53
I have heard a lot of times when other developers use that phrase to "advertise" some patterns or developing best practices. Most of the time this phrase is used when you are talking about benefits of functional programming.
The phrase "Easy to reason about" has been used as it is, without any explanation or code sample. So for me it becomes like the next "buzz"-word, which more "experienced" developers use in their talks.
Question: Can you provide some examples of "Not easy to reason about", so it can be compared with "Easy to reason about" examples?
Secespitus
  • 103
Fabio
  • 3,086
    If this is opinion based, then why this phrase used as a inexorable justification? – Fabio Jun 20 '17 at 09:12
    It sounds like a local phrase, I haven't heard it before. Maybe something that was pitched by someone in your company and got adopted. It does make sense though. If your model is good you can talk about your system., address building blocks. If there are no recognizable building blocks and/or no proper names were given to them, if the code is not well layered, it will be harder to talk/reason about. Because there is no common understanding of the design. – Martin Maat Jun 20 '17 at 09:21
    @MartinMaat a more precise phrase that is widely used is equational reasoning, i'd suggest that this might be what Fabio is after – jk. Jun 20 '17 at 11:51
    I like to use the phrase _"cognitive load"_ for this sort of thing. – Baldrickk Jun 20 '17 at 13:29
    Do you know what [reasoning about programs](https://en.wikipedia.org/wiki/Formal_verification) means? – Bergi Jun 20 '17 at 13:48
    Cross-site similar question: https://stackoverflow.com/questions/18666821/what-does-the-term-reason-about-mean-in-computer-science – Milo P Jun 20 '17 at 16:03
    In the non-formal sense, I use this to mean a solution is simple enough understand (generally) what the results will be for any given input without testing it. It means that for any set of inputs, the results will be unsurprising. Solutions that have non-obvious corner cases, for example, are hard to reason about. Mainly I use this in reference to robustness. – JimmyJames Jun 20 '17 at 16:31
    It sounds like the equivalent in the science/math world is to label something as "trivial". There was always a professor or two who would skip things in a lecture with a (literal) wave of the hand and a quick quip of "this part is trivial so you can figure it out later". It was always hard not to roll my eyes at that those. You've got some good definitions of "Easy to reason about" below, but I wouldn't take someone seriously who actually uses the phrase: the extent to which something is "easy" legitimately depends on the person/experience level. http://www.theproofistrivial.com/ – Conor Mancone Jun 20 '17 at 17:48
    I am very guilty of using "easier to reason about" frequently; I note however that I try to be careful to say the comparative *easier* rather than the absolute *easy*. There was a day in my life when I could reason about no software at all, so it was not *easy* on that day; it became easy only by spending a great deal of time and effort. To say that any programming problem is *easy* is taking a pejorative stance towards anyone who might not (yet) find it easy. To say that one model is *easier* than another is to say that there are fewer concepts involved, fewer moving parts, and so on. – Eric Lippert Jun 20 '17 at 18:40
    @MartinMaat, if you haven't heard it before, I suspect you haven't spent much time in the functional programming community over at least the last decade or so. (That said, within that community, there's a generally-accepted definition that is further from David's answer, and closer to Michael's; it has little to do with code style or variable naming, and much to do with determinism, state management, hidden inputs, functional purity, etc). – Charles Duffy Jun 20 '17 at 23:10
  • Advanced mathematics 101: "I couldn't solve the problem, so I changed it so it was a different problem and solved that. Then I changed it back and the solution still worked. Hurray, where's my Nobel prize? Oh they don't give Nobel prizes for mathematics? Someone should have told me that 20 years ago." And software engineering shares a lot with mathematics. – corsiKa Jun 21 '17 at 15:42
  • @Bergi That's sort of the problem though, people saying this (especially outside FP) often mean it in the colloquial way that David Arno describes. Is there any authoritative source that suggests the formal verification meaning is significantly more widespread or in some way more correct? – Ben Aaronson Jun 21 '17 at 16:26
  • @BenAaronson More widespread? Surely not, as every programmer does some intuitive reasoning when designing an algorithm, possibly without even having heard of formal verification. And I think it comes down to the same thing, our formalism are kinda intuitive as well, and need to get more advanced the more convoluted the program is. But yes, we need an axiomatic framework to even have a notion of "correctness", without a formal method we can believe in the intuitive solution but are unable to check it (or let a computer do the verification). – Bergi Jun 21 '17 at 16:45
  • For me personally, "Easy to reason about" -> Easy for others to understand the justification behind the choices I've made. For example, it's easy to "reason about" going to the gym, because everyone acknowledges that exercise is good for your health. – Mahn Jun 21 '17 at 18:44
    From https://fsharpforfunandprofit.com/posts/is-your-language-unreasonable/ - “reasoning about the code” means that you can draw conclusions using only the information that you have right in front of you, rather than having to delve into other parts of the codebase. – beluchin Jan 06 '19 at 02:24
11 Answers11
63
To my mind, the phrase "easy to reason about", refers to code that is easy to "execute in your head".
