Every day a couple of new javascript modules are created and published around the world and we need to think long term. Let's say today I need to use an ORM module to go smooth and fast. But tomorrow I may face a deprecated module or may find a better one to switch or even may need to create my own.
For example, the team have decided to use Sequelizejs on top of the Sqlite to provide the models:
const User = sequelize.define('user', {
  username: Sequelize.STRING
User.create({
    username: 'melbourne'
Then, a new type of database like Realm was introduced and they planned to switch:
class User {}
User.schema = {
  properties: {
    username: {type: 'string'}
let realm = new Realm({schema: [User]});
realm.write(() => {
  realm.create('User', {
So, this can lead to refactoring the entire application and the team needs an interface to present in front and ignore code rewriting. As a result, switching will be easy and changing the bindings will not affect the entire code.
class User  {
  define(name, dataTypes) {
    ThirdParty.define(name, dataTypes);
  create(data) {
    ThirdParty.create(data);
Regarding the example, what would be the good design pattern in javascript? How to bind an interface on top of third-party modules to develop the future-proofed and scalable apps?
Vahid Hallaji
  • 103
    Possible duplicate of [Are there any OO-principles that are practically applicable for Javascript?](https://softwareengineering.stackexchange.com/questions/180585/are-there-any-oo-principles-that-are-practically-applicable-for-javascript) – gnat Jul 13 '17 at 07:52
I don't think it is possible in general to provide a future-proof abstraction layer. Different libraries have different approaches to the same problem which means they may provide different abstractions.
Furthermore, the point of a library is to save you work. If you have to replicate the whole data model one-level above the ORM just to provide an abstraction layer, you introducing complexity with no benefit.
I think the best approach is to keep your code well-factored in general and follow principles of separation of concerns and single responsibility, but don't introduce layers to prepare for a library replacement which may not happen anyway. See the YAGNI principle.
JacquesB
  • 57,310
  • 127
  • 176
  • It's such a good advice. Thanks. Actually, my thought originates from other OOP languages where binding an interface as a contract to implementations makes the dependency injection with ease. So binding would tell the container that it should inject the module X when a class needs an implementation of that interface. So it would be very easy to change the binding to the new implementation. – Vahid Hallaji Jul 13 '17 at 08:42
    @hallaji: Yes changing the implementation is really easy if a shared interface is defined, but the hard part is defining a common interface which which could be adapted to all libraries. – JacquesB Jul 13 '17 at 10:03
