I recently got into a debate with another developer regarding the below class:
public class GroupBillingPayment
    public void Save(IGroupBillingPayment model)
        if (model == null || UserInfo.UserID == 0)
            throw new Exception("GroupBillingPayment object or Current User Id is NULL , Please Contact Administrator.");
        Data.GroupBillingPayment groupBillingPayment = RepositoryManager.GroupBillingPaymentRepository.GetById(model.GroupBillingPaymentID);
        Mapper.Map(model, groupBillingPayment);
        ServiceManager.GroupBilling.IsBillAlreadyCancelled(groupBillingPayment.GroupBillingID, THROW_ERROR);
        groupBillingPayment.UpdatedBy = UserInfo.UserID;
        groupBillingPayment.UpdatedOn = DateTime.Now;
        RepositoryManager.GroupBillingPaymentRepository.Update(groupBillingPayment, false);
        UpdateGroupBilling([Parameters])
I believe UpdateGroupBilling should not be called inside the save method as it violates the single responsibility principle. But, he says that each time a payment is made, the billing should be updated. Hence this is the correct approach.
My question, is SRP being violated here? If yes, how can we better refactor it so that both our criteria are met?
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
gvk
  • 335
    This depends on the problem domain and on your architecture. How are data and events supposed to flow through your application? What is the responsibility of the involved classes? There isn't enough context in your question to answer this objectively. – amon May 05 '17 at 06:52
    SRP is not a context-free guideline. – whatsisname May 05 '17 at 07:00
    The updated version has some issues which are out of topic here. You may consider posting it at https://codereview.stackexchange.com to get some suggestions for improvements... – Timothy Truckle May 05 '17 at 11:46
    Apply the [POAP](http://www.fragiledeveloper.com/2017/05/the-principle-of-applying-principles.html)! If you don't understand why the principle exists and how it applies to your situation, it's not worth debating yet. And when you *do* understand the purpose of the principle, the answer will be much more straightforward.... to you. Not to us. We don't know your codebase, your organization, or the particular breed of nuts you get to work with. ... I'm VTC-ing this. I don't think we can't give you the "right" answer. Unless the answer is: You need to understand the principle before you debate it. – svidgen May 05 '17 at 13:59
  • See also: https://softwareengineering.stackexchange.com/questions/345018/when-using-the-single-responsibility-principle-what-constitutes-a-responsibili/345029#345029 – svidgen May 05 '17 at 14:01
  • Think in abstract. Forget any implentation detail and do the prototyping of the component following the *Top to Bottom* strategy​. It may or may not answer the question, but what matters is if you can see the levels of abstraction of your use case. Checkout the top voted answer here https://softwareengineering.stackexchange.com/q/110933/222996 – Laiv May 05 '17 at 21:39
    You're almost certainly overthinking this. If the business requirements dictate that you perform some sort of cleanup or update as part of a process, then that cleanup or update *is part of the responsibility, and therefore the responsibility is still single.* – Robert Harvey May 05 '17 at 22:22
  • @svidgen I agree that we should not *apply* a pattern we don't understand because we most likely doing it wrong. But then: how do we learn a principle if we don't *debate* it? – Timothy Truckle May 06 '17 at 07:59
  • @timothy I meant specifically not to debate whether X is a violation of Y, not what Y means... And with regards to what Y means, there isn't usually much room for debate. Y exists for a purpose. Somebody out there with experience *already knows* what Y means. .. this is especially true of things like the SOLID principles, where we know their origin. .. that doesn't mean we can't debate Y at all -- especially it's effectiveness at accomplishing it's purpose. But, it's generally just *bad* to debate these things *in a vacuum.* – svidgen May 06 '17 at 13:29
  • The method is named save, thats all it should do! END OF STORY – John Peters Jun 01 '17 at 02:59
8 Answers8
I would look at it this way:
A method should either call other methods (in same or other objects) which makes it a composed method or do "primitive calculations" (same level of abstraction).
The responsibility of a composed method is "call other methods".
So if your Save method does some "primitive calculations" itself (eg. checks return values), the SPR might be violated. If this "primitive calculations" lives in another method called by your Save method SRP is not violated.
The updated version of the Save method does not follow the single abstraction layer principle. Since this is the more important problem you should extract that to a new method.
This will convert Save into a composed method. As written, the responsibility of a composed method is "call other methods". Therefore calling UpdateGroupBilling([Parameters]) here is not a violation of the SRP, but a business case decision.
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
Timothy Truckle
  • 2,336
    +1, exactly. The Single Responsibility Principle doesn't mean that you can only ever do one *thing* - that would make it impossible to couple things together *at all*. You should only do one thing *at your current level of abstraction*. – Kilian Foth May 05 '17 at 07:56
  • `Save` method has been updated. Please see if this helps – gvk May 05 '17 at 11:30
Single responsibility can be interpreted as function/class should have only one reason to change.
So your current Save method will violate that principle, because it should be changed by more then one reason.
1. Save logic changed
2. If you decide to update something else in addition to updating billing group
You can refactor it by introducing SaveModel method which will be responsible only for saving. And introducing another method which combine all needed operations based on your requirements. So you end up with two methods
public void SaveModel(IGroupBillingPayment model)
    // only saves model
    SaveModel(model);
    UpdateGroupBilling([Parameters]);
Where SaveModel method will have responsibility for saving model to the database and one reason to change - if saving "logic" will change.
Save method now have responsibility to call all required methods for full "saving" process, and have one reason to change - if amount of required method will change.
I think validation can be moved outside of SaveModel too.