When looking at a piece of code, if it is short, clearly written, with good names and minimal mutation of values, then mentally working through what the code does is a (relatively) easy task.
A long piece of code with poor names, variables that constantly change value and convoluted branching will normally require eg a pen and piece of paper to help keep track of the current state. Such code therefore cannot be easily worked through just in your head, So such code isn't easy to reason about.
David Arno
  • 38,972
  • 88
  • 121
    With a slight caveat that no matter how well you name your variables, a program that tries to disprove Goldbach's conjecture is *inherently* difficult to "execute", in your head or elsewhere. But it can still be easy to reason about, in the sense of being easy to convince yourself that if it claims to have found a counter-example then it's telling the truth ;-) – Steve Jessop Jun 20 '17 at 13:22
    I would *never* want to execute code in my head. That, to me, would be the ultimate show of "not easy to reason about." I would want to be able to make predictive statements about what the computer would do *without* executing it. Code that is "easy to reason about" is code which doesn't have to be executed in your head, it can be reasoned about instead. – Cort Ammon Jun 21 '17 at 14:38
    How can one answer a question about *reasoning about code* without even mentioning *formal verification*? This answer suggest that reasoning about code is informal and ad-hoc. its not, its usually done with very great care and mathematical approaches. There are certain mathematical properties that make code "easy to reason about" in an objective sense (pure functions, to bring a very easy example). names of variables have *nothing* to do with how easy it is to "reason" about code, at least not in any formal sense. – Polygnome Jun 21 '17 at 15:30
    @Polygnome Reasoning about code is not usually done with very great care and mathematical approaches. As I write this, people reasoning about code informally are outnumbering the mathematical approachers by millions to one, at least, or so I reckon. – Kaz Jun 21 '17 at 17:57
    @Kaz Yeah, but this is quite a specific phrase. "Code easy to reason about" almost exclusively alludes to its mathematical properties and formal verifictaion. When I'm debugging my code I'm not "reasoning" about it, not really. – Polygnome Jun 21 '17 at 18:22
    @Polygnome `"Code easy to reason about" almost exclusively alludes to its mathematical properties and formal verification` - that roughly sounds like an answer to the question. You may want to post that as an answer instead of disagreeing about what the (subjective) answer is in the comments. – Bernhard Barker Jun 21 '17 at 19:48
  • @SteveJessop A program that tells you that it *hasn't* found a counterexample to Goldbach's conjecture could be doing so without justification. For such a program to be easy to reason about means that it's easy to convince ourselves that it's correctly searching for counterexamples for that conjecture, and not carrying out some other failing search that is unrelated to the conjecture. – Kaz Jun 21 '17 at 20:07
  • "Easy to reason about" isn't about mathematics and/or formal verification. As Kaz said, the majority of the time it just means understanding what this code is going to do, and being able to figure out what the output will be for a particular set of inputs. Typically the person doing the reasoning is coming back to code they themselves wrote in the past or trying to understand someone else's code, for the purpose of using it, modifying it or fixing a bug in it, not formally verifying it. The OP specifically mentions patterns and best practices for development, implying practicality not theory. – Caleb Mauer Jun 21 '17 at 20:23
  • @Kaz Good programmers are hard to come by. The fact those people are a minority says nothing about whether their code is easier to reason with. – 16807 Apr 16 '20 at 15:54
50
A mechanism or piece of code is easy to reason about when you need to take few things into account to predict what it will do, and the things you do need to take into account are easily available.
True functions with no side effects and no state are easy to reason about because the output is completely determined by the input, which is right there in the parameters.
Conversely, an object with state is much harder to reason about, because you have to take into account what state the object is in when a method is called, which means you have to think about which other situations could lead to the object being in a particular state.
