UniqueSedanMethod() // Let’s say this method does not fit the standard to put something in an interface (i.e. it is completely unique to a sedan)
// Logic here ...
return 3;
// Gets base class logic because driving a sedan does not differ (in the basics) from the driving of an SUV
public class SUV : Vehicle
public int CalcAdditionalSeatsAdded()
// Logic here ...
return 5;
In this context, to me it seems it would make sense to have a logical base class to group the common behaviors all vehicles would share. Drive should not ever be different no matter what car type we are in, however if the need should arise, the method can be completely overrode (and use the default implementation where needed in the override). This seems like the best practice because it is clear, clean, simple, and of course DRY code. However, this makes Sedan, SUV, etc. tightly coupled to the Vehicle base class.
From the opposing view, if I used an interface then I would have to copy paste several lines to each class for its implementation despite the fact they are all the same. This would be a huge violation of DRY and then subsequently having to fix / update a method in all classes if the general behavior changes (i.e. more work and error prone).
From another opposing view, if I put methods like Drive, Reverse, etc. in a service-like class that accepts some form of an Vehicle I would have 2 major problems still.
- I would have to code the Sedan / SUV to a common interface still just to get a general parameter else I would have to use generics that would have to be constrained somehow (either interface which makes generics redundant in the first place or the overall class type which is not really ideal since I could pass any class to the method which is definitely not wise).
- The Sedan / SUV just depends on this otherwise extraneous dependency service class (and vice verse for the parameters, potentially). This is still tight coupling or rather still dependent.
From another point of view of the first problem, I could create an external service-like class for each vehicle type (i.e SedanService, SUVService, etc.) with the various methods, but this again just makes the services depend on their respective type which is actually what the dependency inversion principle aims to accomplish (at least I think). The problem of not having DRY code arises again because I just exchange putting the details in the actual vehicle type class to putting them in service class. This does not actually solve the problem but rather takes the titanic business strategy of "shuffle the deck chairs and hope the result is better".
With this example and the aforementioned points of view on using the interface / dependency inversion principle, I do not understand the benefits of coding to an interface or otherwise over using inheritance of a common abstract base class that holds the default implementation that should only need to be overrode in rare circumstances without affecting the base or other derivations. The major downside is tightly coupling of the base and derivative along with the potential of introducing brittle inheritance chains if the derivatives are ever inherited from (i.e. which is why I would make them sealed, but for the sake of the example, I did not).
With all of that, my questions are:
Am I misunderstanding the concept of "code to an interface and do not use inheritance" and/or the dependency inversion principle? (Am I misusing those two?) If so, what is the correct interpretation and examples / solution?
If not, is there another way to achieve dependency inversion / loose coupling that I am just not thinking (or aware) of / understanding?
If I am not misunderstanding "code to an interface", dependency inversion, and not unaware of a better solution, and utilizing inheritance correctly then why would inheritance be considered {insert negative and/or demeaning adjective here}? Is there a downside(s) that I am not considering?
Should DRY code and future maintainability be sacrificed for loose coupling for portability and scalability? Seems like a trade-off that is really steep to make without extreme and carefully considered calculations.
P.S.
I understand interfaces are generally for establishing a contract between something and a set of established characteristics and behaviors which culminate in them being a euphemism-like device for stating that an class "has a(n) {insert interface name/noun here}" relationship. Contrastingly, inheritance is that a class "is a(n) {insert base class name/noun here}" with respect to the base class and derivative class's relationship. This is how I am interpreting the terms, so this could be the source of my confusion, but I do not really think so.