Fabio
  • 3,086
Single Responsibility is IMHO a not easy to nail down concept.
A simple rule of thumb is:
When I have to explain, what a method/class does, and have to use the word »and«, it is an indicator, that something smelly may be going on.
On the one hand, it is only an indicator and on the other hand it works better reverse: If two things are going on, you can not avoid using the word »and« and since you are doing two things, you violate the SRP.
But, does that mean on the other hand, if you do more than one thing, you are violating SRP? No. Because otherwise you were limited to trivial code and trivial problems to solve. You would hurt yourself if your were too strict in the interpretation.
Another perspective on SRP is: one level of abstraction. As long as you are dealing with one level of abstraction, you are mostly fine.
What does all that mean for your question:
To decide, whether this is a violation of SRP, it is necessarry to know, what is going on in the save()-Method. If the method is -as the name- suggests responsible to persist the model to the database, a call to UpdateGroupBilling is IMHO a violation of SRP, since you are extending the context of »saving a payment«. You would paraphrase it with »I am saving the payment and update the group billing«, which is - as I said earlier - a (possible) indicator of violation of SRP.
On the other hand, if the method is describing a "payment-recipe" -i.e. what steps are to take in the process- and decide: everytime a payment is finished, it has to be saved (dealt with in another place) and then the group billings have to be updated (dealt with in another place), that would be no violation of SRP, since you aren't leaving the abstraction of the "recipe": you distinguish between what to do (in the recipe) and where it is done (in the according class/method/module). But if that is what your save()-method does (describing which steps are to take) you should rename it.
Without further context, it is hard to say anything concrete.
Edit: you updated your inital post. I would say, that this method violates the SRP and should be refactored. The fetching of the data should be factored out (it should be a parameter of this method). The addition of data (updateBy/On) should be done elsewhere. The saving should be done elsewhere. Then it would be OK to leave UpdateGroupBilling([Parameters]) as is.
Thomas Junk
  • 9,405
  • 45
Hard to be sure without full context but I think your intuition is correct. My personal favorite SRP indicator is whether you're going to know exactly where to go and change something to modify a feature months later.
A class defining a payment type is not where I would expect to go to redefine who does the paying or how the paying is done. I would expect it to be one of many payment types that simply provide critical details that some other part of the app uses to initiate, conduct, or roll back/cancel a transaction, gathering those details through a uniform interface.
It also looks like a recipe for a more general DRY principle violation if you're going to have multiple types each sorting out their own transactions using a lot of the same methods. SOLID doesn't always feel 100% relevant to primarily JavaScript developer (I suspect a lot of it's explained badly though) but DRY is the gold standard in general programming methodology IMO. Any time I come across an idea that feels like an extension of DRY, I give it consideration. SRP is one of those. If everybody stays on topic, you're less likely to be tempted to repeat yourself.
Erik Reppen
  • 6,243
If there's conceptually only one way to UpdateGroupBilling(...), and it only ever happens in that place, then it's probably fine where it is. But the question is related to the concept, not to temporal circumstances, i.e. "for the time being we only do it here."
If either isn't the case, then one way to refactor it would be to use Publish/Subscribe and notify whenever the payment is saved, and have the billing subscribe to that event and update the relevant entries. This is good especially if you need to have several types of billings that need to be updated. Another method would be to think of Billing as a strategy pattern, i.e. pick one and use it, or accept it as well as a parameter. Or, if billing doesn't always happen, you can add it as a decorator, etc, etc. But again, this does depend on your conceptual model and how you want to think about it, so you'd have to figure it out.
One important thing to consider, though, is error handling. If billing fails, what happens with the previous operations?
Yam Marcovic
  • 9,270
I think this design is violating the SRP, but it's really easy to fix and to still do everything else is needed.
Think of it about messages and about what's happening in this method. It should be saving the GroupBillingPayment, but there's nothing wrong if GroupBillingPayment notifies classes that it's been saved. Especially if it's implementing a pattern that's explicitely exposing that behavior.
You could use the Observer pattern.
Here's an example of how it'd work in your case :
public interface Subject {
    public void register(Observer observer);
    public void unregister(Observer observer);
    public void notifyObservers();
public class GroupBillingPayment implements Subject {
    private List<Observer> observers;
        //UpdateGroupBilling([Parameters]) The Observer will have this responsability instead now
        notifyObservers();
    public void notifyObservers() {
        for (Observer obj : observers) {
            obj.update();
public interface Observer {
    public void update();
    public void setSubject(Subject sub);
Now all you have to do is create one or more Observers that'll be bound to GroupBillingPayment and thus get notified whenever it gets saved. It keeps its own dependencies, doesn't know what notified so it doesn't depend on these at all.
Steve Chamaillard
  • 1,691
You want to achieve X. Unless X is quite trivial, you write a method that will do everything to achieve X, call the method "achieveX", and call that method. The single responsibility of "achieveX" is to do everything to achieve X. "achieveX" shouldn't do other things.
If X is complex, then many actions may be needed to achieve X. The set of actions needed may change over time, so when that happens, you change the method achieveX, but if everything goes well, you can still just call it.
In your example, the method "Save"'s responsibility is not to save the bill and update the group billing (two responsibilities), its responsibility is to take all the necessary actions to make the bill permanently recorded. One responsibility. Maybe you named it badly.
gnasher729
  • 42,090
  • 59
  • 119
-2
If I understand your point I'd have the payment to raise an event such as "Payment made" and the class handling the billing subscribing it. In this way the payment handler knows nothing about the billing.
Zalomon
  • 1,200
