I have an application service which returns entity by its registration number
public Entity FindByRegNumber(string number)
if (!RegNumber.IsValid(number))
return null;
var regNumber = new RegNumber(regNumber);
return repository.FindBy(regNumber);
Here RegNumber
is a value object and it has static method IsValid
which verifies that string correctly represents registration number. This method is used inside constructor as well, but, if string is not valid, constructor throws InvalidOperationException
If IsValid
method belonged to some injected dependency, I could just check in my test that IsValid
was called (a kind of white box testing). Now I have to test FindByRegNumber
repeating all the input used for testing IsValid
method (black box testing).
It looks like the only reason to get rid of static method is to make testing easier. It does not even decreases coupling while call to FullRegistrationNumber
constructor stays.
Another approach is to introduce a factory FullRegistrationNumberCreator' which could abstract away both validation and construction of
FullRegistrationNumber`, but it seems like an overkill and overengineering.
Is here a correct solution?