Even worse are global variables: to reason about code that reads a global variable, you need to understand where in your code that variable could be set and why - and it may not even be easy to find all those places.
Just about the hardest thing to reason about is multithreaded programming with shared state, because not only do you have state, you have multiple threads changing it at the same time, so to reason about what a piece of code does when executed by one thread you have to allow for the possibility that at every single point of execution, some other thread (or several of them!) might be executing just about any other part of the code and change the data you're operating on right under your eyes. In theory, that can be managed with mutexes/monitors/critical sections/whatever-you-call-it, but in practice no mere human is actually able to do that reliably unless they drastically confine the shared state and/or parallelism to very small sections of the code.
Michael Borgwardt
  • 51,037
  • 124
  • 176
    I do agree with this answer, but even with pure functions, declarative approaches (like CSS, or XSLT, or `make` or even C++ template specialisation and function overloading) can put you back in the position of considering the whole program. Even once you think you've found the definition of something, the language allows a more specific declaration *anywhere in the program* to override it. Your IDE might help with this. – Steve Jessop Jun 20 '17 at 13:15
    I'd add that in the multithreaded scenario you also have to have a reasonably deep understanding of what lower level instructions your code desugars to: an operation that looks atomic in source might have unexpected interruption points in the actual execution. – Jared Smith Jun 20 '17 at 14:25
    @SteveJessop: Indeed, this point is often overlooked. There is a reason why C# makes you *say* when you want a method to be overridable rather than quietly making overridability the default; we wish to wave a flag saying "the correctness of your program might depend on code you can't find at compile time" at this point. (That said, I also wish that "sealed" was the default for classes in C#.) – Eric Lippert Jun 20 '17 at 18:43
  • @EricLippert What were the final reasons for `sealed` not being the default? – Zev Spitz Jun 21 '17 at 17:01
  • @ZevSpitz: That decision was made long before my time; I don't know. – Eric Lippert Jun 21 '17 at 17:15
In the case of functional programming, the meaning of “Easy to reason about” is mostly that it is deterministic. By that, I meant that a given input will always lead to the same output. You can do whatever you want to the program, as long as you don't touch that piece of code, it won't break.
On the other hand, OO is typically more difficult to reason about because the "output" produced depends on the internal state of every involved object. The typical way it manifests are unexpected side effects: when changing one part of the code, an appearingly unrelated part breaks.
...the downside of functional programming is of course that in practice, a lot of what you want to do is IO and managing state.
However, there are plenty of other things which are more difficult to reason about, and I agree with @Kilian that concurrency is a prime example. Distributed systems too.
dagnelies
  • 5,415
  • 26
I can provide an example, and a very common one.
Consider the following C# code.
// items is List<Item>
var names = new List<string>();
for (var i = 0; i < items.Count; i++)
    var item = items[i];
    var mangled = MyMangleFunction(item.Name);
    if (mangled.StartsWith("foo"))
        names.Add(mangled);
Now consider this alternative.
var names = items
    .Select(item => MyMangleFunction(item.Name))
    .Where(s => s.StartsWith("foo"))
    .ToList();
In the second example, I know exactly what this code is doing at a glance. When I see Select, I know a list of items is being convert into a list of something else. When I see Where, I know that certain items are being filtered out. At a glance, I can understand what names is and make effective use of it.
When I see a for loop, I have no idea what is going on with it until I actually read through the code. And sometimes I have to trace through it to be sure I have accounted for all the side effects. I have to do a bit of work to even come to understand what names is (beyond the type definition) and how to effectively use it. Thus, the first example is harder to reason about than the second.
Ultimately, being easy to reason about here also depends on understanding LINQ methods Select and Where. If you don't know them, then the second code is harder to reason about initially. But you only pay the cost to understand them once. You pay the cost to understand a for loop every time you use one and again every time it changes. Sometimes the cost is worth paying, but usually being "easier to reason about" is far more important.
Kasey Speakman
  • 4,341
  • 26
Avoiding wider discussion, and addressing the specific question:
I refer you to "The Story of Mel, a Real Programmer", a piece of programmer folklore that dates to 1983 and therefore counts as 'legend', for our profession.
