Context
I want to design a procedure or system task to load into a database, data that's needed by the system in order to work. The easiest example I can come up with is a ACL (or RBAC, not sure which one is the right term) where an user need permission to perform certain actions (create a resource, view a resource, view a scoped list, view a global list).
In this example, as a basic schema we'd have a user N:M role N:M permission
relationship model.
The permission
table contains a column (let's say name
) with a value that the system will use to determine the permission needed to perform this action:
if loggedUser.can('reports.view.global')
reports = reportsRepo.all()
else
reports = reportsRepo.allForDepartment(loggedUser.department)
end
Since the system is dependant on these "hard coded" values, they need to be in sync with the database on each deploy. Meaning, if the next release will add 2 new features (with 2 new permissions) and delete 1 feature (with 1 permission), the deploy task should be updating the database to keep it in sync with the permissions that the next version works with.
Questions
Having explained that, I also want to take in consideration I'm not falling under the XY Problem and that this is actually the correct approach for this problem:
- Should these kind of system data (not sure if the concept itself has a name) be stored in a database (for query-ability purposes) or is there a better standard way?
- Is a cli task that checks for those system data values (in some config file) and sync them with the
permission
table (adding or deleting rows) a good approach, or is it not due to some reason I'm failing to see at the moment?
I've never seen an implementation of this common scenario before, so I'm wondering whether there's already a standard approach for this particular problem (maybe it's even named and I just have to google it but I don't know it's name...)?
