I often create programs both for myself and others using various object-oriented programming languages. When doing so, they are usually relatively small (a few thousand lines at most). Recently, however, I have been attempting to get into making larger projects, such as complete game engines. When doing so, I often seem to run into a road block: complexity.
In my smaller projects, it is easy to remember a mental map of how every part of the program works. Doing this, I can be fully aware of how any change will effect the rest of the program and avoid bugs very effectively as well as see exactly how a new feature should fit into the code base. When I attempt to create larger projects, however, I find it impossible to keep a good mental map which leads to very messy code and numerous unintended bugs.
In addition to this "mental map" issue, I find it hard to keep my code decoupled from other parts of itself. For example, if in a multiplayer game there is a class to handle the physics of player movement and another to handle networking, then I see no way to have one of these classes not rely on the other to get player movement data to the networking system to send it over the network. This coupling is a significant source of the complexity that interferes with a good mental map.
Lastly, I often find myself coming up with one or more "manager" classes that coordinate other classes. For example, in a game a class would handle the main tick loop and would call update methods in the networking and player classes. This goes against a philosophy of what I have found in my research that each class should be unit-testable and usable independently of others, since any such manager class by its very purpose relies on most of the other classes in the project. Additionally, a manager classes orchestration of the rest of the program is a significant source of non-mental-mappable complexity.
Taken together, this prevents me from writing high-quality bug free software of a substantial size. What do professional developers do to effectively deal with this problem? I am especially interested in OOP answers target at Java and C++, but this sort of advice is probably very general.
Notes:
  • I have tried using UML diagrams, but that only seems to help with the first problem, and even then only when it is in regard to class structure rather than (for example) ordering of method calls with regard to what is initialized first.
john01dav
  • 879
    "When trading stocks, how do I make as much money as possible?" -- same question, different occupation. –  Jun 04 '17 at 18:59
  • @MaxB If you're saying that my question is very broad, can you provide some actionable advice on how I can make it more specific? It seems fairly specific to me: I am explaining a specific problem I often encounter and asking for a way to solve it. – john01dav Jun 04 '17 at 19:01
    How much time do you spend on design and modelling? Many of the troubles we stumble upon during the development comes from leak of perspective. The sort of perspective we focus on during the modelling. Then later we try to solve this leak with code. Code that also leak of perspective (the proper abstraction). Large scale projects need planification, to have clear the global picture. From the level of the codebase is going to be hard to have the vision. "*Don't let the trees stop you from seeing the forest*". – Laiv Jun 04 '17 at 19:34
  • @Laiv I normally spend a few minutes thinking about how I am going to structure it, while refactoring constantly if my original structure turns out not to fit. I tried making a UML diagram, but when I did so the diagram's model wasn't any better than the results of my few minutes of thinking with the same lack of mental map and constant refactoring necessity. – john01dav Jun 04 '17 at 19:35
    Modularization and isolation. But it seems you are already doing that, but failing at it. In which case, it really depends on what kind of project it is and what kind of technologies are used. – Euphoric Jun 04 '17 at 19:36
    Constant refactoring is a necessary part of software development - consider it an indication that you're doing something right. Any non-trivial system always contains "unknown unknowns" - i.e. the things which you couldn't have possibly foreseen nor accounted for in your original design. Refactoring is the reality of iterative development and incrementally evolving towards a 'good' solution. Its the reason why developers tend to favour writing code which is easy to refactor, which often involves following [S.O.L.I.D Principles](https://en.wikipedia.org/wiki/SOLID_(object-oriented_design)) – Ben Cottrell Jun 04 '17 at 19:40
  • UML are not the Holy Grail. As you may know there are different diagrams that addresses different stages (and levels of abstraction) of the project. When modeling large projects. Which of these diagrams do you tend to use first? If you start by class diagrams or sequence diagrams, It's like starting with code directly. – Laiv Jun 04 '17 at 19:45
  • @Euphoric I am mostly interested in games and other graphical utilities, networking utilities, and websites. – john01dav Jun 04 '17 at 19:52
