While trying to debug a weird issue where I knew an exception should have been thrown but was not, I found the following in the Java standard library's java.lang.ClassLoader
class:
* Open for reading, a resource of the specified name from the search path
* used to load classes. This method locates the resource through the
* system class loader (see {@link #getSystemClassLoader()}).
* @param name
* The resource name
* @return An input stream for reading the resource, or <tt>null</tt>
* if the resource could not be found
* @since 1.1
public static InputStream getSystemResourceAsStream(String name) {
URL url = getSystemResource(name);
try {
return url != null ? url.openStream() : null;
} catch (IOException e) {
return null;
What reason would there be where the decision was made that this exception should not be thrown but instead silently consumed?
While discussing this with a coworker a possible option was that perhaps this function predated IOException and thus this was added to maintain backwards compatibility, however this method was added in Java 1.1, while IOException was added in 1.0.
This is a file operation so IOExceptions would not be out of place, so why would the makers of an exception based language choose returning null over passing up a thrown exception?