It tells the tale of a programmer writing code that preferred arcane techniques wherever possible, including self-referential and self-modifying code, and deliberate exploitation of machine bugs:
an apparent infinite loop had in fact been coded in such a way as to take advantage of a carry-overflow error. Adding 1 to an instruction that decoded as "Load from address x" normally yielded "Load from address x+1". But when x was already the highest possible address, not only did the address wrap around to zero, but a 1 was carried into the bits from which the opcode would be read, changing the opcode from "load from" to "jump to" so that the full instruction changed from "load from the last address" to "jump to address zero".
This is an example of code that is 'hard to reason about'.
Of course, Mel would disagree...
AakashM
  • 2,107
The crux of programming is case analysis. Alan Perlis remarked on this in Epigram #32: Programmers are not to be measured by their ingenuity and their logic but by the completeness of their case analysis.
A situation is easy to reason about if the case analysis is easy. This either means that there are few cases to consider, or, failing that, few special cases—there might be some large spaces of cases, but which collapse due to some regularities, or succumb to a reasoning technique such as induction.
A recursive version of an algorithm, for instance, is usually easier to reason about than an imperative version, because it doesn't contribute superfluous cases which arise through the mutation of supporting state variables that don't appear in the recursive verison. Moreover, the structure of the recursion is such that it fits into a mathematical proof-by-induction pattern. We don't have to consider complexities like loop variants and weakest strict preconditions and whatnot.
Another aspect of this is the structure of the case space. It is easier to reason about a situation which has a flat, or mostly flat division into cases compared to a hierarchical case situation: cases with sub-cases and sub-sub cases and so on.
A property of systems which simplifies reasoning is orthogonality: this is the property that the cases which govern subsystems remain independent when those subsystems are combined. No combinations give rise to "special cases". If a four-case something is combined with a three-case something orthogonally, there are twelve cases, but ideally each case is a combination of two cases that remain independent. In a sense, there aren't really twelve cases; the combinations are just "emergent case-like phenomena" that we don't have to worry about. What this means is that we still have four cases that we can think about without considering the other three in the other subsystem, and vice versa. If some of the combinations have to be specially identified and endowed with additional logic, then the reasoning is more difficult. In the worst case, every combination has some special handling, and then there really are twelve new cases, which are in addition to the original four and three.
Kaz
  • 3,572
  • 30
A related phrase is (I paraphrase),
It's not enough for code to have "no obvious bugs": instead, it should have "obviously no bugs".
An example of relatively "easy to reason about" might be RAII.
Another example might be avoiding deadly embrace: if you can hold a lock and acquire another lock, and there are lots of locks, it's hard to be sure there's no scenario in which deadly embrace might occur. Adding a rule like "there is only one (global) lock", or, "you're not allowed to acquire a second lock while you hold a first lock", makes the system relatively easy to reason about.
ChrisW
  • 3,387
    Hmm. I'm not sure RAII is so easy to reason about. Sure, it's easy to understand *conceptually*, but it gets more difficult to actually reason about (i.e., predict) the *behavior* of code that makes extensive use of RAII. I mean, it's basically invisible function calls at scope level. The fact that plenty of people have trouble reasoning about this is very plain if [you've ever done any COM programming](https://blogs.msdn.microsoft.com/oldnewthing/20040520-00/?p=39243/). – Cody Gray - on strike Jun 21 '17 at 02:10
  • I meant relatively easy (C++ compared with C): for example the existence of a language-supported constructor means that programmers can't create/have/use an object which they forget to initialize, etc. – ChrisW Jun 21 '17 at 08:31
  • That COM-based example is problematic because it mixes styles, i.e. C++-style smart pointer (`CComPtr<>`) with C-style function (`CoUninitialize()`). I find it a bizarre example, too, so far as I remember you invoke CoInitialize/CoUninitialize at module scope and for the whole module lifetime, e.g. in `main` or in `DllMain`, and not in some tiny short-lived local function scope as shown in the example. – ChrisW Jun 21 '17 at 08:40
  • It is an overly simplified example for illustrative purposes. You're completely right that COM is initialized at module scope, but imagine Raymond's example (like Larry's example) as being the entry point (`main`) function for an application. You initialize COM at startup, and then you uninitialize it right before exiting. Except you have global objects, like COM smart pointers, using the RAII paradigm. Regarding mixing styles: a global object that initialized COM in its ctor and uninitialized in its dtor is workable, and what Raymond suggests, but it's subtle and not easy to reason about. – Cody Gray - on strike Jun 21 '17 at 11:27