  • @Laiv I am not aware of any such diagrams. If I am writing a diagram, I always jump straight to UML. I have also tried writing a document that describes exactly what I want the project to do from an end-user's perspective, and that was useful but it was far from getting anywhere close to solving this problem. It sounds like there may be something in-between. I tried looking around Google for some of these, but all I am finding is stuff on UML or some other diagram that does the same thing. – john01dav Jun 04 '17 at 19:54
  • @john01dav Then you should ask how to properly architect/modularize such applications. – Euphoric Jun 04 '17 at 19:55
    UML is a modelling language with several diagrams. If you are unaware of that then you are using "the language" inadequately and that explain why it doesn't help you. – Laiv Jun 04 '17 at 19:56
  • @Laiv It seems like I have a lot of research to do then, and it sounds like these higher level diagrams are very useful. It sounds like it may be a significant part of a good answer. Thanks :) – john01dav Jun 04 '17 at 20:00
  • Excusme If I sound simplistic but: "dive and conquer". Turn a big problem into many but smaller. The way to do so is with planification. The plan will lead you to the modelling and so on till reach the lower level of details. Be your own architectect and then the developer. Don't mix up both roles :-). Come here with narrowed questions and I'm sure is going to be easier to help you out. – Laiv Jun 04 '17 at 20:04
    UML IMHO lacks the most useful kind of diagram type for this: data flow diagrams. However, that is not a silver bullet, modularization and isolation don't come automatically by using data flow diagrams. – Doc Brown Jun 05 '17 at 06:46
There are entire books written on this subject. Here is a quote from one of the most important books ever written on software development, Steve McConnell's Code Complete:
Managing complexity is the most important technical topic in software development. In my view, it's so important that Software's Primary Technical Imperative has to be managing complexity.
As an aside, I would highly recommend reading the book if you have any interest in software development at all (which I assume you do, since you've asked this question). At the very least, click on the link above and read the excerpt about design concepts.
In this particular case, I would consider your PlayerMovementCalculator class and your NetworkSystem class to be completely unrelated to each other; one class is responsible for calculating player movement, and the other is responsible for network I/O. Perhaps even in separate independent modules.
However I would certainly expect there to be at least some additional bit of wiring or glue somewhere outside of those modules which mediates data and/or events/messages between them. For example, you might write a PlayerNetworkMediator class using the Mediator Pattern.
Another possible approach might be to de-couple your modules using an Event Aggregator.
In the case of Asynchronous programming such as the type of logic involved with network sockets, you might use expose Observables to tidy up the code which 'listens' to those notifications.
Asynchronous programming doesn't necessarily mean multi-threaded either; its more about program structure and flow control (although multi-threading is the obvious use-case for asynchrony). Observables may be useful in one or both of those modules to allow unrelated classes to subscribe to change notifications.
For example:
  • NetworkMessageReceivedEvent
  • PlayerPositionChangedEvent
  • PlayerDisconnectedEvent
etc.
While some of this certainly comes down to experience; the name Manager in a class often indicates a design smell.
When naming classes, consider the functionality that class is responsible for, and allow your class names to reflect what it does.
The problem with Managers in code, is a bit like the problem with Managers in the workplace. Their purpose tends to be vague and poorly understood even by themselves; most of the time we're just better off without them altogether.
Object-Oriented programming is primarily about behaviour. A class is not a data entity, but a representation of some functional requirement in your code.
If you can name a class based on the functional requirement it fulfils, you'll reduce your chance of ending up with some kind of bloated God Object, and are more likely to have a class whose identity and purpose in your program is clear.
Furthermore, it should be more obvious when extra methods and behaviour start creeping in when it really doesn't belong, because the name will start to look wrong - i.e. you'll have a class which is doing a whole bunch of things which aren't reflected by its name
Lastly, avoid the temptation of writing classes whose names look like they belong in an entity relationship model. The problem with class names such as Player, Monster, Car, Dog, etc. is that the imply nothing about their behaviour, and only seem to describe a collection of logically related data or attributes. Object-oriented design isn't data modelling, its behaviour modelling.
