Which is the better name for a method that returns a boolean?
IsSupportContentType
or
CanSupportContentType
or
Is vs. Can
According to the Microsoft naming convention recommendations, both "Is" and "Can" are OK (and so is "Has") as a prefix for a Boolean.
In plain English, "Is" would be used to identify something about the type itself, not what it can do. For example, IsFixed
, IsDerivedFrom
, IsNullable
can all be found in CLR types and methods. In all of these cases, "Is" is followed by an adjective.
Meanwhile, "can" more clearly indicates a capability, e.g. CanEdit
, CanRead
, CanSeek
. In each of these cases, can is followed by a verb.
Since "Support" is a verb, I think in your case CanSupportContentType
is better.
Shorter alternative
On the other hand, the conventions say the prefix is optional. What's more, it's kind of cheesy to include the argument type in the method name, since a developer can see the type of the argument in intellisense. So you could just name your method Supports
and define it like this:
public bool Supports(System.Net.Mime.ContentType contentType)
...which is shorter and still clearly communicates the purpose. You'd call it like this:
ContentType contentType = new ContentType("text/plain");
var someClass = new MediatorsClass();
bool ok = someClass.Supports(contentType);
Or as a compromise maybe this is best:
public bool CanSupport(System.Net.Mime.ContentType contentType)
It's worth mentioning that the "should" prefix can also be used. According to Apple's guideline, not just "can" and "should", modal verbs in general can be used to name functions that return boolean. I can't see many use of "will" but "should" is nice for advice-inquiring hooks, as seen in reactjs:
shouldComponentUpdate: (newProps: any) => boolean
For the people against the use of "should" prefix for boolean arguments, here is my fresh last one used for an optional argument name (but I need to agree that I can't even remember last time I've used this prefix):
MethodNameToUpdateDataList(..., bool shouldDeactivateMissingIds = false) {}
Neither "is", "can" nor "will" prefix seems ok there... What do you think?