  • I would argue that, in many ways, COM programming is easier to reason about in C, because everything is an explicit function call. There's nothing hidden or invisible going on behind your back. It is a bit more *work* (i.e., more tedious), because you have to manually write all those function calls and go back and check your work to see that you've done it correctly, but it's all laid bare, which is the key to making it easy to *reason* about. In other words, ["sometimes smart pointers are just too smart"](https://blogs.msdn.microsoft.com/ericlippert/2003/09/16/smart-pointers-are-too-smart/). – Cody Gray - on strike Jun 21 '17 at 11:31
  • Instead of adding extra `{` and `}` inside a function, it would be clearer to wrap the smart pointer's lifetime in a new subroutine, for example, `int main() { CoInitialize(); run(); CoUninitialize(); return 0; } void run() { CComPtr p; ... etc...; }` – ChrisW Jun 21 '17 at 11:37
  • Anyway, the examples I gave re. avoiding deadly embrace are examples of extra constraints which make the system easier to reason about (perhaps because the constraints are understandable). IMO C++ is not just more powerful (or feature-rich) compared with C, it's also more constrained (constructors, destructors, `const`, `throw`, etc.) have defined behaviour, and because it's defined it's constrained or able-to-be-reasoned-about ... unlike an equivalent mess of hand-coded C spaghetti. – ChrisW Jun 21 '17 at 11:43
The idea of functional languages being possible to reason about comes from their history, specifically ML which was developed as a programming language analogous to the constructs which the Logic for Computable Functions used for reasoning. Most functional languages are closer to formal programming calculii than imperative ones, so the translation from code into the input of a system of reasoning system is less onerous.
For an example of a reasoning system, in pi-calculus, each mutable memory location in an imperative language needs to be represented as a separate parallel process, whereas a sequence of functional operations is a single process. Forty years on from LFC theorem prover, we are working with GB of RAM so having hundreds of processes is less of an issue - I have used pi-calculus to remove potential deadlocks from a few hundred lines of C++, despite the representation having hundreds of processes the reasoner did exhaust the state space in around 3GB and cure an intermittent bug. This would have been impossible in the 70s or required a supercomputer in the early 1990s, whereas the state space of a functional language program of similar size was small enough to reason about back then.
From the other answers, the phrase is becoming a buzz-phrase even as though much of the difficulty which made it hard to reason about imperative languages is eroded by Moore's law.
Pete Kirkham
  • 1,798
Sure. Take concurrency:
Critical sections enforced by mutexes: easy to understand because there is only one principle (two threads of execution cannot enter the critical section simultaneously), but prone to both inefficiency and deadlock.
Alternative models, e.g. lock-free programming or actors: potentially much more elegant and powerful, but hellishly hard to understand, because you can no longer rely on (seemingly) fundamental concepts such as "now write this value to that place".
Being easy to reason about is one aspect of a method. But choosing which method to use requires considering all aspects in combination.
Kilian Foth
  • 107,706
  • 45
  • 295
  • 310
    -1: really, really bad example that makes me think you don't understand what the phrase means yourself. "Critical sections enforced by mutexes" are in fact one of the hardest things to reason about out there - pretty much everyone who uses them introduces race conditions or deadlocks. I'll give you lock-free programming, but the whole damn point of the actor model is that it is much, much easier to reason about. – Michael Borgwardt Jun 20 '17 at 12:26
    The problem is that concurrency is itself a very difficult topic for programmers to reason about, so it doesn't make for a very good example. You are completely correct that critical sections enforced by mutexes are a relatively simple way to implement concurrency, compared to lock-free programming, but most programmers are like Michael, and their eyes glaze over when you start talking about critical sections and mutexes, so this certainly doesn't seem like an easy thing to understand. Not to mention all the bugs. – Cody Gray - on strike Jun 20 '17 at 14:33
Let us limit the task to the formal reasoning. Because humoristic or inventional or poetic reasoning have different laws.
Even so, the expression is dimmly defined, and cannot be set in a strict manner. But it does not mean it should remain so dim for us. Let us imagine that a structure is passing some test and getting marks for different points. The good marks for EVERY point mean that the structure is convenient in every aspect and thus, "Easy to reason about".
The structure "Easy to reason about" should get good marks for the following:
  • Inner terms have reasonable, easily distinguished and defined names. If elements have some hierarchy, the difference between parent and child names should different from the difference between siblings names.