For example, consider two different ways of modelling a Monster and Player calculating damage:
class Monster : GameEntity {
    dealDamage(...);
class Player : GameEntity {
    dealDamage(...);
The problem here is that you might reasonably expect Player and Monster to have a whole bunch of other methods which are probably totally unrelated to the amount of damage these entities might do (Movement for example); you're on the path to the God Object mentioned above.
A more naturally Object-Oriented approach is to identify the name of the class based on its behaviour, for example:
class MonsterDamageDealer : IDamageDealer {
    dealDamage(...) { }
class PlayerDamageDealer : IDamageDealer {
    dealDamage(...) { }
With this type of design, your Player and Monster objects probably don't have any methods associated with them because those objects contain the data needed by your whole application; they are probably just simple data entities which live inside a repository and only contain fields/properties.
This approach is usually known as Anemic Domain Model, which is considered an anti-pattern for Domain-Driven-Design (DDD), but the S.O.L.I.D principles naturally lead you toward a clean separation between 'shared' data entities (perhaps in a repository), and modular (preferably stateless) behavioural classes in your application's object graph.
SOLID and DDD are two different approaches to OO design; while they cross-over in many ways, they tend to pull in opposing directions with regards to class identity and separation of data and behaviour.
Going back to McConnell's quote above - managing complexity is the reason why software development is a skilled profession rather than a mundane clerical chore. Before McConnell wrote his book, Fred Brooks wrote a paper on the subject which neatly sums up the answer to your question - There is No Silver Bullet to managing complexity.
So while there's no single answer, you can make life easier or harder for yourself depending on the way you approach it:
  • Remember KISS, DRY and YAGNI.
  • Understand how to apply the S.O.L.I.D Principles of OO Design/Software Development
  • Also understand Domain-Driven Design even if there are places where the approach conflicts with SOLID principles; SOLID and DDD tend to agree with each other more than they disagree.
  • Expect your code to change - write automated tests to catch the fallout of those changes (You don't have to follow TDD in order to write useful automated tests - indeed, some of those tests might be integration tests using "throwaway" console apps or test harness apps)
  • Most importantly - be pragmatic. Don't slavishly follow any guidelines; the opposite of complexity is simplicity, so if in doubt (again) - KISS
Ben Cottrell
  • 11,656
  • 30
  • 41
    Solid answer. Pun intended. – ipaul Jun 04 '17 at 21:43
    I disagree that DDD and SOLID are in disagreement with each other. I think they are quite complementary in fact. Part of why they may seem contradictory, or perhaps orthogonal, is that they describe different things at a different level of abstraction. – RibaldEddie Jun 05 '17 at 00:32
    @RibaldEddie I agree they are complementary for the most part; the main issue I see is that SOLID seems to actively encourage the so-called "Anemic" domain model as a natural consequence of taking SRP to its logical conclusion of a true single-responsibility-per-class, whereas DDD calls that an anti-pattern. Or perhaps there's something about Fowler's description of Anemic Domain Model that I've mis-interpreted? – Ben Cottrell Jun 05 '17 at 09:41
I think it is about managing complexity, which always drops down when the things around you become too complex to still manage with what you currently have and probably occurs a couple of times when growing from a 1 man company to a half a million persons global enterprise.
In general complexity grows when your project grows. And in general at the moment that complexity becomes to much (independent if it is IT or managing the program, programs or the complete enterprise) you need more tools or replace tools with tools that handle complexity better that is what humanity has done since forever. And tools go hand in hand with complexer processes, since someone needs to output something that someone else needs to work on. And those go hand in hand with " extra persons " who have specific roles e.g. an Enterprise Architect who is not needed with a 1 person project at home.
At the same time your taxonomy behind it must grow behind your complexity until the moment comes that taxonomy is too complex and you push over to unstructured data. E.g. you can make a list of websites and categorize them but if you need have a list of 1 billion websites there is no way to do this within a reasonable time so you go to smarter algorithms or just search through data.
In a small project you can work on a shared drive. On a somewhat large project you install .git or .svn or whatever. On a complex program with multiple projects which all have different releases which all are live and all have different release dates and all have dependencies on other systems you might need to switch to clearcase if you are responsible for configuration management of it all instead of merely versioning some branches of a project.
