I'm in the process of writing a development philosophy document for a small groups of developers (6.5 developers to be specific), but it's ideally a document that will set down the company's best practices as our team scales up. In the process of creating this document I've been interviewing each engineer to understand their development processes, to make something that's a good mix of helpful in eliminating redundant work, and not overly prescriptive.
Most of the issues I've found there are pretty good solutions for, but there's something that I assume must be a common issue that I can't seem to find a good solution for. That's managing environment variables that are required for local development. For instance, we've got a development key for AWS. It's required to use a lot of functions and features within the application we're developing.
At present the process is pretty bad. Obviously we can't commit an env file to Github as it's sensitive information that we don't want the entire org to have access to. Right now we have a secure S3 file that contains the env file required for development.
We've found that there are a lot of issues both keeping this up-to-date both in terms new env variables making it into this file, and pulling this down during development. It's not very surprising since it's a single piece of the development cycle that's not a part of Github, and it's something that only has to be updated or accessed pretty rarely. That said, when people run into issues it can be very frustrating since realizing that you've got the wrong S3 key, or something isn't a standard kind of error-checking.
Are there any solutions for managing environment variables that people have found work particularly well? We had an employee write a repo that is the best solution we've currently got (https://github.com/sihrc/privvy), but is there something better?
EDIT: The reason why private repositories are not the solution for this problem (we're already using private repos)
These variables aren't limited to a single project. The development env file for instance is
Version-controlling this file would make development difficult or impossible. If we roll an API key, that's the API key that we need to use forever more. If you need to revert to an older revision and the key changes, that's a problem
It's not strange for us to have to add a third-party to a repo. It's VERY important that they be able to view the code, but not the credentials.
