Let's say I have IRepository interface implemented by Repository class(uses database context to implement IRepository methods). And IUnitOfWork interface implemented by UnitOfWork class using IRepository.
My questions are:
1) Should I unit test Repository on it's own?(have no idea how, because it uses database context and I don't know if it is good practice to mock database context?)
2) Will it be enough if I mock IRepository and only test UnitOfWork?
David Maisuradze
  • 145
I don't think there's much point. A Repository is supposed to act as a layer of abstraction between your business logic and the database, so by the time you mock the database for testing purposes, all that's left to test is the Repository's API endpoints (a test that I would regard as "uninteresting", and already covered by integration tests anyway).
Of course, depending on what you consider "enough." This is the appropriate place to mock a business operation, in my opinion, since the expected values are those required of your repository mock, and not those of a database (which would require an integration test).
To put it another way, your repository is already expected to return the "correct" value. If you're not sure about that, then include some integration tests for your repository (wired up with the proper data-source) to make sure.
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
  • Thank you for your time. Yes, sorry, "enough" was a bit rough word here. I wanted to ask "WIll it be good practice if I unit test Repository on its own or not?" – David Maisuradze May 18 '17 at 19:01
    "Good practice" is not any better than "enough." The "best practice" is the one that most effectively meets your specific requirements. See https://meta.stackexchange.com/a/142354 – Robert Harvey May 18 '17 at 19:03
  • I don't know if it is good practice to mock database context?
  • Will it be enough if I mock IRepository and only test UnitOfWork?
Always think about what you actually need to test.
Even Uncle Bob admits he doesn't test his GUI. He also insists you move all logic out of the GUI.
It's the same with the DB. If you can move all the interesting logic away from the the DB you don't have to mock the DB. You mock what you use to talk to the DB. Long as that thing has no interesting logic in it that's fine.
candied_orange
  • 102,279
  • 197
  • 315