So I think the best effort of humans until now is a combination of tools, specific roles, processes to manage the increasing complexity of about everything.
Luckily there are companies who sell business frameworks, process frameworks, taxonomies, data models, etc, so depending on the industry you are in you can buy, when complexity has grown so large that everyone acknowledges that there is no other way, a data-model and process out of the box for e.g. a global insurance company, from there you work your way down to refactor your existing applications to bring everything in line again with the general proven framework which already includes a proven data-model and processes.
If there is none in the market for you industry perhaps there is an opportunity :)
edelwater
  • 544
  • It seems like you are basically suggesting some combination of "hire people" or "buy something that will make your problems go away™" I am interested in a managing complexity as an individual developer with no budget working on hobby projects (for now). – john01dav Jun 04 '17 at 19:41
  • I think on that level probably your question is something like " name 100 best practices a good application architect applies" ? Because I think in essence he is managing complexity behind everything he does. he sets standards to battle complexity. – edelwater Jun 04 '17 at 19:45
  • That is kindof what I am asking, but I am more interested in a general philosophy than a list. – john01dav Jun 04 '17 at 19:50
  • Its a broad question since there are 21.000+ books on application architecture practices/patterns/design etc: https://www.safaribooksonline.com/search/?query=application%20architecture – edelwater Jun 04 '17 at 19:50
  • Book could only shows popularity of a question, not broadness of good answers. If you think it takes a book to answer this question, then by all means make a recommendation. – john01dav Jun 04 '17 at 19:51
  • I would not know where to start e.g. https://www.safaribooksonline.com/library/view/patterns-of-enterprise/0321127420/ – edelwater Jun 04 '17 at 19:55
  • Make recommendations is off-topic here :-( – Laiv Jun 04 '17 at 19:58
What a mother lode of a question! I might embarrass myself attempting this one with my quirky thoughts (and I would love to hear suggestions if I'm really off). But for me the most useful thing I've learned lately in my domain (which included gaming in the past, now VFX) has been to replace interactions between abstract interfaces with data as a decoupling mechanism (and ultimately reduce the amount of information required between things and about each other to the absolute barest of minimums). This might sound completely insane (and I might be using all sorts of poor terminology).
Yet let's say I give you a reasonably manageable job. You have this file containing scene and animation data to render. There's documentation covering the file format. Your only job is to load the file, render pretty images for the animation using path tracing, and output the results to image files. That's a pretty small scale application that's probably not going to span more than tens of thousands of LOC even for a pretty sophisticated renderer (definitely not millions).
You have your own little isolated world for this renderer. It isn't affected by the outside world. It isolates its own complexity. Beyond the concerns of reading this scene file and outputting your results to image files, you get to focus entirely on just rendering. If something goes wrong in the process, you know it's in the renderer and nothing else, since there is nothing else involved in this picture.
Meanwhile let's say instead that you have to make your renderer work in the context of a big animation software which actually does have millions of LOC. Instead of just reading a streamlined, documented file format to get at the data necessary for rendering, you have to go through all kinds of abstract interfaces to retrieve all the data you need to do your thing:
Suddenly your renderer is no longer in its own little isolated world. This feels so, so much more complex. You have to understand the overall design of a whole lot of the software as one organic whole with potentially many moving parts, and maybe even sometimes having to think about implementations of things like meshes or cameras if you hit a bottleneck or a bug in one of the functions.
Functionality vs. Streamlined Data
And one of the reasons is because functionality is much more complex than static data. There are also so many ways a function call could go wrong in ways that reading static data cannot. There are so many hidden side effects that could occur when calling those functions even though it's conceptually just retrieving read-only data for rendering. It can also have so many more reasons to change. A few months from now, you might find the mesh or texture interface changing or deprecating parts in ways that requires you to rewrite hefty sections of your renderer and keep up with those changes, even though you're fetching the exact same data, even though the data input to your renderer hasn't changed whatsoever (only the functionality required to ultimately access it all).
