Based on this Question and its answer :
Object in Business layer same as DTO with logic?
I want to ask :
What if instead of DAL, I'm getting data from a remote service (API) through DTOs. My DTOs here represent prettymuch the business objects with all the relationships in between. Although there is BOs in the API that I'm calling I cannot put the behavior that I need there as it is specific for me. How can I deal with this ?
if no behavior on DTO so what ? This look crappy
(API) <--DTO--> (mappingService) <--Domain object--> (domainService) <--DTO--> (UI) ??
Mohamed Amine Mrad
  • 733
  • Are you using an anemic or rich domain? – candied_orange Jun 10 '17 at 01:21
  • If your system doesn't need rich domain data models, because it's a mere proxy between UI and 3rd party services. Why do you care about the business? The schema you have suggested makes sense. Your system acts like a integration facade. – Laiv Jun 10 '17 at 12:50
There are several architectural patterns for your choice:
  • The DTO is a distribution pattern and aims to transfer data between processes and remote services. The goal is to reduce the number of interprocess function/method calls that are inefficient when crossing the boundaries of a single process.
  • The domain model object leaves transfer and persistance to a data gateway or a mapper.
  • The active record is a mix between both. It aims at encapsulating data access together with domain logic.
Basically, combining your DTO with domain logic looks pretty much like an active record. It's a viable solution if your domain model is simple and if the domain object is very close to the DTO.
However, be aware of its major drawbacks :
  • you no longer benefit from the decoupling offered by the DTO. A DTO isolates your internal domain model, from the back-end implementation, and let each of it evolve at its own pace.
  • it's not really aligned with the clean design principle of single responsibility
And attention: use it only if the domain model is simple. It's not a good idea if one object is simple but the whole model would be rather complex, because active records raise a lot of issues if you'd need to combine it with unit of work, an identity map or other patterns of enterprise application architecture.
Christophe
  • 74,672
  • 115
  • 187
