I know function names can be very expressive. And therefore it can be tempting split up a program into particular functions and call them from a large "oversee-able" functions file.
However is this actually effective for a programmer? Since each function usually relies on some input provided from a previous function, either a returned value or a global variable or whatever else your language uses - it often only works, and makes sense in context with the previous function. A change to a previous function would often obviously destroy functionality in the second function.
When one program is split up into functions which are jumbled up into a functions file. The effect that changes have are not necessarily very clear. So is it a good idea to split things up in this way?
FrustratedWithFormsDesigner
  • 46,105
  • 126
  • 176
Maximilian Travis
  • 169
    If you split up the functions right they will tell a story and keep you from repeating yourself. If there's no story to tell and no repetition then it may not need to be split into functions. – joshp Apr 01 '17 at 00:59
  • I wrote up [this answer](https://softwareengineering.stackexchange.com/a/274821/) to another question a while ago: it does not answer this one, but it is relevant. The answer dives into advantages to splitting a function up, and why it enforces correctness. –  Apr 01 '17 at 05:07
  • How large is the function body? A few hundred lines, or a dozen of thousands lines? The *name* of the function does not matter (except for readability by human developers, which is very important). – Basile Starynkevitch Apr 01 '17 at 06:45
7 Answers7
14
As someone who recently did just that, refactored a few long sheets of code into a set of small functions, I can attest it is effective.
I assume you heard about the Unix principle: "do one thing and do it well". It helps immensely.
A short function is easy to observe, easy to reason about, and easy to test. What's important, it's usually easy to test in absence of most other functions, and while mocking only a few, if any, objects it depends on.
When you write a short function, you are forced to think what exactly it does, come up with a proper name (doIt() does not fit), good parameter names, etc. It makes your code more self-descriptive, and it makes you understand the code better. It also gives you higher-level concepts to describe your program with.
Splitting complex state transitions into short functions makes you think about the data flow of the program, and untangle it as much as possible. This leads to fewer data dependencies, often shorter lifetimes of some data (important when the data is huge), and fewer errors like data races, state updates clobbering each other, etc.
Factoring out any fragment of code larger than a screenful into a function also makes you notice and factor out copy-pasted code, even slightly modified. Finding the common pattern helps understanding.
Sometimes you end up with functions you instantly recognize, because they do (almost) the same thing as some library function already does. You slash the line count, and reuse someone else's existing work (and any upcoming improvements and bugfixes).
Conversely, the functions you extracted can be reused in your other programs. You cannot reuse a fragment of monolithic code, except by copy-pasting it.
Many people struggle to write short functions, though. They tend to write a long monolithic script that does the whole thing, as they would write a whole chapter of prose. One of the remedies is not to just write code, but to immediately run it.
If you have a dynamic language like Python or JS, or even things like Scala, have a REPL open at all times. When you come up with a fragment of code, try it in the REPL. You will need dependent objects for it? Write a function that provides each dependent object. Once you came up with a code fragment that produces something meaningful, wrap it in a function, too. You will need it at the next step. This way you end up with a set of functions that compose into the whole program you needed, and you have run most of it already!
With languages that don't readily provide a REPL things are harder. Here 'test-driven design' may help: you cannot freely play with your code fragments in a REPL, but you can run it cheaply as tests. As you go, you end up with the whole program and with a set of tests verifying and explaining it. With a monolith, this is impossible.
If your program is a throwaway script, not important enough even to be peer-reviewed before running in production, a wall of code may be fine.
Otherwise, factoring your code into smaller pieces pays up every time you have to extend, modify, review someone else's changes to it, or just consult it.
9000
  • 24,162
  • 51
  • 79
    Good idea: the Unix principle of "do one thing and do it well" is most certainly applicable to functions, and I rarely hear that comparison. I approve. –  Apr 01 '17 at 05:14
  • Also +1 for mentioning the Unix principle. – Giorgio Apr 01 '17 at 06:39
    You could have written this answer in one long paragraph. Or one paragraph per sentence. You picked something in between, which is just about right. It's the same with functions. There's too big, and there's too small. – gnasher729 Apr 01 '17 at 16:25
  • @gnasher729: "As simple as possible, but not simpler", as someone famous said. – 9000 Apr 01 '17 at 17:41
While I always favor compact, self-contained functions over huge, sprawling if/else trees, it is true that real-world programs are seldom as nice and neat (untangled) as we would wish. Application state (global or not) is generally unavoidable.
I believe that it is also true that there are diminishing returns to splitting things up into smaller and smaller functions. For a logical extreme, take a look at the book Clean Code by Robert C. Martin. Not everyone will agree with me, but I find many of his examples to actually be slightly less comprehensible after his refactoring. (Maybe I don't write enough Java to appreciate them?)
Having said that, I do personally believe that the function is the most powerful abstraction available to us. Sure, functions can be used incorrectly. There is absolutely nothing stopping you from writing terrible, tangled code with a bunch of tiny functions, even without those evil weapons, the global variables. But on a whole, functions are a force of goodness and light.
When practically possible, heed the standard wisdom of the crowd in creating "clean" functions:
  • Do not modify any external state within your functions.
  • A function should be deterministic: the same input must always produce the same output.
  • A function should do only one thing and one thing only.
Just these three rules will avoid 90% of the most common design headaches. It also allows you to easily write tests for your functions!
Beyond that, just try your hardest to make only "clean" functions when you can. Depending on the application, this can actually be a very difficult exercise at first. But one does get better at it. As with most things, it's a real craft and it takes experience (programming experience in general and experience with that project, in particular) to get it just right.
Untangled code doesn't just happen. It's hard work and an art...and totally worth it.