So when possible, I've found that streamlined data is a very good decoupling mechanism of a kind that really lets you avoid having to think about the entire system as a whole and lets you just concentrate on one very specific part of the system to make improvements, add new features, fix things, etc. It's following a very I/O mindset for the bulky pieces that make up your software. Input this, do your thing, output that, and without going through dozens of abstract interfaces end endless function calls along the way. And it's starting to resemble, to some degree, functional programming.
So this is just one strategy and it may not be applicable for all people. And of course if you're flying solo, you still have to maintain everything (including the format of the data itself), but the difference is that when you sit down to make improvements to that renderer, you can really just focus on the renderer for the most part and nothing else. It becomes so isolated in its own little world -- about as isolated as it could be with the data it requires for input being so streamlined.
And I used the example of a file format but it doesn't have to be a file providing the streamlined data of interest for input. It could be an in-memory database. In my case it's an entity-component system with the components storing the data of interest. Yet I've found this basic principle of decoupling towards streamlined data (however you do it) so much less taxing on my mental capacity than previous systems I worked on which revolved around abstractions and lots and lots and lots of interactions going on between all these abstract interfaces which made it impossible to just sit down with one thing and think only about that and little else. My brain filled to the brink with those previous types of systems and wanted to explode because there were so many interactions going on between so many things, especially when something went wrong in a completely different area than what I was trying to focus on between all these abstract function calls.
Decoupling
If you want to minimize how much larger codebases tax your brain, then make it so each hefty part of the software (a whole rendering system, a whole physics system, etc) lives in the most isolated world possible. Minimize the amount of communication and interaction that goes on to the barest of minimums through the most streamlined data. You might even accept some redundancy (some redundant work for the processor, or even for yourself) if the exchange is a far more isolated system that doesn't have to talk to dozens of other things before it can do its work.
And when you start doing that, it feels like you're maintaining a dozen small-scale applications instead of one gigantic one. And I find that so much more fun too. You can sit down and just work on one system to your heart's content without concerning yourself with the outside world. It just becomes inputting the right data and outputting the right data at the end to some place where other systems can get at it (at which point some other system might input that and do its thing, but you don't have to care about that when working on your system). Of course you still have to think about how everything integrates in the user interface, for example (I still find myself having to think about everything's design as a whole for GUIs), but at least not when you sit down and work on that existing system or decide to add a new one.
Perhaps I'm describing something obvious to people who keep up-to-date with the latest engineering methods. I don't know. But it wasn't obvious to me. I wanted to approach the design of software around objects interacting with each other and functions being called for large-scale software. And the books I read originally on large-scale software design focused on interface designs above things like implementations and data (the mantra back then was that implementations don't matter so much, only interfaces, because the former could be easily swapped out or substituted). It didn't come intuitively to me at first to think about a software's interactions as boiling down to just inputting and outputting data between huge subsystems that barely talk to each other except through this streamlined data. Yet when I started to shift my focus to designing around that concept, it made things so much easier. I could add so much more code without my brain exploding. It felt like I was building a shopping mall instead of a tower which could come toppling down if I added too much or if there was a fracture in any one part.
Complex Implementations vs. Complex Interactions
This is another one I should mention because I spent a good portion of my early part of my career seeking out the simplest implementations. So I decomposed things into the teeniest and simplest bits and pieces, thinking I was improving maintainability.
In hindsight I failed to realize I was exchanging one type of complexity for another. In reducing everything down to the simplest bits and pieces, the interactions that went on between those teeny pieces turned into the most complex web of interactions with function calls that sometimes went 30 levels deep into the callstack. And of course, if you look at any one function, it's so, so simple and easy to know what it does. But you're not getting much useful information at that point because each function is doing so little. You then end up having to trace through all sorts of functions and jump through all sorts of hoops to actually figure out what they all add up to doing in ways that can make your brain want to explode more than one bigger, more complex thing which centralizes and isolates its complexity instead of scattering it about all over the place.
