Recently I started a project which didn't seem too hard to make, the concept was a fairly simple application that had to accept input every now and then (maybe 10x a day), and try to perform some operations on them and collect all results at the end. This application would then get a front-end web portal that customers could use to view the results, not exactly rocket science.
For this I initially made smart use of Python's built-in concurrency libraries (ThreadPoolExecutor
) and use an easy-to-use library for the front-end (I chose Flask as it's easy for beginners and is relatively easy to maintain and test).
Once we were halfway the project, the PM stated we had to use third party message queue capabilities instead of threads and had to implement load balancing, what eventually ended up happening was that we eventually started working with Celery, Redis, RabbitMQ, Nginx, uWSGI and a bunch of other large third party services which nobody had any real experience with.
In the end this lead to a bunch of spaghetti code, untestable tasks (because of the complexity of third party libraries, patching the code didn't even work) and a bunch of headaches because nobody even knew what the added value of these services were.
Before you say "Yes you should use those services", keep in mind nobody knows how to use these or even knows what they do besides introduce race-condition plagued code.
What should I do about this? At this point it would simply be too costly to revert back to what we had and the PM is dead-set on using these services, even though the end-product is now worse off than it was in the beginning. Is there even any use in discussing this with him? Do I ask for more time? Or the harsh answer, am I just too stupid for my job?
