So I came across an old blog post from Robert Martin (Uncle Bob) that talks about how the Structured Programming discipline convinced programmers to take the GOTO
statement out of their code, even when its only implicit like in this example that he gave:
if (a>10)
b++;
else
b--;
He said that was bad practice because it basically would correlate to this code if written in FORTRAN:
IF (A-10) 20,20,30
20 B = B - 1
GOTO 40
30 B = B + 1
40 ...
To me, that makes sense. An If
block essentially acts like a GOTO
statement under the hood so why use it. (Of course, in the back of my mind, I'm thinking there's no way to get around some kind of JUMP
instruction in the underlying assembly language, which is basically a GOTO
statement, but I ignored that thought and moved on.)
But then he said:
you could restrict your program to three different control structures: Sequence, Selection, and Iteration
and that with a Selection
structure, you could write code like this:
if (someBooleanValue())
doThisStep();
else
doOtherStep();
That's supposed to be a better version of an If
block than the GOTO
version I mentioned above because it used a Selection
structure. However, I don't really see the difference between them. What is the fundamental difference?
The only thing I can figure is that is has something to do with what he said here:
Dijkstra's argument was that a structured program can be easily analyzed because the state of the system at any line of code, depends only on the boolean values being tested by selection and iteration, and the list of calling procedures on the stack.
Somehow it seems like there is a deeper principle here that I'm missing. I get that you can keep track of the state of a program using boolean variables but what does that have to do with these two If
blocks?