That's not to suggest god objects or anything like that. But perhaps we don't need to dice up our mesh objects into the tiniest things like a vertex object, edge object, face object. Maybe we could just keep it at "mesh" with a moderately more complex implementation behind it in exchange for radically fewer code interactions. I can handle a moderately complex implementation here and there. I can't handle a gazillion interactions with side effects occurring who-knows-where and in what order.
At least I find that much, much less taxing on the brain, because it's the interactions that make my brain hurt in a large codebase. Not any one specific thing.
Generality vs. Specificity
Maybe tied to the above, I used to love generality and code reuse, and used to think the biggest challenge of designing a good interface was fulfilling the widest range of needs because the interface would be used by all sorts of different things with different needs. And when you do that, you inevitably have to think about a hundred things at once, because you're trying to balance the needs of a hundred things at once.
Generalizing things takes so much time. Just look at the standard libraries that accompany our languages. The C++ standard library contains so little functionality, yet it requires teams of people to maintain and tune with whole committees of people debating and making proposals about its design. That's because that little teeny bit of functionality is trying to handle the entire world's needs.
Perhaps we don't need to take things so far. Maybe it's okay to just have a spatial index that's only used for collision detection between indexed meshes and nothing else. Maybe we can use another one for other kinds of surfaces, and another one for rendering. I used to get so focused on eliminating these kinds of redundancies, but part of the reason was because I was dealing with very inefficient data structures implemented by a wide range of people. Naturally if you have an octree that takes 1 gigabyte for a mere 300k triangle mesh, you don't want to have yet another one in memory.
But why are the octrees so inefficient in the first place? I can create octrees that only take 4 bytes per node and take less than a megabyte to do the same thing as that gigabyte version while building in a fraction of the time and doing faster search queries. At that point some redundancy is totally acceptable.
Efficiency
So this is only relevant to performance-critical fields but the better you get at things like memory efficiency, the more you can afford to waste a bit more (maybe accept a bit more redundancy in exchange for reduced generality or decoupling) in favor of productivity. And there it helps to get pretty good and comfy with your profilers and learn about computer architecture and the memory hierarchy, because then you can afford to make more sacrifices to efficiency in exchange for productivity because your code is already so efficient and can afford to be a little less efficient even in the critical areas while still outperforming the competition. I've found that improving in this area has also allowed me to get away with simpler and simpler implementations, since before I was trying to compensate for my lack of skills in micro-efficiency with more and more complex algorithms and data structures (and the latter yields much, much more complex code than more straightforward data structures that are just really efficient with memory layouts and access patterns).
Reliability
This is kind of obvious but might as well mention it. Your most reliable things require the minimum intellectual overhead. You don't have to think much about them. They just work. As a result the bigger you grow your list of ultra reliable parts that are also "stable" (don't need to change) through thorough testing, the less you have to think about.
Specifics
So all of that above covers some general things that have been helpful to me, but let's move on to more specific aspects for your area:
For me this tends to be related to complex side effects and complex control flows. That's a rather low-level view of things but all the nicest-looking interfaces and all the decoupling away from the concrete to the abstract cannot make it any easier to reason about complex side effects occurring in complex control flows.
Simplify/reduce the side effects and/or simplify the control flows, ideally both. and you'll generally find it so much easier to reason about what much bigger systems do, and also what will happen in response to your changes.
Conceptually you have to have some coupling. When people talk about decoupling, they usually mean replacing one kind with another, more desirable kind (typically towards abstractions). To me, given my domain, the way my brain works, etc. the most desirable kind to reduce the "mental map" requirements to a bare minimum is that streamlined data discussed above. One black box spits out data that gets fed into another black box, and both completely oblivious about each other's existence. They're only aware of some central place where data is stored (ex: a central filesystem or a central database) through which they fetch their inputs, do something, and spit out a new output which some other black box might then input.
If you do it this way, the physics system would depend on the central database and the networking system would depend on the central database, but they wouldn't know a thing about each other. They wouldn't even have to know each other exist. They wouldn't even have to know that abstract interfaces for each other exist.
You tend to need something to orchestrate all the systems in your game. Central is maybe at least less complex and more manageable than like a physics system invoking a rendering system after it's done. But here we inevitably need some functions being called, and preferably they're abstract.