303
  • 103
DaveGauer
  • 1,287
Yes, this is generally a good idea. Smaller functions are usually easier to read and understand, and are potentially reusable in different contexts. It is true that the process of refactoring can sometimes break some things, but if you do it properly (and fix things as they break and using unit tests to help detect the things which break) then the end result is usually well worth it.
  • 46,105
  • 126
  • 176
  • I understand the point about resuability and readability. However it would seem that a whole lot of the applications overall logic would basically rely on the sequencing of the now separated functions. I guess thats not bad and the sequence itself could be stored in a separate function calling the other functions. – Maximilian Travis Mar 31 '17 at 17:35
  • @MaxTravis: Doing it properly could be to have your main function call each of the smaller functions in sequence, capturing/processing output and passing it to the next function as needed. I'm not sure why "'global' variables" are being mentioned here. Perhaps you could explain the context of your question in a little more detail, maybe give an example of the function that you might be considering for refactoring? – FrustratedWithFormsDesigner Mar 31 '17 at 17:41
  • Ah so in this case i guess you would advocate independence from using the same variable names between functions? Since i am moving from un-modularised code variable names obviously remained consistent throughout. I considered declaring global variables because in PHP the variables created and accessed inside a named function are "local" to the function unless declared global. I will try to concoct a suitable example. – Maximilian Travis Mar 31 '17 at 17:48
  • @MaxTravis: global variables are generally a thing to be avoided at all costs. – Michael Borgwardt Mar 31 '17 at 18:31
    @MaxTravis Also note that functions can be decomposed hierarchically, so that you end up with high-level functions that call lower-level functions that in turn call lower-level functions, rather than having just a series of functions called in a series where output from one function call is passed to the next function. This is an essential and powerful programming principle of abstraction: at any level you do not worry about the details in the implementation of lower level functions, which makes complex problems manageable. – MikkelRJ Mar 31 '17 at 20:31
    @FrustratedWithFormsDesigner I would recommend editing to say that refactoring can break things, however, _unit tests_ can catch them when they break. _Never refactor code without unit tests in place that pass prior to the refactoring_. If we can learn one thing from [Michael Feathers](https://smile.amazon.com/Working-Effectively-Legacy-Michael-Feathers/dp/0131177052/) (and experience) regarding refactoring, that should be it. –  Apr 01 '17 at 05:15
If that is the case, your functions are badly designed. They do not have clear responsibilities or contracts and don't represent good abstractions.
Well-designed functions do one thing that is conceptually easy to understand from the function name without knowing the implementation details, and is mostly isolated from the rest of the application.
You'll find that if you have such functions that are true abstractions of the functionality they implement, they will much more often be reusable in different contexts, and at the same time less likely to have undesired side effects when they are changed.
With a badly designed function, any change you make to it has you worried about breaking things in 5 other places it's called from. With a well designed function, any change you make to it will be something (such as a bugfix) that you want to apply to the 5 other places it's called from.
Michael Borgwardt
  • 51,037
  • 124
  • 176
^ This statement is true even if you leave your code as one big function! Instead of small functions depending on each other, you have lines of code within a big function depending on each other. This is much worse because there is no way to indicate which variables apply to what code in what stage of the execution; everything in local scope is available to everything in the function.
If you were to break it down into a series of smaller functions, you can define constraints on which functions work with what dependencies, by declaring them as parameters and taking advantage of each function's local scope. Thus you can break a larger problem into a series of smaller problems that (1) have clear breaks between them, making each one easier to understand, and (2) have a clear relationship, defined in code, that tells you how the problem is broken down into subproblems.
This is far, far preferable to long functions that cover many pages that require the programmer to scroll up and down to figure out how it works. After years of programming, I can tell you from experience that those are the functions that tend to be full of the nastiest bugs.
John Wu
  • 26,032
  • 63
  • 84
Functional programming languages do everything with functions. Even a language with little support for functional programming should be able to get pretty darn close. So, yes.
Then don't do that. Leave the old function there, and make a new one, possibly using the old function to do most of the work and just tweaking the output.
The general philosophy for functional programming languages is like building up a vocabulary of jargon words and then writing something with them. And how do you get the jargon words? Well, you write definitions in terms of other words you already have. Instead of thinking of it as a giant piece of existing code that needs to be broken up in random places and shoved into functions, think of it as creating a vocabulary of functions that makes writing the top level function easier.
Michael Shaw
  • 5,116
It depends. A single cohesive function is often better than many small functions. But there can be good reasons to extract parts of a function to separate functions, for example:
  • Code repetition
  • Different levels of abstraction
  • A specific section of the code is often changed without the rest of the function changing.
But, decomposing a single function into multiple functions also have a cost in complexity. Unfortunately this cost is easily overlooked, which is why it is tempting to decompose larger functions, even in cases where it actually makes the code more complex and harder to maintain.
Some drawbacks to multiple functions:
They are exposed to other parts of the code, which means the overall complexity burden increase. Maintainability is about reducing the visibility of parts to the tightest possible scope. That is why global variables are frowned upon, local variables are better than class-level fields, and private members is preferred to public. Immutability and constants are preferred to mutability, since it reduce the possible operations on the exposed data structures. A single cohesive function is therefore better than multiple exposed functions since it encapsulates its internals better.
If extraction into muliple functions only happen because of an arbitrary limit on function size, the functions will not represet natural abstractions or units of computation, which mean they will be hard to understand and have awkward signatures. Furthermore, such functions often have temporal coupling, i.e. they much be called in a certain sequence to give a meaningful result. Temporal coupling is explicit inside a single function blody, but implicit across multiple functions which is one of the hidden costs.
Unfortunately, some coding guidelines put limits on the lengths of function, without consideing the hidden cost of an unnatural decomposition.
JacquesB
  • 57,310
  • 127
  • 176
