Background
I'm working in a team that's looking to implement zero-downtime deployments. We're planning on using a blue/green deployment strategy in order to achieve this. One of the things I'm realising in doing the research is how complicated it becomes to make database changes. A simple operation like renaming a column can take 3 full release cycles until it's completed!
It seems to me that having the full rollout of a change take multiple release cycles introduces a lot of potential for human error. In the linked article it shows that code changes are necessary for 2 releases and a database migration is needed for 3 releases.
What I'm looking for
Currently, if we want to remember to do something, we can create a ticket in our issue management system, which creates clutter and also might get moved to a later sprint or the backlog by management; or we can create a TODO comment, which will probably be forgotten about completely.
What I'm looking for is a way that a TODO comment can have a deadline against it, and our Continuous Integration system (current undecided which we'll use) would reject the build if this deadline was expired.
For example, if we rename a column we could create the initial migration for it, and then two TODO comments to ensure that the remaining two migrations are created:
// TODO by v55: Create migration to move constraints to new column, remove references to old column in app
// TODO by v56: Create migration to drop old column
This seems fairly simple to implement, but I'm wondering if something like this already exists, because I don't want to re-invent the wheel.
Additional thoughts
I feel like I might be suffering from XY problem here, given that rolling deployments and blue/green deployments are considered a best-practice it seems strange that I can't find a solution for making database updates less painful. If you think I'm looking into the wrong thing entirely, please let me know in a comment! That said, the database example I gave is just one example, and I think TODO comments with due dates would be useful in other situations too, so even if I'm approaching this specific situation all wrong I'd really like to answers to my actual question too. Thanks!
EDIT: I just thought of another situation where this could be helpful. If you use Feature Toggles to turn on parts of your app when they are ready, you have to be careful to clean them up, otherwise you may end up with Toggle Debt. Comments with deadlines could be a good way of remembering this.