So you might create an abstract interface for a system with an abstract update function. It can then register itself with the central engine and your networking system can say, "Hey, I'm a system and here is my update function. Please call me from time to time." And then your engine can loop through all such systems and update them without hard-coding function calls to specific systems.
That allows your systems to live more in like their own isolated world. The game engine doesn't have to know about them specifically (in a concrete way) anymore. And then your physics system might have its update function called, at which point it inputs the data it needs from the central database for everything's motion, applies physics, then outputs the resulting motion back.
After that your networking system might have its update function called, at which point it inputs the data it needs from the central database and outputs, say, socket data to clients. Again the goal as I see it is to isolate each system as much as possible so that it can live in its own little world with minimal knowledge of the outside world. That's basically the kind of approach adopted in ECS that's popular among game engines.
ECS
I guess I should cover ECS a little since a lot of my thoughts above revolve around ECS and trying to rationalize why this data-oriented approach to decoupling has made maintenance so much easier than the object-oriented and COM-based systems I've maintained in the past in spite of violating just about everything I held sacred originally that I learned about SE. Also it might make a lot of sense for you if you're into trying to build larger-scale games. So ECS works like this:
And as in the above diagram, the MovementSystem might have its update function called. At this point it might query the central database for PosAndVelocity components as the data to input (components are just data, no functionality). Then it might loop through those, modify the positions/velocities, and effectively output the new results. Then the RenderingSystem might have its update function called, at which point it queries the database for PosAndVelocity and Sprite components, and outputs images to the screen based on that data.
All the systems are completely oblivious about each other's existence, and they don't even need to understand what a Car is. They only need to know specific components of each system's interest that make up the data required to represent one. Each system is like a black box. It inputs data and outputs data with minimal knowledge of the outside world, and the outside world also has minimal knowledge of it. There might be some event pushing from one system and popping from another so that, say, the collision of two entities in the physics system can cause the audio to see a collision event that causes it to play sound, but the systems can still be oblivious about each other. And I've found such systems so much easier to reason about. They don't make my brain want to explode even if you have dozens of systems, because each one is so isolated. You don't have to think about the complexity of everything as a whole when you zoom in and work on any given one. And because of that, it's also very easy to predict the results of your changes.
Stop writing everything OOP and add some services instead.
For example, I was recently writing a GOAP for a game. You'll see the examples on the internet couple thier actions to the game engine with the OOP style:
Action.Process();
In my case I needed to process actions both in the engine and also outside of the engine, simulating actions in a less detailed way where the player is not present. So instead I used:
Interface IActionProcessor<TAction>
    void ProcessAction(TAction action);
this allows me to decouple the logic and have two classes.
ActionProcesser_InEngine.ProcessAction()
ActionProcesser_BackEnd.ProcessAction()
Its not OOP, but it means that the actions now have no link to the engine. Thus my GOAP module is completely separate from the rest of the game.
Once its finished I just use the dll and don't think about the internal implementation.
Ewan
  • 70,664
  • 76
  • 161
    How is your action processor not object-oriented? – Greg Burghardt Jun 04 '17 at 19:21
    I think your point is: “Don't try to produce an OOP design, because OOP is only one of many techniques to tackle complexity – something else (e.g. a procedural approach) might work better in your case. It doesn't matter how you get there, as long as you have clear module boundaries that abstract over implementation details.” – amon Jun 04 '17 at 19:35
    I think the problem is not at code level. It's at higher levels. The problems with the codebase are sympoms not illness. The solution won't come from the code. I think it will come from the design and the modelling. – Laiv Jun 04 '17 at 20:14
    If I read this imagining myself as the OP, i find this answer lacking in details and not providing any useful information, as it doesn't describe how the IActionProcessor actually provides value instead of just adding another layer of indirection. – whatsisname Jun 04 '17 at 20:27
  • using services like this is procedural rather than OO. This provides clearer separation between responsibilities than OO, which as the OP has found can quickly become overly coupled – Ewan Jun 04 '17 at 22:37