  • Number of types of structural elements is low
  • Used types of structural elements are easy things we are accustomed to.
  • The hardly understandable elements (recursions, meta steps, 4+ dimensional geometry...) are isolated - not directly combined with each other. (for example, if you'll try to think on some recursional rule changing for 1,2,3,4..n..dimensional cubes, it will be very complicated. But if you will thransfer each of these rules to some formula depending on n, you will have separately a formula for every n-cube and separately a recursion rule for such formula. And that two structures separately can be easily thought about)
  • Types of structural elements are obviously different (for example, not using mixed arrays starting from 0 and from 1)
Is the test subjective? Yes, naturally it is. But the expression itself is subjective, too. What is easy for one person, is not easy for another one. So, the tests should be different for the different domains.
Gangnus
  • 2,805
Easy to reason about is a culturally specific term, which is why it's so hard to come up with concrete examples. It is a term which is anchored to the people who are to do the reasoning.
"Easy to reason about" is actually a very self descriptive phrase. If one is looking at the code, and wants to reason what it does, it's easy =)
Okay, breaking it down. If you're looking at code, you usually want it to do something. You want to make sure that it does what you think it should do. So you develop theories on what the code should be doing, and then you reason about it to try to argue why the code does indeed work. You try to think about the code like a human (rather than like a computer) and try to rationalize arguments about what the code can do.
The worst case for "easy to reason" is when the only way to make any sense of what the code does is to go line-by-line through the code like a Turing machine for all inputs. In this case, the only way to reason anything about the code is to turn yourself into a computer and execute it in your head. These worst case examples are easily seen in obsfucated programming contests, such as these 3 lines of PERL which decrypt RSA:
#!/bin/perl -sp0777i<X+d*lMLa^*lN%0]dsXx++lMlN/dsM0<j]dsj
$/=unpack('H*',$_);$_=`echo 16dio\U$k"SK$/SM$n\EsN0p[lN*1
lK[d2%Sa2/d0$^Ixp"|dc`;s/\W//g;$_=pack('H*',/((..)*)$/)
As for easy to reason, again, the term is highly cultural. You have to consider:
  • What skills does the reasoner have? How much experience?
  • What sorts of questions might the reasoner have about the code?
  • how certain does the reasoner need to be?
Each of these affects "easy to reason about" differently. Take the skills of the reasoner as an example. When I started at my company, it was recommended that I develop my scripts in MATLAB because it is "easy to reason about." Why? Well, everyone in the company knew MATLAB. If I picked a different language, it would be harder for anyone to understand me. Nevermind that MATLAB's readability is atrocious for some tasks, simply because it wasn't designed for them. Later, as my career progressed, Python became more and more popular. Suddenly MATLAB code became "hard to reason about" and Python was the language of preference for writing code that was easy to reason about.
Also consider what idoms the reader may have. If you can rely on your reader to recognize a FFT in a particular syntax, it's "easier to reason about" the code if you stick to that syntax. It lets them look at the text file as canvas that you painted a FFT onto, rather than having to get into the nitty gritty details. If you're using C++, find out how much your readers are comfortable with the std library. How much do they like functional programming? Some of the idioms which come out of the containers libraries are very dependent on which idomatic style you prefer.
Its also important to understand what sorts of questions the reader may be interested in answering. Are your readers mostly concerned with superficial understanding of the code, or are they looking for bugs deep in the bowels?
How certain the reader has to be is actually an interesting one. In many cases, hazy reasoning is actually enough to get the product out the door. In other cases, such as FAA flight software, the reader is going to want to have ironclad reasoning. I ran into a case where I argued for using RAII for a particular task, because "You can just set it up and forget about it... it will do the right thing." I was told that I was wrong about that. Those who were going to reason on this code weren't the sort of people who "just want to forget about the details." For them, RAII was more like a hanging chad, forcing them to think about all the things that can happen when you leave scope. Those who were reading that code actually preferred explicit function calls at the end of the scope so that they could be confident that the programmer thought about it.
Cort Ammon
  • 10,840
  • 32
    The Perl code is hard to *read*; not *reason* about. If I had some stake in having to understand it, I would de-obufscate the code. Code that is actually hard to reason about is that which is still hard to reason about when it is nicely formatted with clear identifiers for everything, and no code golfing tricks. – Kaz Jun 21 '17 at 02:04
