I have a class similar to ServletFilter which has multiple validation on the input request
class TokenHandler implements SomeHandler{
  Response handle(Request request){
    if(paramXMissing(request)){
       return new Response(); // empty response
    if(paramYGreaterThan100(Request request)){
   //some more similar validation on request
request parameter can be an instance of any subtype of Request. As most of the validation methods depend on Request instead of the Handler, this seems more like feature envy code smell. Had Request been a normal domain object I would have just Moved method to that class. But in this case, how do I refactor this code (Long method)? I am not sure if introducing a new Validator class would be a right choice.
Edit
I don't have just the validation, but also additional processing on request object, for instance, remove particular parameter from query string.
I actually think that introducing new classes for each specification would be an overkill. Is it really required? Any other alternative?
sidgate
  • 123
    Possible duplicate of [Style for control flow with validation checks](https://softwareengineering.stackexchange.com/questions/148849/style-for-control-flow-with-validation-checks) – gnat May 17 '17 at 17:11
  • ...as for `Request` I would most likely pass it via constructor parameter into that `Specification` class discussed in [this answer](https://softwareengineering.stackexchange.com/a/148855/31260) – gnat May 17 '17 at 17:14
  • Does this mean that I have to create different `specification` classes for each condition? Doesn't it sound like an overkill? – sidgate May 17 '17 at 17:23
  • Are you able to create a subclass of Request, and add your validation functions to that instead? – Pete May 17 '17 at 17:23
  • you create one specification class for all conditions and one instance of that class per request – gnat May 17 '17 at 18:51
I would create an interface for the Validator and create a list of specialized Vatidator objects:
   interface Validator{
     boolean isInvalid(Request request);
  private final List<Validator> validators = Arrays.asList(
      (Validator)request->paramXMissing(request),
      (Validator)request->paramYGreaterThan100(request),
      // Checks could also be implemented as separate classes or enum...
    for(Validator validator : validators){
      if(validator.isInvalid(request)){
    // continue for valid response
Timothy Truckle
  • 2,336
